POV-Ray : Newsgroups : povray.binaries.images : Slush candle: Near-final [160KB] Server Time
10 May 2026 00:54:57 EDT (-0400)
  Slush candle: Near-final [160KB] (Message 1 to 9 of 9)
Subject: Slush candle: Near-final [160KB]
Date: 26 Feb 2006 06:08:14
Message: <44018c1e@news.povray.org>
* Finally fixed the candle flame. I'm reasonably pleased with it. (I
know everybody else will tell me it's rubbish...)
* Took Gail's suggestion to make the marble stand rounded. I think it
looks better this way.
* Spend countless hours tearing my hair out attempting to make the ice
crystals look like... um... ice crystals. In the end, I took the fill
light and made it white instead of blue, and decreased the fade_distance
on the candle flame. This makes the crystals look less blue and more
white, which sort-of achieves the desired effect. (The crystals are also
smaller now, which helps... though not as much as I had hoped.)
At present, the ice crystals don't look enough like ice, and the overall
colour balance of the image is wrong. I doubt I can actually fix either
of these. (Suggestions welcome tho.)
This is rendered without radiosity. It bearly makes any difference now,
but does result in a very slightly redder image, which is probably
better. I'm rendering it now. Not sure which version I will submit.
Render time for this image was 2 hours + 48.3 seconds.
Download 'candle-ip-08+rad=off.jpg' (159 KB)
Preview of image 'candle-ip-08+rad=off.jpg'
Subject: Re: Slush candle: Near-final [160KB]
Date: 26 Feb 2006 06:35:21
Message: <44019279@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:44018c1e@news.povray.org...
   It looks ok to me.
  Three suggestions, time permitting:
  1. Try to make the wick black at the top, and white(ish) at the bottom.
  2. Give your ice crystals a higher ambient.
  3. Make the flame bigger.
     Looking good though.
    ~Steve~
Date: 26 Feb 2006 10:00:54
Message: <4401c2a6@news.povray.org>
What's the finish on the ice crystals? Specifically specular and roughness,
or phong and phong_size
Date: 27 Feb 2006 00:52:25
Message: <44029399$1@news.povray.org>
Orc,
Suggestions:
Bring the base of the flame down to the bottom of the black part of the wick
where it can actually melt the wax and generate a wax puddle to feed off.
The puddle doesn't need to be any more visible than it already is.
Paint the asphalt chips/kidney stones matte white!
:D
Date: 27 Feb 2006 16:34:18
Message: <4403705a@news.povray.org>
Might have time...
> :D
They already have pigment {rgb 1}... The fact that they look that colour
is some kind of lighting issue. :-(
Date: 27 Feb 2006 16:36:10
Message: <440370ca$1@news.povray.org>
No phong.
Specular is 0.5; roughness (and brilliance) are both at default.
(And for the record, colour = rgb 1.)
Date: 27 Feb 2006 23:29:13
Message: <4403d199@news.povray.org>
news:440370ca$1@news.povray.org...
roughness,
> No phong.
try specular 1 roughness 0.0002 (if you still have time)
Should give them a bit more gleam
Subject: Final
Date: 28 Feb 2006 16:59:20
Message: <4404c7b8@news.povray.org>
OK, well... I just submitted my entry!
Never done this before... kinda scary...
Made minor adjustments to the image:
* Flame is bigger. (Not sure it looks better this way, actually.)
* Ice is more shiny now. (Not drastically.)
I guess you'll all have to wait until the voting opens to see it...
Subject: Re: Final
Date: 28 Feb 2006 17:22:12
Message: <4404cd14@news.povray.org>
news:4404c7b8@news.povray.org...
      You're gonna cop it now... Just wait... You'll get phone calls at
3am...
       :op
  Proportionately, your original flame was just about to... disappear.
   In RL, it needed to be big... ger.
    Yep, only another twenty days to go...  ;)
      ~Steve~
