POV-Ray : Newsgroups : povray.binaries.images : Frontpage text Server Time
3 Aug 2026 20:59:41 EDT (-0400)
  Frontpage text (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Frontpage text
Date: 16 Sep 2005 17:55:41
Message: <432b3f5d@news.povray.org>
> can't read the text.
   Screen's too dark.
Date: 16 Sep 2005 18:04:49
Message: <432b4181$1@news.povray.org>
Eero Ahonen nous apporta ses lumieres en ce 2005-09-16 16:25:
> Skip Talbot wrote:
>> Very unique and eye catching design.  One thing I can suggest though
>> is that the text should stand out more from the black background.
>> Perhaps you could increase the light intensity to make the text brighter.
> This actually is my usual problem. I'm using very dark monitor
> (brightness set to 0), but with extreme contrast (set to full) - so
> alltough everything is dark, the different shades of black (and colors,
> especially) are visible. And when I create graphics which look nice
> here, they are usually way too dark everywhere else.
>> I have no idea how you are desiging the webpage or what layout you are
>> using, but at this current resolution/size it may be a bit big for
>> most webpages.  I found that smoothly integrating 3D text into
>> websites can be rather difficult, which is why I usually stick with 2D
>> text for most of my projects.  Looks good so far though.
> If you'll check the site (http://www.zbxt.net), you'll see that there's
> a "zbxt" -image on frontpage that changes (actually, it's randomized
> when you load the page). The goal is to have the image same-sized as the
> old ones (right now the image is rendered 800x600 and I cropped it) and
> small (bytes, I mean here, to get it quick-loading). Site itself is
> using basic text for all actual information.
>> Skip
My monitor is set at brightness 48% and contrast 100%, and I can barely see that there
is something
looking like it may be some text!
Date: 16 Sep 2005 21:00:55
Message: <432b6ac7$1@news.povray.org>
I suggest you re-think how you're making your images.  Your website is
totally illegible as well.  All I can see is a totally black screen with
a few meaningless dark smudges on it.  (Except for the straight-text
links -- people/hardware/etc...)
      -=- Larry -=-
Date: 17 Sep 2005 03:02:57
Message: <432bbfa1$1@news.povray.org>
>> colors, especially) are visible. And when I create graphics which look
>> nice here, they are usually way too dark everywhere else.
>      -=- Larry -=-
Umh, image really THAT dark? There has to be something mystical either
with my monitor or with my eyes... It has to be with my eyes actually,
'cause I keep all monitors usually as dark as possible (and I like it -
and I see it clearly).
But hmh, you can't see the texts behind those links? Normal text is a
bit darker than a link, but IMO it should be fully readable by anyone
(color is #bbbbbb). The Raytracing -department "might be" "a bit" dark;
maybe part of the Photography, too?
Eero "Aero" Ahonen
    http://www.zbxt.net
Date: 17 Sep 2005 11:07:49
Message: <432c3145$1@news.povray.org>
Eero Ahonen nous apporta ses lumieres en ce 2005-09-17 03:02:
>>> look nice here, they are usually way too dark everywhere else.
>> with a few meaningless dark smudges on it.  (Except for the
>> straight-text links -- people/hardware/etc...)
>>      -=- Larry -=-
The raytracing section IS VERY dark! I have to crank up the brightness of monitor
almost to the max.
Some tumbnails are so dark, I have to hit ctrl-A to realise that there IS something
there...
I've done a render of "life" and realised that there is a textured ground and
non-black background
by going trough the code.
Date: 19 Sep 2005 06:53:33
Message: <432e98ad$1@news.povray.org>
Can you make out the difference between all of these on your monitor?
http://www.dpreview.com/images/grayscale.gif
Date: 19 Sep 2005 11:46:33
Message: <432edd59$1@news.povray.org>
The favicon of that site has an uncanny resemblance to the POV-Ray logo.
Date: 19 Sep 2005 17:06:36
Message: <432f285c$1@news.povray.org>
For me it's hard to see the difference of Y and Z. Guess my monitor is
se to too dark (brightness 0%) :p.
Eero "Aero" Ahonen
   http://www.zbxt.net
Date: 19 Sep 2005 18:11:54
Message: <432f37aa$1@news.povray.org>
"scott" <sco### [at] spamcom> wrote in message news:432e98ad$1@news.povray.org...
I can see a difference between all rectangles, but only if that image is the
only thing on my monitor :)
(but I have a quite bright windows-theme)
cu!
Date: 5 Oct 2005 20:16:13
Message: <43446ccd$1@news.povray.org>
As a suggestion you should try to find an ICM for your monitor
that adjusts the screen so that it reflects the actual output.
In printshops and other places this is very important.
You just load it somewhere under the properties.
Look it up :)
Stefan
"Eero Ahonen" <aer### [at] removethiszbxtnetinvalid> skrev i meddelandet
news:432b2a41$1@news.povray.org...
> Skip Talbot wrote:
>> Very unique and eye catching design.  One thing I can suggest though is
>> that the text should stand out more from the black background.  Perhaps
> This actually is my usual problem. I'm using very dark monitor (brightness
> set to 0), but with extreme contrast (set to full) - so alltough
> everything is dark, the different shades of black (and colors, especially)
> are visible. And when I create graphics which look nice here, they are
>> using, but at this current resolution/size it may be a bit big for most
>> webpages.  I found that smoothly integrating 3D text into websites can be
>> rather difficult, which is why I usually stick with 2D text for most of
> If you'll check the site (http://www.zbxt.net), you'll see that there's a
> "zbxt" -image on frontpage that changes (actually, it's randomized when
> you load the page). The goal is to have the image same-sized as the old
> ones (right now the image is rendered 800x600 and I cropped it) and small
> (bytes, I mean here, to get it quick-loading). Site itself is using basic
>> Skip
> Eero "Aero" Ahonen
>    http://www.zbxt.net
