POV-Ray : Newsgroups : povray.binaries.images : Elements Server Time
3 Aug 2026 19:09:43 EDT (-0400)
  Elements (Message 11 to 18 of 18)
Subject: Re: Elements
Date: 10 Nov 2005 13:09:01
Message: <43738cbd$1@news.povray.org>
"Orchid XP v2" <voi### [at] devnull> wrote in message
news:43732846$1@news.povray.org...
> The wood doesn't seem to be on fire, despite being surrounded by it. And
> the flames don't seem to cast any light on the surrounding rocks. But
> other than that...
The lack of light is probably accurate, in fact the flames are brighter than
they should be. I have full radiosity in the scene so if you can't see
lighting from the flames it's because they're so much darker than the sun.
In fact I've actually cheated an made the flames brighter than they should
be in daylight (I looked at some photos of flames).
> Actually, that's the best CG flames I've ever seen. How did you do that?
Emissive media with a little absorption, granite pattern with some
turbulence for the density, modulated by a spherical pattern. Then a couple
of adjustments to the pattern to give a very sudden change in density from
outside the flame to inside. Then tweak all the parameters until it looks
right. The source code makes it look pretty complex but all those nested
pigment_patterns are just to control the boundary between inside and outside
the flame.
Tek
http://evilsuperbrain.com
Date: 11 Nov 2005 06:47:47
Message: <437484e3$1@news.povray.org>
> the flame.
...so fundamentally, it's granite and turbulence?
(I just couldn't think of a pattern that looks flame-like, that's all.)
Date: 11 Nov 2005 10:53:16
Message: <aq5e43-d1f.ln1@badulaque.unex.es>
Among other things, Tek saw fit to write:
> So, I submit it to you folks as a curiosity. Fool your friends, be the
> life of the party, etc.
> Comments/critiques welcome.
Very nice, it has some kind of Myst/Riven flavour...
My only comment is that there seem to be a couple of black spots in the
stones, and there are some bright pixels in the beach areas of the left
edge. Also, maybe a very faint smudge of cloud somewhere could add a bit
of atmosphere, not that the image needs it much, though.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 11 Nov 2005 18:13:37
Message: <437525a1@news.povray.org>
Amazing work. One of the most pleasing things I've seen in a long time.
Compositionally, it has both elements of stylization (what a boring waste to
do actual realism), but shows a lot of deference to the physics of
plausible-universe (if not our planet) landscapes.
Date: 11 Nov 2005 23:41:26
Message: <43757276$1@news.povray.org>
news:437484e3$1@news.povray.org...
Yeah basically, though you can get stuff that doesn't look at all like fire
if you just use granite and turbulence, hence all the extra info :)
Oh, and it's low frequency turbulence (2 octaves I think). That's important.
Tek
Date: 11 Nov 2005 23:48:19
Message: <43757413$1@news.povray.org>
Those black spots look dark brown on my monitor, and they're intentional,
just imperfections in the stone. The bright pixels are some kinda wierd
error that I couldn't track down.
The cloud's a nice suggestion, I'll try it if I work on the image some more.
Tek
"Jellby" <me### [at] privacynet> wrote in message
news:aq5### [at] badulaqueunexes...
Date: 14 Nov 2005 15:19:28
Message: <4378f150$1@news.povray.org>
Bet it doesn't look flamey when animated. ;-)
Date: 15 Nov 2005 12:24:45
Message: <437a19dd$1@news.povray.org>
news:4378f150$1@news.povray.org...
You know, if I were bored and had nothing better to do with my free time,
I'd prove you wrong.
(have a look at p.b.a)
Tek
