POV-Ray : Newsgroups : povray.binaries.images : media-fog bug? Server Time
2 Aug 2026 10:46:29 EDT (-0400)
  media-fog bug? (Message 11 to 20 of 20)
Subject: Re: media-fog bug?
Date: 21 Feb 2006 02:53:55
Message: <43fac713@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> schreef in bericht
news:43f9e7f5$1@news.povray.org...
> I shall test without this to see if there is a difference
....No. No difference   :-(
Date: 21 Feb 2006 03:10:16
Message: <43facae8$1@news.povray.org>
"Tek" <tek### [at] evilsuperbraincom> schreef in bericht
news:43fa041a$1@news.povray.org...
> Actually that's different to my problem, my media container is invisible
but
> the smoke media from my volcano gets more fogged than the top of the
volcano
> does at the same distance.
> I've managed to work round the problem by an extremely elaborate means:
> First, I tried using a global media instead of the fog, but that did
exactly
> the same thing. So then I replaced it with a huge box of media in front of
> the camera, differenced with the smoke-media's container. And I added a
copy
> of the air-media to the inside of the smoke media's container. All of this
> meant that pov finally got the message and gave me the result I was after,
> though it's a ludicrously elaborate work-round.
Yes it's different, but somehow I cannot convince myself that there is not a
common problem here which concerns media and fog...
Subject: Re: media-fog bug? intersecting with isosurface
Date: 21 Feb 2006 04:40:11
Message: <43fadffb@news.povray.org>
news:43f970b9@news.povray.org...
> The container is, however, hardly or not visible when in front or
> intersecting a textured surface/object. In my Alien Cliff image, I cannot
> see it against the cliff.
This is not true unfortunately :-(
I looked acrefully at my image and saw strange patches that shouldn't be
there. So I made a new test with the fog, the media, and an isosurface
representing the cliff. This is the result. Note that the horizontal plane
does not show any artifact!!
Download 'Media_mist_test2.jpg' (17 KB)
Preview of image 'Media_mist_test2.jpg'
Date: 21 Feb 2006 04:55:23
Message: <43fae38b$1@news.povray.org>
Thanks for giving the partial script earlier, Thomas. I just now got a look
at a rendering of that here and saw the container bubble this time. I was
going to ask if you had POV 3.6.1a or the 3.6.1b but I guess that's not the
reason anyhow.
I didn't know you were using two fogs together before this point in time,
thinking it was only media and one fog. I have no idea why the two fogs
cause the media container to appear.
Bob H
Date: 21 Feb 2006 08:52:28
Message: <43fb1b1c@news.povray.org>
"Bob Hughes" <omniverse@charter%net> schreef in bericht
news:43fae38b$1@news.povray.org...
look
the
> reason anyhow.
Thank you Bob, for taking time to look into this. Which shows again, by the
way, that it is always important to give complete information. Small details
(like one or two fogs) can easily be overlooked when just asking questions.
In fact, in the latter case, it is not the fog which causes the container to
appear! The container is carved out of the isosurface whether there is a fog
or not! I am puzzled because I cannot find any document treating this
matter. But I may be overlooking the obvious (I wouldn't be surprised).
So I end up with two problems.
1. interaction media and 2 fogs
2. interaction media and isosurface
Date: 21 Feb 2006 11:15:01
Message: <web.43fb3bb0ee45fcd0731f01d10@news.povray.org>
I've been having a play with this, and I have a couple of conclusions.
It's not the media. It appears to be a fog problem - if you take out the
interior block, the (now totally invisible) container object still shows up
if you use more than one fog. Unless someone knows a way around this, I
guess you'll have to fake one of the fogs with media (!).
Again, it's the container object intersecting the isosurface that seems to
cause the problem. Try raising the accuracy of the isosurface (i.e., use a
lower accuracy value). That worked with my tests.
Hope that's of some use
Bill
Date: 21 Feb 2006 15:55:13
Message: <43fb7e31$1@news.povray.org>
Oh, isosurface has a keyword for that, it's all_intersections. Won't help
the fog bubble any but should eliminate those empty places where another
object is in contact with a isosurface. There's also a way to give it a
certain number of possible "intersections", the Help tells something about
it. I wasn't paying any attention to those arches in that last image and
only looked for the media container bubble. ;)
Bob H
Date: 22 Feb 2006 02:46:53
Message: <43fc16ed@news.povray.org>
news:43fb7e31$1@news.povray.org...
to
a
Thanks a lot, Bill and Bob,  for these thought.
Accuracy it is! I had forgotten that I had changed the default value for
faster render. Did not realise that it would also influence other things.
Very stupid... I had tried already increasing max_trace (or
all_intersection) but to no avail, so I was on the wrong track.
Remains the transparant object/fogs problem. Replacing one of the fogs by a
media is tricky to say the least, and will bring down my already very slow
render speed even more. I shall first try to leave it out altogether and see
what the image is like.
Again, thanks both of you for your help!
Date: 22 Feb 2006 03:09:14
Message: <43fc1c2a@news.povray.org>
"Thomas de Groot" <t.d### [at] internlnet> wrote in message
news:43fc16ed@news.povray.org...
Good to know there was an explanation. :)  Wish you much luck getting that
cliff scene done.
I tend to change accuracy only for changing effect of how textures appear,
something I noticed early on when isosurfaces were first being implemented
in POV or to see how the it's surface differs at varying values of accuracy.
I leave it alone most of the time now.
Bob H
Date: 23 Feb 2006 03:59:13
Message: <43fd7961@news.povray.org>
news:43fc1c2a@news.povray.org...
things.
> cliff scene done.
accuracy.
Thanks Bob. The scene will be finished eventually. :-)   I have noted that,
against the cliff, the media container is invisible (the fog is probably too
thin thin) so I left my two fogs in place. Started rendering again....
I mainly change accuracy for render speed or to test how different
isosurface settings looks, although I admit it doesn't change speed that
much in general. To avoid forgetting to set things back to normal, I should
leave it alone...
