POV-Ray : Newsgroups : povray.binaries.images : MegaLOGOmaniac Server Time
3 Aug 2026 19:09:43 EDT (-0400)
  MegaLOGOmaniac (Message 11 to 14 of 14)
Subject: Re: MegaLOGOmaniac
Date: 27 Oct 2005 15:40:00
Message: <web.43612ce7e4e76d83e45da7f10@news.povray.org>
LightBeam <lig### [at] tiscalifr> wrote:
> Created and exported with inkscape (www.inkscape.org)... Inkscapes can
> exports splines to povray.
> HDRI "invoked" with experimental feature named radiosity.
Very cool picture. I had just been on the hunt for a good, free vector
graphic program, and was satisfied with Sodi Podi. Now I'll have to give
this one a try...
Again, awesome picture, and thanks for the tip! :P
Date: 27 Oct 2005 16:24:54
Message: <43613796$1@news.povray.org>
> Inkscape can exports splines to povray.
Seriously?
You learn something every day...
(I've used Inkscape for a while now, but never found that particular
"feature".)
Date: 27 Oct 2005 16:29:11
Message: <43613897$1@news.povray.org>
> "feature".)
That (exporting to POV) should be more like reason to exist than just a
"feature" ;).
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 27 Oct 2005 16:57:58
Message: <pan.2005.10.27.20.57.58.2133@nospam.com>
> Seriously?
Yeah, I've been playing with it a little bit right the last couple of days
in conjunction with "trace bitmap" for a project I've been toying with off
and on for work, "save as" has this as an option.
So far the results are pretty good, though the "trace bitmap"
functionality leaves gaps after I fiddle with the different resultant
layers a bit to get rid of some undesired artifacts; the preliminary test
results look pretty good, especially with partial transparency (something
I need) and the layers.
Part of the problem with my bitmap trace is that the bitmaps are
relatively small.  What I need is eps versions of what I'm working with to
start with.
Jim
