POV-Ray : Newsgroups : povray.binaries.images : Kepler Solar System - Take 5 [~165 kB] Server Time
3 Aug 2026 23:26:47 EDT (-0400)
  Kepler Solar System - Take 5 [~165 kB] (Message 11 to 20 of 36)
Subject: Re: Kepler Solar System - Take 5 [~165 kB]
Date: 12 Aug 2005 06:10:01
Message: <web.42fc73a5b9d4c122ba8a7c6f0@news.povray.org>
Here is a 3D view of the Kepler Solar System. This image was generated using
StereoPOV, which unfortunately rotates the camera around the vertical axis,
rather than just panning horizontally.
To view .jps and .pns files get the DepthCharge plugin for Internet Explorer
from
http://www.vrex.com/depthcharge/
or for .jps files, the Stereoscope Java Applet by Andreas Petersik from
http://www.stereofoto.de/sapplet/index.html
Download 'keplertesta1s.jps.jpg' (127 KB)
Preview of image 'keplertesta1s.jps.jpg'
Date: 12 Aug 2005 06:20:00
Message: <web.42fc75e9b9d4c122ba8a7c6f0@news.povray.org>
Here's another 3D view of the Kepler Solar System, using more
anaglyph-friendly colours, and generated using POV-Ray 3.6.
Download 'keplertestb1.jps.jpg' (135 KB)
Preview of image 'keplertestb1.jps.jpg'
Date: 12 Aug 2005 09:38:31
Message: <42fca657@news.povray.org>
"EagleSun" <nomail@nomail> schreef in bericht
news:web.42fb46d9b9d4c122841337530@news.povray.org...
> Wow!
> Cool!
> What is it?  What's Kepler model?
Thank you!
Kepler's model is/was his idea of the solar system, based on the harmonic
measures of Euclidean primitives. The object you see is based on an
engraving that was published in his book on the subject.
> Having so many objects makes the scene believable.... must have been hard
> work putting in all those objects and aligning them exactly in place.....
> I'm having a tough time already picking up real objects in my room and
> putting them in right place... such a time-consuming event.
Not so hard to place them as this scene was built in Moray. You see exactly
what you do... except that I have also pure POV-ray objects imported, and
that is somewhat harder. But there are a couple of plugins around that makes
work easy.
> And how do you post more than 1 picture?
Well, you can attach as many files as you want, like in an e-mail. I
currently use MS explorer for my mail and newsgroup work, and it works fine.
Date: 15 Aug 2005 03:13:44
Message: <430040a8@news.povray.org>
"PM 2Ring" <nomail@nomail> schreef in bericht
news:web.42fb01f3b9d4c122ad93754b0@news.povray.org...
> "PM 2Ring" <nomail@nomail> wrote:
> It's all working now. I'm using a simple B&W checker floor. I've done some
> preliminary 3D renders, but I had to modify the brass colour used for the
> planetary polyhedra so it looks ok as an anaglyph. I would have posted a
> preview, but I've has ISP problems for the past 3 days. With luck, I'll be
> able to upload an image or two tonight when I get home.
I have not been able to get the stereoscope working. I don't know why. I
tried to change directories for the .bat but no results.
I am experimenting now instead with Joerg Schrammel's JAC. Not conclusive
yet, but I am working on it.
Date: 15 Aug 2005 03:40:00
Message: <web.430045bab9d4c122ad93754b0@news.povray.org>
> Thomas
If you like, I'll upload a small Web page setup with Petersik's stereoscope
applet. Or if worse comes to worse, I can convert the pics to anaglyphs.
I also discovered a free Stereoscopic slideshow prog, but its Windows only.
(I assume the problem is you aren't using Windows/Internet Explorer).
Date: 15 Aug 2005 09:14:11
Message: <43009523@news.povray.org>
news:web.430045bab9d4c122ad93754b0@news.povray.org...
stereoscope
only.
Thanks!!!
I am using IE, but still version 5, because I have never been able to
upgrade to version 6 (just freezes slowly during installation and stops
altogether. No help from MS); and I use Firefox mostly nowadays. All under
WinME (will upgrade when I change my PC someday in the future...).
After some trials, I think I shall have an acceptable anaglyph picture ready
tomorrow.
Date: 15 Aug 2005 12:29:02
Message: <4300c2ce$1@news.povray.org>
Cross your eyes hard, then slowly relax until the middle pair merge.
Then relax the focus and you'll see it in stereo.
It's probably easier to practice with a simpler picture, like a line
drawing of a hypercube projection or so.
I'm not sure what the software is supposed to do to it?
"You're going to be late for your meeting."
      "That's OK. I can be late."
"What's it about?"
      "Someone else's problems."
Date: 15 Aug 2005 13:19:01
Message: <4300ce85$1@news.povray.org>
I had good luck with this (for the first time) today.
I held a pencil up about half way between my eyes and the screen, on the
line between the two pictures.  When I looked at the pencil I noticed a
small slice of "overlap" picture appeared.  By moving the pencil (in my
case towards me) I was able to enlarge this center image until it was
full size.  Once I had it I was able to slip the pencil down and enjoy
the image.
Which is very cool by the way.  Nice work!
Date: 16 Aug 2005 03:46:32
Message: <430199d8$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> schreef in bericht
news:4300c2ce$1@news.povray.org...
I know the technique, the point is that I have not even been able to get an
image on my screen! :-(
Date: 16 Aug 2005 05:22:37
Message: <4301b05d@news.povray.org>
Just my stupidity!!! :-(
Just discovered that I could open the jps files with PaintShopPro! I thought
I needed the software...
Well...crossing my eyes... I was fairly good at that when I worked with
aereal photographs... Gave me headaches too...
Ok, have to try again.
