POV-Ray : Newsgroups : povray.binaries.images : volcano WIP update Server Time
2 Aug 2026 11:53:06 EDT (-0400)
  volcano WIP update (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: volcano WIP update
Date: 29 Jan 2006 09:20:37
Message: <43dccf35@news.povray.org>
news:43dbaf21@news.povray.org...
> Well I've been putting a lot of work into the volcano, though I've hardly
> touched anything else in the scene.
Very nice.
I'll echo a couple of others. Scrap the underwater and just focus on above.
At the moment it's a split image with two disconnected points of focus.
Some ice on the water, steam where the lava hits the ocean, glow around the
top and it'll look very nice.
Date: 29 Jan 2006 16:39:23
Message: <43dd360b@news.povray.org>
The bit underwater is just a placeholder! if you compare it to the first WIP
you'll see it hasn't changed, honestly it's just a bunch of spheres I threw
down there to remind me to come back later and put something in. I should
probably have mentioned that!
The other suggestions are good though, I'm going to try to do all of them.
Tek
http://evilsuperbrain.com
"Ger" <No.### [at] ThankYou> wrote in message news:43dbfbb9@news.povray.org...
>> touched anything else in the scene. As you can see I've incorporated a
>> lot
>> of the great suggestions from folks round here, thanks everyone! The only
>> problems I have with the volcano now are: it's still too dark - I didn't
>> realise until after this lengthy render, and there's lava touching snow
>> in
>> the foreground which is obviously complete nonsense! Next I'm going to
>> work on the smoke and under-sea area.
>> My favourite bit in this is the lava rivers, which work using a really
>> simplistic particle system that basically rolls a particle down the
>> volcano leaving a trail of blobs behind it. Slight adjustments to the
>> start position and random seed make it take radically different paths,
>> which actually looks pretty realistic.
>> Anyway I thought I'd post this for further comments, and so you can see
>> how much better it's got!
> Coming along neatly, but ( sorry, there's always one of those ) :)
> 4 things above the water that caught my eye
> No distinct column of smoke/dust/ash over the vent
> The boulders/rocks that come flying out of the volcano all are(look like)
> the same size.
> No smoke/dust plumes where they hit the ground
> No steam where the lava touches the water
> under water
> The bulging lava doesn't seem connected to the volcano
> Ger
Date: 29 Jan 2006 16:46:40
Message: <43dd37c0$1@news.povray.org>
I think I explained all this in an earlier post, though I should have said
when I posted this picture, allow me to reiterate:
1/ The mountains and undersea areas are just placeholders (cones and
spheres) until I get round to working on them, frankly I'm amazed people
keep commenting on them! To me they look so obviously unfinished.
2/ That isn't a drop of lava underwater, it's one of those underwater lava
vents where lava's escaping through a small crack underwater and solidifying
on the outside almost immediately, but the pressure of the lava keeps
cracking the solid surface so more of it can break through. This is why it's
so far from the volcano, it hasn't fallen there it's come up from
underground.
Tek
"Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> wrote in message
news:43dcaf24$1@news.povray.org...
>> how
> Ok, forget my earlier comments partly. I'm still disturbed about that
> there's _one_ glowing lava drop underwater, but not another even near.
> And the mountains at background are still exported from Egypt :). All
> other things I mentioned you seem to have maintained with honour.
> But maybe there should be steam (and boiling?), where the lava river
> gets into the water?
> Eero "Aero" Ahonen
>   http://www.zbxt.net
Date: 29 Jan 2006 16:48:42
Message: <43dd383a@news.povray.org>
I'm going to keep disagreeing with people about the underwater area until I
get round to working on it. Personally I think it's the most important part
of the whole image because it shows the cold beating the lava, which
balances out what's happening above.
I guess I should work on that next so people can see what it's supposed to
look like and see if they still disagree with me :)
Tek
"Gail Shaw" <gshaw AT sentechsa com> wrote in message
news:43dccf35@news.povray.org...
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
> Very nice.
> above.
> the
Date: 29 Jan 2006 19:02:29
Message: <43dd5795$1@news.povray.org>
news:43dd383a@news.povray.org...
> I get round to working on it. Personally I think it's the most important
> part of the whole image because it shows the cold beating the lava, which
Tek,
Expect to see a lot of boiling at the undersea vent.
For form google 'black smoker' - those chimneys are heaps of fun...  and a
modelling challenge.
http://images.google.com/images?q=black+smoker&hl=en&btnG=Search+Images
D
Date: 30 Jan 2006 06:01:20
Message: <43ddf200@news.povray.org>
news:43dd5795$1@news.povray.org...
> Tek,
> D
I think Tek intents that kind of cushion lava
http://satftp.soest.hawaii.edu/space/hawaii/vfts/pele/page.s2.html
As you can see water pressure and temperature conditions prevents water to
boil further than 1 inch away the  forming crust.
Steam condensates and bubbles shrink as soon as formed.
Marc
Date: 30 Jan 2006 15:25:00
Message: <web.43de751c9c2a5cdebe920ef30@news.povray.org>
It's looking real good...
Quick thought:  The lava will cool as goes downhill.  That should make it
change from yellow to red and from bright to dim as it gets farther away
from the heat source.
Jon
Date: 30 Jan 2006 16:02:24
Message: <43de7ee0@news.povray.org>
I thought it's not even near of finishing, but I guessed that you'd want
visions of the image (I would've). My apologies, if I was so wrong.
> underground.
Ah. For my eye, it looked like a stone for my eye. But after all, I
didn't even realize that those cracks exist (thou it's logical, while
thinking it now).
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 30 Jan 2006 16:05:08
Message: <43de7f84@news.povray.org>
Nice! Now, even I can see (and understand) what's the underwater part
about :).
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 30 Jan 2006 16:40:07
Message: <43de87b7@news.povray.org>
news:43ddf200@news.povray.org...
Pillow should be better than cushion.
Marc
