POV-Ray : Newsgroups : povray.binaries.images : I got an idea Server Time
10 May 2026 07:18:37 EDT (-0400)
  I got an idea (Message 11 to 14 of 14)
Subject: Re: I got an idea
Date: 12 Jan 2006 14:56:39
Message: <43c6b477$1@news.povray.org>
fls13 wrote:
> Kozaburo does paint hilites into his textures, which I wish he wouldn't do.
> Would like to swap material settings on skin, eyes, etc. with those who use
> Poser figs in Pov-ray.
I don't really like the way PoseRay makes the material file, and all I
did for this figure was rearrange and change formatting, and tweak some
materials...as I prefer to have all the skin textures be identical, I
#declare a texture for i.e. the body or head, then reference that for
each material.  looks a lot nicer in the file instead of the massive
clutter that gets output by default, defining each one separately, and
with unnecessary levels of precision in the values for things...
for instance, from the texture file I have for the figure in the
tenshi.jpg scene (though the eyes I could probably make the material
definitions more compact...what's silly is the eye texture maps,
separate for left and right, have a reflection, and they're just
mirrored...so one eye is reflecting the opposite of the image map they
used to make it, lol)
//Map definitions
#declare p_map1 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LarkynBody.jpg"        interpolate 2}}
#declare p_map2 =normal  {bump_map            {jpeg
"C:\Data\3D\LarkynBodyB.jpg"       interpolate 2}}
#declare p_map3 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LarkynHead.jpg"        interpolate 2}}
#declare p_map4 =normal  {bump_map            {jpeg
"C:\Data\3D\LarkynHeadB.jpg"       interpolate 2}}
#declare p_map5 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\A3Teeths.jpg"          interpolate 2}}
#declare p_map6 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LarkynEyeL.jpg"        interpolate 2}}
#declare p_map7 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LarkynEyeR.jpg"        interpolate 2}}
#declare p_map8 =pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LeatherJacketMAP.jpg"  interpolate 2}}
#declare p_map9 =normal  {bump_map            {jpeg
#declare p_map10=pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LeatherBaceMAP.jpg"    interpolate 2}}
#declare p_map11=normal  {bump_map            {jpeg
#declare p_map12=pigment {uv_mapping image_map{jpeg
"C:\Data\3D\short_bob_brown.jpg"   interpolate 2}}
#declare p_map13=pigment {uv_mapping image_map{jpeg
"C:\Data\3D\short_bob_trans_i.jpg" interpolate 2}}
#declare p_map14=pigment {uv_mapping image_map{jpeg
"C:\Data\3D\LarkynLashes_i.jpg"    interpolate 2}}
//Material definitions
// Skin materials
// ...for the head
#declare TEX_HEAD      =texture{pigment{p_map3} normal{uv_mapping p_map4
bump_size 1} finish{phong 0.06 phong_size 25 diffuse 0.6 ambient rgb 0}}
#declare SkinScalp_1_  =TEX_HEAD
#declare SkinHead_1_   =TEX_HEAD
#declare Lips_1_       =TEX_HEAD
#declare EyeSocket_1_  =TEX_HEAD
#declare InnerMouth_1_ =TEX_HEAD
#declare Nostrils_1_   =TEX_HEAD
#declare Lacrimal_1_   =TEX_HEAD
#declare Tongue_1_     =TEX_HEAD
// ...for the teeth and gums
#declare TEX_TTHGUM    =texture{pigment{p_map5} finish{phong 0.06
#declare Teeth_1_      =TEX_TTHGUM
#declare Gums_1_       =TEX_TTHGUM
// ...for the body
#declare TEX_BODY      =texture{pigment{p_map1} normal{uv_mapping p_map2
#declare SkinNeck_1_   =TEX_BODY
#declare SkinTorso_1_  =TEX_BODY
#declare Nipples_1_    =TEX_BODY
#declare SkinArm_1_    =TEX_BODY
#declare SkinForearm_1_=TEX_BODY
#declare SkinHand_1_   =TEX_BODY
#declare Fingernails_1_=TEX_BODY
#declare SkinHip_1_    =TEX_BODY
#declare SkinThigh_1_  =TEX_BODY
#declare SkinKnee_1_   =TEX_BODY
#declare SkinShin_1_   =TEX_BODY
#declare SkinFeet_1_   =TEX_BODY
