POV-Ray : Newsgroups : povray.binaries.images : Alien Cliff...again [~150kB] Server Time
2 Aug 2026 14:57:30 EDT (-0400)
  Alien Cliff...again [~150kB] (Message 31 to 38 of 38)
Subject: EUREKA!
Date: 5 Feb 2006 03:03:39
Message: <43e5b15b@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> schreef in
bericht news:43e34ca6$1@news.povray.org...
> And 36 hours, sheesh, at was resolution are you rendering? :-) Is it just
> because of the isosurface, or is there lot of media in there? If it's
> isosurface...
I found the culprit! It is the texture used for the landscape. I embedded a
slope texture inside another slope texture. Now, this works fine, but is
very slow, and not really essential in this scene. I corrected it and lo!
Much faster!
Subject: Re: EUREKA!
Date: 5 Feb 2006 04:42:36
Message: <43e5c88c@news.povray.org>
news:43e5b15b@news.povray.org...
> Much faster!
Now you can rise render time again with media haze for your waterfall ;)
Marc
Subject: Re: Alien Cliff...again [~150kB]
Date: 5 Feb 2006 05:29:09
Message: <43e5d375$1@news.povray.org>
> I am not sure about this, but I assume that it is the calculation of the
> lightfall and shadows of the object elements that takes all the time?
I'm sure if you search around you can find data on these NGs somewhere,
but basically the thing that typically takes most of the time in
raytracing is figuring out which object(s) a ray actually intersects.
(They recon ray intersection tests typically make up 80% of the
calculation - obviously depending on what you're drawing.)
This is probably *especially* true with isosurfaces. Gotta do a whole
adaptive sampling process for each ray intersection there. (Plus extra
calculations to find the surface normal.)
Once you have the ray intersection coordinates and the surface normal,
actually figuring out the lighting is a tiny little calculation. (Except
that if you want shadows, gotta shoot *more* rays... And if you have
area lights, gotta shoot *loads* more rays...)
This is why POV-Ray [currently] has bounding boxes, vista buffers, light
buffers, etc. It's all the try to reduce the number of ray intersection
tests...
[I understand the new beta might be using kD trees or something... not
finalised yet.]
Date: 5 Feb 2006 07:22:43
Message: <43e5ee13@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> schreef in bericht
news:43e5c88c@news.povray.org...
> > Much faster!
You know what? I did some testing indeed..... render time dropped
vertiginously!! I am seriously thinking not to implement that item... :-(
Date: 6 Feb 2006 04:30:00
Message: <web.43e716af435fc922731f01d10@news.povray.org>
It's interesting that there's a whole range of scene planning / modelling
skills that have no impact at all on the final image but can make the
rendering time feasible as opposed to prohibitive. It's always worth trying
for speed. That's why I'm building my knots out of meshes - I tried it as a
sphere_sweep originally and it took hours - at the moment 35,000 meshes
only take 35 minutes (that's with area lights and at 1024x768).
That said, patience is a virtue when the chips are down. Like Stefan, I
often leave renders running for 100s of hours, usually on my office PC
overnight or at weekends.
Keep up your productive patience!
Bill
Date: 6 Feb 2006 10:12:25
Message: <43e76759$1@news.povray.org>
news:web.43e716af435fc922731f01d10@news.povray.org...
trying
a
> Bill
Thanks Bill. Yes, I agree with you.In the present case, I have lost again
quite a lot of render speed by using a more complex plant (mesh2 of course).
And now I have included also a media mist at the base of the (moved
elsewhere) waterfall.
Patience I have (in Yoda speak)... I think the end result will be very
interesting.
Date: 7 Feb 2006 05:50:00
Message: <web.43e87a1a220a28164e7d119a0@news.povray.org>
Man-o-man, this has improved dramatically since I last saw it. Looks like it
could end up being a fantasy book cover. Many elements in the scene are so
interesting that it's not possible to just "glance" at it--the total effect
astounds me. The 'sum is bigger than its parts' so to speak. What grand
scale.
Those Pteranodons(?) are quite nice. A suggestion would be to give them a
more interesting texture, in keeping with the fantastical atmosphere of the
entire scene. Something more colorful, perhaps.
Ken
Date: 7 Feb 2006 10:07:14
Message: <43e8b7a2@news.povray.org>
"Kenneth" <kdw### [at] earthlinknet> schreef in bericht
news:web.43e87a1a220a28164e7d119a0@news.povray.org...
it
effect
> scale.
the
Thank you indeed!
Yes, going well, and the next version is pending (veeeeery slow because of a
media simulating the vapor at the base of the waterfall!!)
Good idea about the Pteranodons! I used the standard textures that came with
them, but I am going to change that. Thanks for mentioning that feature.
Maybe a leopard texture would be nice....
