POV-Ray : Newsgroups : povray.binaries.images : Fire and... wait, what the hell...? [100 KB] Server Time
14 Aug 2026 19:02:14 EDT (-0400)
  Fire and... wait, what the hell...? [100 KB] (Message 11 to 15 of 15)
Subject: Re: Fire and... wait, what the hell...? [100 KB]
Date: 10 Feb 2006 00:05:06
Message: <43ec1f02$1@news.povray.org>
"Gail Shaw" <gshaw AT sentechsa com> wrote in message
news:43ec1820@news.povray.org...
> Leave the candle flame orange/yellow and put a fade_distance on it, then a
> blue light from above will look very nice. Warm in the center (within
> range
> of the candle) and cool further away
Yeah exactly, you need the orange but it will look more orange if there's a
second light that's at the other end of the spectrum and in a different part
of the scene, lots of nice contrast and varying tone.
Tek
http://evilsuperbrain.com
Date: 10 Feb 2006 14:17:24
Message: <43ece6c4$1@news.povray.org>
>>I tried making the candle flame cyan instead of yellow.
>>It made the wood look green! :-S
> blue light from above will look very nice. Warm in the center (within range
The yellow light source inside the flame already has face_distance set.
(And face_power=2.)
Now, here's a question. Should I add a blue *light source*, or just make
the roof of the box bright blue and let radiosity do the rest?
>>The ice did look slightly more icy though. But only slightly. I think
>>maybe the ice is just too damn transparent? Or maybe I should put some
>>scattering media in it or something? (I mean heck, it's only 4 hours a
>>render at the moment; why not make it 4,000 hours??)
> Try these...
> #declare M_Ice= // might be suitable, was designed for a frozen lake
>  material {
>   texture {
>    pigment{rgb <.9,.9,1>}
>    normal {bumps 0.02 scale 0.25 turbulence .5}
>    finish {specular 0.5 roughness 0.02 diffuse 0.7 ambient 0.3
>     reflection { 0 , 0.15 }
>     conserve_energy
>   interior {
>    ior 1.25
>    fade_distance 0.002
>    fade_power 2
>    fade_color rgb <1,1,1>
> #declare T_Snow=
>   texture {
>    pigment {rgb <0.95,0.95,1>}
>    finish {
>     ambient 0.25
>     diffuse 0.55
>     reflection {0,0.2}
>     specular 0.6 roughness 0.008
>    normal {granite 0.1 scale 0.01}
Thanks. I'll give 'em a whirl.
>>I haven't even started on the flame yet. As I see it, I need to fix the
>>abysmal wood and marble textures, make the ice look more like ice, and
>>somehow make my snow look like snow.
> The textures in woods.inc and stones.in are quite nice, at least as
> starting point
Um... isn't that defined as cheating?
>>So, basically, change the entire image, actually... >_<
> As my archery coach is fond of saying Why should you be different from
> everyone else? Most of my scenes go through 2-3 complete redesigns before
> I'm happy.
Ah well... we'll see what I can get done over the weekend...
Date: 10 Feb 2006 14:50:51
Message: <43ecee9b@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:43ece6c4$1@news.povray.org...
> (And face_power=2.)
What's the fade_distance, what's the colour and how big is the scene?
personally, I'd say scrap the radiosity, but that's because I've never had
much luck with it.
Give it a try both with and without if you have the time.
Pleasure
> > starting point
No, why would it? It's called not reinventing the wheel when it's not
necessary.
Irtc doesn't say that you must create everything yourself, just that you
must give credit for other's work
Do you not use any of the standard pov includes?
Date: 10 Feb 2006 16:55:08
Message: <43ed0bbc$1@news.povray.org>
>>(And face_power=2.)
*checks*
face_distance is 50 cm. (For reference, the candle is 20 cm tall.)
Colour is <0.9, 0.8, 0.5>.
> much luck with it.
Without the radiosity, almost the entire floor is in shaddow and comes
out pure black. (It's shaded by the candle. BTW, *real* candles do this
also. I have *lots* of candles. What can I say? I enjoy burning things.
Erm...)
Of course, if I add another light source...
>>>starting point
> necessary.
I used functions.inc so I could access f_bozo [which is what generates
that bizzare candle] and f_crackle [for the ice crystals]. But no, I
never use anything else.
Date: 11 Feb 2006 04:04:48
Message: <43eda8b0$1@news.povray.org>
Personally I always use radiosity if it doesn't make my renders too slow
(which it usually does!), particularly if I have an enclosed scene like this
where you'd need a lot of lights to fake all the light that should be
bouncing off the walls. I normally use the Radiosity_Fast setting in
rad_def.inc, because it's way too complex to figure out what all the
radiosity settings do.
Tek
news:43ed0bbc$1@news.povray.org...
>>>(And face_power=2.)
> *checks*
>> had
>> much luck with it.
> Without the radiosity, almost the entire floor is in shaddow and comes out
> pure black. (It's shaded by the candle. BTW, *real* candles do this also.
> I have *lots* of candles. What can I say? I enjoy burning things. Erm...)
>>>>starting point
>> necessary.
> that bizzare candle] and f_crackle [for the ice crystals]. But no, I never
> use anything else.