#declare Toenails_1_   =TEX_BODY
// Hair materials
#declare PubicHair_1_  =texture{pigment{color rgbt 1}}
#declare hair_1_1      =texture{pigment{p_map12} finish{diffuse 0.6
ambient rgb 0}}
#declare hair_1_2      =texture{pigment{color rgbt 1}}
#declare hair_1_       =texture{pigment_pattern{p_map13} texture_map{[0
hair_1_1][1 hair_1_2]}}
#declare Eyelashes_1_1 =texture{pigment{color rgb  <0.23,0.15,0.02>}
finish{diffuse 0.6 ambient rgb 0}}
#declare Eyelashes_1_2 =texture{pigment{color rgbt 1}}
#declare Eyelashes_1_  =texture{pigment_pattern{p_map14} texture_map{[0
Eyelashes_1_1][1 Eyelashes_1_2]}}
#declare Eyebrows_1_  =texture{pigment{color rgb <0.23,0.15,0.02>}
finish{phong 0 phong_size 25 diffuse 0.6 ambient rgb 0}}
// Eye materials
#declare LCornea_1_    =texture{pigment{color rgbt 1}
                     finish{phong 0.25 phong_size 37 diffuse 0.6 ambient
rgb 0 reflection{0.5}}}
#declare LEyewhite_1_  =texture{pigment{p_map6}
rgb 0 reflection{0}}}
#declare LPupil_1_     =texture{pigment{p_map6}
                     finish{phong 0    phong_size 44 diffuse 0.6 ambient
#declare LIris_1_      =texture{pigment{p_map6}
                     finish{phong 0.50 phong_size 44 diffuse 0.6 ambient
#declare RCornea_1_    =texture{pigment{color rgbt 1}
#declare REyewhite_1_  =texture{pigment{p_map7}
#declare RPupil_1_     =texture{pigment{p_map7}
#declare RIris_1_      =texture{pigment{p_map7}
// Clothing materials
#declare skirt_1_      =texture{pigment{color rgb <0.8,0.2,0.3>}
                       finish{phong 0.10 phong_size 15 diffuse 0.4
ambient rgb 0}}
#declare hem_1_        =texture{pigment{color rgb <0.8,0.2,0.3>}
ambient rgb 0}}
#declare belt_1_       =texture{pigment{color rgb <0.8,0.8,0.8>}
ambient rgb 0}}
#declare Leather_2_    =texture{pigment{p_map8}        normal{uv_mapping
p_map9  bump_size 1} finish{phong 1.00 phong_size 16 diffuse 0.3 ambient
rgb 0}}
#declare Leather_3_    =texture{pigment{p_map10}       normal{uv_mapping
p_map11 bump_size 1} finish{phong 1.00 phong_size 16 diffuse 0.6 ambient
rgb 0}}
#declare Cloth_2_      =texture{pigment{color rgb <0.10,0.07,0.00>}
                       finish{phong 0.10 phong_size 25 diffuse 0.6
ambient rgb 0}}
#declare Metal_2_      =texture{pigment{color rgb <0.15,0.07,0.00>}
finish{phong 1.00 phong_size 25 diffuse 0.6 ambient rgb 0 brilliance 6
reflection{0.8}}}
#declare Silver_3_     =texture{pigment{color rgb <0.06,0.06,0.06>}
finish{phong 1.00 phong_size 10 diffuse 0.6 ambient rgb 0 brilliance 6
reflection{0.8}}}
Tim Cook
Version: 3.12
Date: 12 Jan 2006 15:09:54
Message: <43c6b792$1@news.povray.org>
Tim Cook wrote:
> ...from an image on an imageboard, specifically
> http://img.kukaionline.com/egl/src/1127697699198.jpg ...mine's just a
> quickish doodle, threw together a few bits in Poser and rendered in
> POV...mine is kinda lame, needs work (especially on the pose of the
> arms, they look too Poser-y to me)...oh well.
Good start.  Shows how much you can do quickly with preexisting
components and that POV, while a "low level" interface, is a great
platform for supporting "high level" workflow too.
Date: 15 Jan 2006 04:25:19
Message: <43ca14ff@news.povray.org>
Hi Tim,
"Tim Cook" <z99### [at] bellsouthnet> schrieb im Newsbeitrag
news:43c58a93@news.povray.org...
I appreciate this nice work, especially the technique and the idea. If the
title of the picture is "I got an idea", then I would say, the girl looks a
little bit clueless. Maybe there could be done some work to the face and the
position of the arms?
C.B.
Date: 15 Jan 2006 12:11:58
Message: <43ca825e$1@news.povray.org>
The title of the picture isn't "I got an idea", it's just that, well...I
got an idea from another the image I linked to.  I liked the wings just
being visible in the shadow.  ^^
Tim Cook
Version: 3.12
