POV-Ray : Newsgroups : povray.binaries.images : RSOCP Server Time
23 Mar 2026 19:06:47 EDT (-0400)
  RSOCP (Message 1 to 9 of 9)
Subject: RSOCP
Date: 9 Feb 2006 03:30:01
Message: <web.43eafcf196b04c3582fc96790@news.povray.org>
Hi there!
I am hanging around the newsgroups since a while. It is time for me to make
my  RSCOP contribution. Here is an attempt. It could be named "H + 1
microsecond".
   Bruno.
Download 'rsocp_2.png' (551 KB)
Preview of image 'rsocp_2.png'
Subject: Re: RSOCP
Date: 9 Feb 2006 08:45:01
Message: <web.43eb46ce798b978382fc96790@news.povray.org>
"Bruno Cabasson" <bru### [at] alcatelaleniaspacefr> wrote:
> Hi there!
> microsecond".
>    Bruno.
Here is another render. "H + 2 microseconds"
   Bruno
Download 'rsocp_2bis.png' (229 KB)
Preview of image 'rsocp_2bis.png'
Subject: Re: RSOCP
Date: 9 Feb 2006 09:14:37
Message: <43eb4e4d$1@news.povray.org>
Bruno Cabasson wrote:
> Hi there!
> microsecond".
Pretty. What are the spikes ? media or translucent cylinders?
Two points....
File size - if you'd jpeg compressed the image it could have been 30KB
not 700+KB and you'd not have lost any noticable image quality. Some
people feel quite strongly about this especially if they're not on
broadband. My connections are 1Mb/sec at home and *far* faster at work
so I'm not ppersonally bothered by download speed but the newsgroup
server only has limited space.
Secondly my newsreader (Thunderbird) has a bug where it confuses threads
with the same name so I'd appreciate it if people came up with more
descriptive (and hopefully unique) titles than "RSOCP" or "IRTC WIP". I
know it's a bug in my newsgroup client but its probably generally a nice
idea to give more descriptive names regardless.
Anyway welcome to the group, and don't let the above two comments put
you off (just try to keep file sizes down a tad.)
Happy POVing
Verm
Subject: Re: RSOCP
Date: 9 Feb 2006 09:50:01
Message: <web.43eb556b798b978382fc96790@news.povray.org>
> > Hi there!
> > microsecond".
> Two points....
> Happy POVing
> Verm
OK. Next posts will be jpeg.
The spikes are true media effect: the sphere has an internal light_source
and the light comes throught the holes of the cracked sphere, which is
sourrounded by scattering media. BUT, in order to have well-defined
'spikes' I had to increase media samples up to 200 (yes, two hundred), and
only one interval.
Here is the code for the sphere:
#declare THICKNESS = 0.01; // Thickness of the sphere
#declare THRESHOLD = 0.03; // Threshold for the crackle pattern
#declare CM_Incandescent = color_map
    [0 White]
    [0.1 Yellow]
    [0.2 Coral]
    [0.3 Orange]
    [0.4 Red]
    [0.5 VioletRed]
    [0.6 Light_Purple]
#declare P_Crackle = pigment {crackle scale 0.5 turbulence 0.15 omega 0.5
color_map {[0 rgb 0][THRESHOLD rgb 0][1.1*THRESHOLD rgb 1]}}
#declare fn_Crackle = function {pigment{P_Crackle}}
#declare FOUND_MAX_GRADIENT = 20;
#declare MIN_FACTOR = 0.6;
#declare O_BaseSphere = isosurface
    function {f_sphere (x,y,z, (1-THICKNESS)) -
THICKNESS*fn_Crackle(x,y,z).red}
    max_gradient 20
    evaluate FOUND_MAX_GRADIENT*MIN_FACTOR,
sqrt(FOUND_MAX_GRADIENT/(FOUND_MAX_GRADIENT*MIN_FACTOR)), 0.7
    contained_by {sphere {0, 0.9999}}
#declare O_CrackedSphere = difference
    object {O_BaseSphere}
    sphere {0, 1.001*(1-THICKNESS)}
#declare O_Media = sphere
    0, 1
    pigment {rgbt 1}
    hollow
    interior
        media
            intervals 1 samples 200
            scattering {1, White}
            density {spherical color_map {CM_Incandescent}}
            density {spherical turbulence 0.2}
            density {spherical}
#declare O_ExplodingSphere = union
    object {O_CrackedSphere}
    object {O_Media scale 2}
I am curently rendering another try with radiosity and partially reflective
ground, and I'll post it as jpg.
   Cheers.
Subject: Re: RSOCP
Date: 10 Feb 2006 04:41:52
Message: <43ec5fe0$1@news.povray.org>
> only one interval.
Owch rendertimes? It took 12 hrs to render 800*600 on a 3.2 ghz machine
then I saw I'd messed up the crackle pattern and got a seam.
Roll on the multiprocessor release of pov - although that won't help you
with radiosity.
I'll be expecting the radiosity version of this scene in May then.
Subject: Re: RSOCP
Date: 10 Feb 2006 05:15:00
Message: <web.43ec6778798b978382fc96790@news.povray.org>
> > only one interval.
> with radiosity.
I rendered a pure-radiosity version (only the light_source inside the
sphere) last night, and it took about 2:30 hours for 800*600 on a laptop
equipped with AMD Athlon XP3200+ (clocked 2.2 Ghz). I join here the result,
but the settings are not satisfactory yet (splotchiness), and I'll post a
new try asap.
     Bruno.
Download 'rsocp_5.jpg' (88 KB)
Preview of image 'rsocp_5.jpg'
Subject: Re: RSOCP
Date: 10 Feb 2006 15:20:00
Message: <web.43ecf526798b978365660efe0@news.povray.org>
I'm impressed with your light rays effect, and how simple your code for it
is. :-) Nice.
William
Subject: Re: RSOCP
Date: 10 Feb 2006 16:00:01
Message: <web.43ecfe07798b97833ae2665e0@news.povray.org>
> is. :-) Nice.
> William
Thanks :-) But the counter part is the render time. I rencently rendered a
800*600 radiosity version which took 2:30 hours on a laptop AMD Athlon
3200+. I'll post asap (still tuning). Depending on the lighting, it may
take half a day ...
Whatever can be my effots, I am million lightyears away from the POV-gurus
and what they can do. Thanks to them for their kindness and contributions,
and admiration for their art and skill.
         Bruno
Subject: Re: RSOCP
Date: 28 Jan 2008 17:11:32
Message: <479e5314$1@news.povray.org>
Wow! If only I had the source code, I would do some intergalactic "thing" of
it!
Bruno, can I have the source code?
Thanks,
Sven
"Bruno Cabasson" <bru### [at] alcatelaleniaspacefr> schrieb im
Newsbeitrag news:web.43eafcf196b04c3582fc96790@news.povray.org...
> Hi there!
> make
> microsecond".
>   Bruno.
