POV-Ray : Newsgroups : povray.binaries.images : Australia. Server Time
3 Aug 2026 19:09:43 EDT (-0400)
  Australia. (Message 18 to 27 of 27)
Subject: Re: Australia.
Date: 15 Nov 2005 02:11:40
Message: <43798a2c$1@news.povray.org>
Hmm, and it's 21600x21600 chunks, too...how do I make an isosurface that
applies an image as a radius modifier to a section of a sphere so that
the entire image maps to a 45x45-degree segment?
The code I have for the entire image to the whole sphere is
#include "functions.inc"
#declare fn_EarthPigm1=function{
   pigment{
     image_map{
       jpeg "srtm_ramp2.world.5400x2700.jpg"
       map_type 1
       once
       interpolate 4
#declare EarthIso=isosurface{
   function{f_sphere(x, y, z, 0.633)-(fn_EarthPigm1(x,y,z).red*0.006)}
   contained_by{sphere{0,0.7}}
   texture{pigment{rgb 1}}
   scale  <-1,1,1>
   rotate <90,0,-90>
...I'm guessing there's a way to apply fn_EarthPigm1 to only part of the
sphere?  But how?
Tim Cook
Version: 3.12
Date: 15 Nov 2005 03:04:18
Message: <dlc4j1$j5d$1@chho.imagico.de>
Tim Cook wrote:
> Hmm...well I guess I might be able to do it after all, then...HOLY CRAP
> the 500 m dataset is 65 GB?!
That's wrong.  One full data set is exactly 3x86400x43200=11197440000 bytes.
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 15 Nov 2005 03:09:18
Message: <dlc514$jbm$1@chho.imagico.de>
Just map it accordingly - using a mapping warp or manually using the
f_th()/f_ph() functions:
#local fn_Spherical=
   function {
     fn_Flat(1-(f_th(x,z,y)+pi)/(2*pi), f_ph(x,-z,y)/pi, 0)
Date: 15 Nov 2005 07:04:01
Message: <4379ceb1@news.povray.org>
> bytes.
Yes, but the complete dataset has one set for each month, plus
topography plus bathymetry...
Tim Cook
Version: 3.12
Date: 15 Nov 2005 08:00:54
Message: <4379dc06$1@news.povray.org>
Trying out the mapping warp on the texture to get a feel for the method,
but not sure how to make the image occupy a different sector of the
sphere... warp{spherical orientation z dist_exp 1} scale <-0.5,0.5,0.5>
rotate 90*x gives a segment from 90 degrees 'south' to the 'equator',
and 0 to 180 degrees 'west'...changing the rotation only changes the
position of that wedge, and I want to have the image occupy, for
instance, 0 degrees to 45 degrees north and 90 degrees to 135 degrees
west.  The documentation doesn't seem to elaborate on this aspect.
Tim Cook
Version: 3.12
Date: 15 Nov 2005 08:21:45
Message: <4379e0e9$1@news.povray.org>
Tim Cook wrote:
> Her's the Earth, looking at Australia.
Ah, there it is!
Sebastian
Date: 15 Nov 2005 11:11:21
Message: <437a08a9$1@news.povray.org>
Wa ha, figured it out...use translate before the warp.  :3
Tim Cook
Version: 3.12
Date: 15 Nov 2005 13:00:00
Message: <web.437a20d8f94adb4dd61e8c370@news.povray.org>
Funny,
I'm going to leave the discussion topic a bit, but
just by chance I downloaded the 8km/pixel file of July before I read this
thread. And as all these Blue Marble pictures are Mercator projections, I
thought it was a good idea to...
Well, two continents one thought...
The original satellite image was more a _Black_ Marble to me, so I made it a
bit lighter (Photopaint).
But when I saw your image I thought: "Hey let's give the NZers a chance!",
and changed from my home coordinates:
       // Latitude
       //rotate 9.93948843330146 * y  // East is Plus
       // Longitude
       //rotate -53.584204427898 * x  // North is Minus
To the coords of Christchurch
        rotate (-90 + 172.66) * y
        rotate 43.5 * x
But anyway, I've got two questions:
These deep sea trenches west of Australia won't show up. Did you made them
afterwards?
And how did you do the athmosperic rim - a second sphere filled with media?
Yours,
Bu.
Download 'nzers.jpg' (30 KB)
Preview of image 'nzers.jpg'
Date: 15 Nov 2005 13:54:03
Message: <437a2ecb@news.povray.org>
They're not Mercator projections, they're spherical.  (Mercator
projections are progressively distorted vertically as you approach the
poles, and approach infinity at the poles themselves.)
> afterwards?
I made a second function of the bathymetric data and added that to the
earth isosurface, where the function with the topography is subtracted,
since they're two files each with a full 256 shades of grey and it's a
shame to not use that full amount by trying to combine the two images
into one, which would reduce the vertical resolution by half.
Yep.  I outline the important particulars in my 'not oops' post dated
2005-11-10 08:53.
Tim Cook
Version: 3.12
Date: 18 Nov 2005 11:40:13
Message: <ch1v43-d22.ln1@badulaque.unex.es>
Among other things, Tim Cook saw fit to write:
Some time ago, before this new Blue Marble appeared, I got a full
bathymetric and elevation data file frome somewhere (I don't remember the
URL or the resolution, but it was acceptable[*]). The original data was a
binary no-header 16-bit file, which I converted to pgm with some effort
(involving using sox for getting the correct byte ending), as at that time
POV-Ray didn't support reading 16-bit PNG files... This all goes to say
that you can in theory combine everything in a 16-bit file without losing
resolution, or even get the whole thing with higher resolution.
[*] I may have the file somewhere and could put it in a server if someone is
interested.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
