POV-Ray : Newsgroups : povray.binaries.images : Black Pearl (no, not a sailing ship!) Server Time
3 Aug 2026 19:51:13 EDT (-0400)
  Black Pearl (no, not a sailing ship!) (Message 11 to 14 of 14)
Subject: Re: Black Pearl (no, not a sailing ship!)
Date: 21 Oct 2005 12:54:01
Message: <43591d29@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:43588dd1@news.povray.org
  Much, much better. Try changing to a darker colour, 'black pearl' means
black pearl. Also, when I said there would be a gold rim around the stone to
hold it, it would probably be white gold, or, if it's that expensive,
platinum, (a bright-white colour - chrome would suffice).
     You need to work on the eyelet too - there wouldn't be a gap...  ;)
    As for scale, put them, (a pair, as earrings, or one as a pendant), in a
presentation box on a table.
    I'll also go with Joannes input that there should be slight
irregularities here and there, (small bumps etc.)
     ~Steve~
Date: 21 Oct 2005 12:58:40
Message: <43591e40@news.povray.org>
"St." <dot### [at] dotcom> wrote in message news:43591d29@news.povray.org...
   Ah, there you go, ts got it right with that last pearl texture. Nice one
ts! :)
    ~Steve~
Date: 21 Oct 2005 22:01:20
Message: <43599d70@news.povray.org>
ts wrote:
> i may have messed up on that code Rick ...
> try the following instead ...
> playing with the variable "Trans" to tweak the transparency.
Closer, closer, ever closer... thanks ts!
Clasp is getting closer too.
Cheers!
Rick Measham
Download 'blackpearl.jpg' (34 KB)
Preview of image 'blackpearl.jpg'
Date: 22 Oct 2005 00:25:00
Message: <web.4359bde945d6fa38f0d571b50@news.povray.org>
> Cheers!
> Rick Measham
yes.
although, with zero transmit ...
you are going to miss out on the translucence ...
because then the interior layer is not seen at all.
so perhaps using a somewhat less white underlayer ...
along with playing with the specular ...
will allow you to use at least some transparency
in the black outer texture.
also ... in my example there is nothing for the
pearl to reflect ... whereas in yours, there are
lighter things which will also lighten the surface.
so you may want to lower the reflection of that
outer texure as well.
i have found that the lighting, skysphere and even
background greatly alter the effect precisely because
they do get reflected. no problem  except when you
want black. ;)
so it takes a lot of tweaking and fine tuning for
any other changes you make in the scene.
if you want to emphisize the 'black' of the pearl ...
you will have to minimize what is there for it
to reflect.
looking good.
-ts-
