POV-Ray : Newsgroups : povray.binaries.images : bug or am I silly? Server Time
13 Jul 2026 08:49:15 EDT (-0400)
  bug or am I silly? (Message 11 to 14 of 14)
Subject: Re: bug or am I silly?
Date: 1 Aug 2005 03:44:52
Message: <42edd2f4@news.povray.org>
Hall wrote:
> using pov-ray 3.6.1 for windows on windows XP...
> Should I be seeing the banding produced in this minimal scene file?
> (Is this a limitation of POV's precision, or a bug?  banding is
> stronger in original bmp of picture)
> camera { location <-4,4,-4> look_at <0,0,0> right <1,0,0> up <0,1,0> }
> light_source { <1,1,-1> color rgb 1 }
> plane { <0,1,0>, 0 pigment{color rgb 1} }
> and result....
What monitor do you have?  Some old/cheap LCDs only do interpolated 18-bit
colour rather than true 24-bit.  If it's quoted as being able to display
16.2 million colours, it's 18-bit, true 24-bit is 16.7 million colours.  On
this pattern the interpolation your monitor is doing might be more visible.
Have you tried doing a gradient in another program, like powerpoint?
Date: 1 Aug 2005 19:17:57
Message: <42eeada5@news.povray.org>
> (Is this a limitation of POV's precision, or a bug?  banding is stronger in
Fredrick's got it right. The banding is natural for this kind of image
at 24-bit precision, as you effectively only have 8 bits of pure gray to
work with.
Outputting at 48 bits and then dithering down in another app (probably
GIMP or Photoshop) should help reduce the banding; it will also make
your image a bit grainy, but it shouldn't be visibly so. Alternately,
introducing more noise or color to the scene, or adding noise in
post-processing, should eliminate the banding.
-Xplo
Date: 1 Aug 2005 21:38:28
Message: <42eece94$1@news.povray.org>
"scott" <sco### [at] spamcom> wrote in message news:42edd2f4@news.povray.org...
> > and result....
On
visible.
I see this banding on the two computers we have---both are using crt
monitors and are running in 32 bit (true color mode)....
In PSP when doing a pure gray gradient, the banding is also visible....but
when doing pure red or blue or green, the banding is not visible.
I agree, as was said by some others, this is a limitation of  the 24 bit
nature of true color displays...will stick to using more color in pictures
from now on...if I ever get a system capable of 48 bit color display, then I
will try working with pure greyscale pictures again.
hexhall
Date: 2 Aug 2005 04:37:14
Message: <42ef30ba$1@news.povray.org>
> visible....but when doing pure red or blue or green, the banding is
> not visible.
> bit nature of true color displays...will stick to using more color in
> pictures from now on...if I ever get a system capable of 48 bit color
> display, then I will try working with pure greyscale pictures again.
You could turn the contrast down on your monitor :-)
