POV-Ray : Newsgroups : povray.binaries.images : Prepared 4 company: The ice age cometh (WIP 2) Server Time
25 Aug 2025 19:04:28 EDT (-0400)
  Prepared 4 company: The ice age cometh (WIP 2) (Message 1 to 10 of 10)
Subject: Prepared 4 company: The ice age cometh (WIP 2)
Date: 2 Oct 2005 05:17:27
Message: <433fa5a7@news.povray.org>
Here is the next version of my interpretation of Tim Nikias' room. This
image is rendered without radiosity (see below).
Changes have been made to:
- finish/diffuse of the background image to make it slightly brighter.
- wall and ceiling textures; blending more the different colors, adding a
crackle pattern and tweaking the normals.
- texture of the crates; different wood textures underlying the paint.
- a stove in the corner; I googled a barrel stove from Alaska that exactly
fitted my needs, and modelled it in Moray and Silo before exporting it to
POV-Ray through PoseRay. I used two image_maps provided by Nicolas Rougier
for his Chain in this ng, that perfectly fitted the stove.
I experimented with photons to see if some caustics would be reflected on
the ceiling, but results were unconclusive, so I left it for the time being.
I still have to do something about the glass in the windows.
And then radiosity:
I noted that Tim used two different render sizes: a smaller one for the
gathering pass, and a larger one for the second pass. I was wondering how
much the two sizes could differ. A small size for gathering radiosity data
is faster, but to what degree can you then use that data in a final larger
render, e.g. 320x240 for the gathering pass and 800x600 for the final pass?
I could not find info about this in the docs. The point is important to me
because I have a slow computer, I have to increase count substantially to
diminish color banding which tend to hide the more subtle wall texture, and
I encountered some memory problems. All in all, the gathering pass takes
several hours on my machine.
Like always, comments welcome!!
Download 'windows_room_03.jpg' (86 KB)
Preview of image 'windows_room_03.jpg'
Subject: Re: Prepared 4 company: The ice age cometh (WIP 2)
Date: 3 Oct 2005 04:13:45
Message: <4340e839@news.povray.org>
The ice looks very very realistic. How did you make it? Isosurface? Perhaps
an hdri photo? Your drawing reminds me the Gold Rush of Chaplin!
Friendly
433fa5a7@news.povray.org...
> being.
> And then radiosity:
> pass?
> and
> Thomas
Date: 3 Oct 2005 08:55:44
Message: <43412a50@news.povray.org>
"Remy Closset" <rem### [at] tiscalifr> schreef in bericht
news:4340e839@news.povray.org...
> Thomas
Perhaps
original scene from which this is a variation (see the tread of 21-9-2005
for the first version).
The Gold Rush! Yes! I remember though, that Chaplin had 'real' furniture in
his log cabin, hadn't he?
Date: 3 Oct 2005 09:29:53
Message: <43413251$1@news.povray.org>
I like it!
Maybe you should try to add some normals to the wooden crates, as to
simulate a change in depth between painted and unpainted regions. I'd also
go for a rusty spot on the ceiling, where the stove is.
And I'd try to use some no_shadow-lightsources with fade_power in order to
create more contrast in the shadowed parts of the image. They look
"depthless" as it is now.
And have you thought about adding some icy crust to the edges of the
windows?
Tim
"Tim Nikias v2.0"
Date: 4 Oct 2005 03:44:49
Message: <434232f1@news.povray.org>
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> schreef in
bericht news:43413251$1@news.povray.org...
> I like it!
> windows?
Thank you Tim!
Yes, the crates need some extra normals. I shall look into that, as also
into the shadow lights. I agree that this is still not satisfactory. In the
present image there are two shadowless lights (one is your original one, the
other is a very feeble one at the camera location), but htey lack fade_power
yet.
Yes, still have to work on the windows!!!
Do you have an idea about my radiosity question? My latest esperiment,
yesterday, was not really satisfying for the aspect of the walls.
Date: 6 Oct 2005 03:01:37
Message: <4344cbd1$1@news.povray.org>
> windows?
I have just done this for the round window (spherical color_map). It looks
good, except for the thickness of the glass which becomes visible as the
texture is applied to both sides of the cylinder. I shall have to reduce the
thickness to make it less conspicuous.
Date: 6 Oct 2005 04:14:42
Message: <4344dcf2@news.povray.org>
the
Hm. Is frost always on both sides? I remember that I'd often have frost on
the inside of my windows, because of the moisture in the air due to my
breath, or outside because of fog or such...
Dunno, but less thick windows might be a good move as well, just wanted to
voice a comment. :-)
"Tim Nikias v2.0"
Subject: Re: Prepared 4 company: The ice age cometh (WIP 3)
Date: 6 Oct 2005 10:58:51
Message: <43453bab@news.povray.org>
bericht news:4344dcf2@news.povray.org...
No, frost is not (necessarily) on both sides, but this was an effect of the
cylindrical color_map. I solved it easily by adding an extra layer (very
thin cylinder or box) to the outside of the windows (kept their thickness).
See the image below.
Also added a soot stain on the ceiling around the chimney (also a
cylindrical color_map).
I added some normals to the paint on the crates
Finally, I commented out the shadowless on one of the extra lights inside
the room and added fade and fade_power. This gives a better view (although
with some shadows) than my experiments with radiosity.
Download 'windows_room_04.jpg' (85 KB)
Preview of image 'windows_room_04.jpg'
Date: 6 Oct 2005 11:06:11
Message: <43453d63$1@news.povray.org>
I like it, the lighting has improved significantly with more contrast. You
should work a little more on the frost, but I guess that the current version
is just preliminary. Often, you can still see through the frost, and the
edge is always as hard as you've made it.
Apart of that, have you tried getting the paint to appear thicker than the
wood beneath using normals? It seems like they have some grain now, which is
fine, but there's still no discernable edge between paint and wood.
Tim
"Tim Nikias v2.0"
Date: 7 Oct 2005 04:08:59
Message: <43462d1b@news.povray.org>
bericht news:43453d63$1@news.povray.org...
version
is
Yes the frost is preliminary. It is rather tricky to control its shape,
especially on the rectangular windows, as it is the combination of color_map
index and turbulence that does the trick. Yes, it is still too opaque. I
gave it some small transmit value but I want to experiment with higher ones
and with filter values.
The paint: I think The problem lies in the final texture_map of  Tim
McMurdo's macro that I have worked on for this scene. There is probably to
much fading from the paint texture to the wood texture, giving a kind of
rubbed-off or eroded look to the object. But in this case, the edges should
be sharper indeed, showing flacking paint instead. I think this is easy to
implement.
Thanks indeed for your comment, btw! They are very helpful and keep me on my
toes, sts  :-)
