POV-Ray : Newsgroups : povray.binaries.images : Black Pearl (no, not a sailing ship!) Server Time
10 May 2026 09:16:27 EDT (-0400)
  Black Pearl (no, not a sailing ship!) (Message 1 to 10 of 14)
Subject: Black Pearl (no, not a sailing ship!)
Date: 20 Oct 2005 10:46:55
Message: <4357addf$1@news.povray.org>
Watching a game show on TV the other night, I saw this great piece of
jewellery: A black pearl set with diamonds. So I decided it was a good
time to play with photons. However I'm not sure where to go, so I beg
for help.
The image following has photons set with this:
photons {
	count 20000
	autostop 0
	jitter .4
	save_file "photons-save-load.pho"
However it's all too bright. The diamonds look like they're emitting a
ton of light. How do I reduce the light so it looks real?
Cheers!
Rick Measham
Subject: Re: Black Pearl (no, not a sailing ship!)
Date: 20 Oct 2005 10:49:24
Message: <4357ae74@news.povray.org>
Strange .. there's no image .. posting again ...
Download 'blackpearl.jpg' (15 KB)
Preview of image 'blackpearl.jpg'
Date: 20 Oct 2005 14:53:15
Message: <4357e79b$1@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:4357ae74@news.povray.org...
    Are you sure it was a black pearl the diamonds were set into? If so,
then I would expect a thin gold setting around the diamond to hold the
diamond securely. If not, then they are probably Cubic Zirconia's, and glued
in. I even doubt the latter, because no-one would glue a CZ into a black
pearl - they're just too expensive for CZ's. (Perhaps you saw a black
enamelled piece with diamonds - which would make more sense?)
     Nice start though. How are you going to get the lustre/sheen of a
(black) pearl?
      ~Steve~
Date: 20 Oct 2005 15:15:01
Message: <web.4357eb9145d6fa383aadfdc90@news.povray.org>
How about a layered, Pearlescent type of texture for the pearl?
Alter the pigments and play with the specular and transmit values on the for
nice effects.
Results in nice pearlescent paint as well.
  #declare Rmin=.1;
  #declare Rmax=.33;
  #declare T_inner=White; #declare T_outer=Black;
   //#declare T_inner=White; #declare T_outer=Black;
   //#declare T_inner=Black; #declare T_outer=White;
   //#declare T_inner=Blue*0.3; #declare T_outer=Red*0.0+Green*0.9+Blue*0.9;
   //#declare c1=Red*0.5; #declare c2=Red*0.9+Green*0.9+Blue*0.0;
  #declare T_Layers=
  texture{
    pigment{rgb T_inner}
    finish{specular 2 metallic roughness .1 brilliance 10}
  texture{
    pigment{rgb T_outer transmit .33}
    finish{
    specular 1 roughness .0125 diffuse 1-rmax reflection{Rmin,Rmax}
conserve_energy
Date: 20 Oct 2005 18:47:12
Message: <43581e70@news.povray.org>
> diamond securely.
I assume there was a thin gold setting then .. as the piece was worth
half a small fortune!
Thanks!
Rick Measham
Date: 21 Oct 2005 02:10:00
Message: <web.4358851445d6fa38c00443f50@news.povray.org>
> > diamond securely.
> Thanks!
> Rick Measham
Rick, how is the ambient_light's value? its may be zero..
Hasan.
Date: 21 Oct 2005 02:42:25
Message: <43588dd1@news.povray.org>
OK, here's the latest version ..
Q: How do I give an idea of the scale?
Notes:
- I've used/changed the texture provided by 'ts'
- I've changed the light to an area_light (always intended)
- I've turned off radiosity .. don't think it's really needed
- I've turned off the photons .. I like it already :)
Thoughts/Comments/Suggestions always welcome. Source available on request.
Cheers!
Rick Measham
Download 'blackpearl.jpg' (22 KB)
Date: 21 Oct 2005 04:10:46
Message: <20051021091059.6372b50a@dh286.pem.cam.ac.uk>
You could put it against a wooden surface with an appropriate grain, or
have a macroscopic background (maybe of a room you have done in the
past) heavily focus-blurred. You could attach a slender chain or thread
to it, or have some visible skin near it (a finger, a neck) if you are
feeling like spending a lot of time on the background.
But like the blackbird on the wire    And like the blackbird on the wire
I will not take the prey on you    [ surreal ]       I just watch you by
You wouldn't want me to            [ .istic. ]  The tears I knew I'd cry
For I am too soft for such a thing [   org   ] Fall unnoticed down below
Date: 21 Oct 2005 05:15:01
Message: <web.4358b06845d6fa38dc45bc820@news.povray.org>
you could just hang it from an ear, like the girl with a pearl earring in
this year's POVCOMP.
Now we can see the pink diamonds it's clear why it would be so expensiVe!
I would expect a black pearl to have an iridescent surface, and may be some
irregularity of shape.
Joanne
http://www.onewhiteraven.com
Date: 21 Oct 2005 12:45:01
Message: <web.43591aed45d6fa38cb16d5100@news.povray.org>
> Rick Measham wrote:
> Notes:
i may have messed up on that code Rick ...
try the following instead ...
playing with the variable "Trans" to tweak the transparency.
//------- Pearlescent Texture -----------
#declare Rmin=.1;
#declare Rmax=.33;
#declare Trans=.5; //Alter transmission of outer texture
#declare T_inner=White; #declare T_outer=Black; // *****
//#declare T_inner=Silver; #declare T_outer=Black;
//#declare T_inner=Yellow; #declare T_outer=Red; //easier to see the results
in color
#declare TOpal=
    texture{pigment{rgb T_inner} finish{specular 1 metallic roughness .1
brilliance 25}}
    texture{pigment{rgb T_outer transmit Trans}
      finish{specular 1 roughness .0125 diffuse 1-Rmax reflection{Rmin,Rmax}
conserve_energy}
The attached file shows the results of using White as the inner
texture and transparent Black as the outer ...
the upper left sphere being the inner texture alone ...
then with Black at 0.9 transmit, 0.8 going left to right ...
the 2nd row down 0.7, 0.6, 0.5 ... ect all the way to 0 transparency
bottom center.
It may be easier to see if you uncomment the Yellow/Red pigment line above
and of course one can use Silver or even one of the Metal textures for
the inner.
I haven't tried adding a bump normal ...
not sure one can with layer textures.
and suggestions in that area would be appreciated.
> Cheers!
> Rick Measham
sure ... please do post the source ...
I never have done well using diamonds so ...
would appreciate if you could point me in the right direction.
-ts-
Download 'blackpearl.jpg' (87 KB)
