POV-Ray : Newsgroups : povray.binaries.images : Dome lights Server Time
2 Aug 2026 13:53:30 EDT (-0400)
  Dome lights (Message 11 to 17 of 17)
Subject: Re: Dome lights
Date: 20 Dec 2005 14:55:01
Message: <web.43a86066e93c309aed196ef10@news.povray.org>
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote:
> I got interested in m1j's post about "dome lighting" based on HDRI maps
(http://news.povray.org/povray.binaries.images/thread/%3Cweb.43912795ae23e4252f222b3b0%40news.povray.org%3E/)
> so I had a try at it (using my own code however, based on a geodesic dome
> macro I wrote many years ago) with impressive results.
> HDRI2a.jpg shows a scene using HDRI with radiosity lighting (medium-low
> quality settings though)
> HDRI2c.jpg shows the same scene using the dome lighting based on the HDRI
> (with a threshold limit)
> the rest use the dome lighting using different HDRI maps.  As a note, each
> took on average 10mins to render (no AA or rad)
> -tgq
A great example of photons!
Download 'building_g.jpg' (20 KB)
Preview of image 'building_g.jpg'
Date: 22 Dec 2005 01:12:54
Message: <43aa43e6@news.povray.org>
A sample from my latest work on this project.  DomeLight.jpg is the actual
image.  DomeLightEval.jpg is a secondary output from the macro that  allows
the scene and adjustments to be pre-evaluated.  The blue and red dots
represent where samples are taken, with red being above the threshold and
getting a light, and blue being below with no light.  You can see in certain
patches where the dots are much denser, this results from the adaptive
sampling option.  I will post the new code later when I'm a bit more
satisfied with it.
I ended up not doing subsampling for evaluating light sources as I found
that more often it would steal lights away than adding additional lights to
the scene.  I may end up adding a small scale subsampling only to average
the light colour/intensity of lightsources without adding or removing light
sources though if I like the looks of it.
-tgq
Download 'DomeLight.jpg' (38 KB) Download 'DomeLightEval.jpg' (169 KB)
Preview of image 'DomeLight.jpg'
Preview of image 'DomeLightEval.jpg'
Date: 24 Dec 2005 15:23:38
Message: <43adae4a$1@news.povray.org>
Wow
I am really impressed with the quality of the images you are producing
with this technique.  I have been doing a few google searches on
geodesic dome construction before attempting to code anything myself.
This is something I definately want to persue though once I have some
basic understanding.  Its been a while since I coded anything in POV so
I hope this spurs me on to creating something just as wonderful.
Quick question though.  I understand that the brightness of the lights
is adjusted based on the sample you take from the HDR image.  Do you
also sample the colour and adjust the light source colour based on this?
Keep up the GREAT work.
Dave.
Date: 26 Dec 2005 19:55:01
Message: <web.43b090b6e93c309a2f222b3b0@news.povray.org>
> satisfied with it.
> -tgq
Here are the last two sets of code I tried. Without photons My renders range
from 4 to 15 minutes. With photons it gets pushed closer to 30 to 50
minutes.
I am sure I could still improve this but I like your results and my use your
code instead.
#macro PSURFACE2(PS,U,V)
    #local W = 1 - U - V;
    #local u2 = U * U;
    #local u3 = u2 * U;
    #local v2 = V * V;
    #local v3 = v2 * V;
    #local w2 = W * W;
    #local w3 = w2 * W;
     (w3*PS[0] + (3*U*w2)*PS[1] + (3*u2*W)*PS[2] + u3*PS[3] + (3*w2*V)*PS[4]
+ (6*W*U*V)*PS[5] + (3*u2*V)*PS[6] + (3*W*v2)*PS[7] + (3*v2*U)*PS[8] +
v3*PS[9])
//light dome from image.
#macro
DOMELITE2(SP,YANGLE,MULT,CLIPV,THRES,LSAMPL,RAD,AREA,AS,LV,FNAME,FTYPE)
#switch(FTYPE )
  #case(0)
    #local PIMAGE = function {pigment{image_map {jpeg FNAME}}}//grab image
  #break
  #case(1)
    #local PIMAGE = function {pigment{image_map {png FNAME}}}//grab image
  #break
  #case(2)
    #version unofficial megapov 1.21;
    #local PIMAGE = function {pigment{image_map {hdr FNAME}}}//grab image
  #break
// #local PS = array[10]
{<0,RAD,0>,<RAD*0.6,RAD,0>,<RAD,RAD*0.6,0>,<RAD,0,0>,<0,RAD,RAD*0.6>,<RAD*0.6,RAD*0.6,RAD*0.6>,<RAD,0,RAD*0.6>,<0,RAD*0
.6,RAD>,<RAD*0.6,0,RAD>,<0,0,RAD>};
{<0,0,RAD>,<0,RAD*0.6,RAD>,<0,RAD,RAD*0.6>,<0,RAD,0>,<RAD*0.6,0,RAD>,<RAD*0.6,RAD*0.6,RAD*0.6>,<RAD*0.6,RAD,0>,<RAD,0,R
AD*0.6>,<RAD,RAD*0.6,0>,<RAD,0,0>};
 /*                         1           2                3              4
      5               6                          7               8
    9            10*/
#local Q = 0;
#while(Q < 4)
#local U = 0;
#while(U < 1-(1/SP))
  #local V = 0;
  #while(V < 1-U-(1/SP)/2)
    #local LLOC = PSURFACE2(PS,V,U);
    #local COL = PIMAGE(U/4+Q/4,V,0);///4+Q/4
        light_source{LLOC color (COL*MULT)
          #if(LV) looks_like{sphere{LLOC,RAD/SP pigment{color COL}
finish{ambient 1}}} #end
          #if(AREA) area_light  <AS, 0, 0> <0, 0, AS>   4, 4 adaptive 1
jitter  circular  orient  #end
          #if(COL.gray > 0.5) photons {refraction on reflection on} #end
          rotate y*(Q*90)
  #local V = V + 1/SP;
#local U = U + 1/SP;
#local Q = Q + 1;
Download 'building_j.jpg' (26 KB)
Preview of image 'building_j.jpg'
Date: 26 Dec 2005 20:10:00
Message: <web.43b0938ee93c309a2f222b3b0@news.povray.org>
Here is an example of the light distribution with my last set of code.
Download 'dlite1.jpg' (78 KB)
Preview of image 'dlite1.jpg'
Date: 4 Jan 2006 11:35:00
Message: <web.43bbf8c5e93c309a6c4803960@news.povray.org>
David Brickell <d.b### [at] nospamgmailcom> wrote:
> Wow
Thanks, not sure if its a true geodesic dome, I just created an algorithm
that subdivides a sphere into equal triangles to try to get an even spacing
Yes, the colour is sampled as well.  So if there is a predominant colour in
the image, it will show up in the lighting
-tgq
> Dave.
-tgq
Message: <web.43bbf92ae93c309a6c4803960@news.povray.org>
Looks like a nice even distribution, you should get better results with that
-tgq
