POV-Ray : Newsgroups : povray.binaries.images : wip shark [39 Kb] Server Time
22 Jun 2026 11:27:04 EDT (-0400)
  wip shark [39 Kb] (Message 8 to 17 of 27)
<<< Previous 7 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: wip shark [39 Kb]
Date: 19 Jul 2005 18:05:19
Message: <42dd791f$1@news.povray.org>
s.day wrote:
> I like the background but think it needs to look a bit more like it is
> underwater, I have never done an underwater scene so I can't really give
> any advice (I wouldn't know where to start except I expect very long trace
> times..)
As a certified scuba diver, I can say that the background *and* the
flotsam are both quite convincing. It's simply a deep evening dive.
     The samba was clearly inspired
     by the margarita.
Date: 19 Jul 2005 18:07:36
Message: <42dd79a8@news.povray.org>
Jim, this is almost like an underwater flash pic if this is possible. It
seems to have been captured by a camera flash light to me. I think this is
why I like it, apart from the modeling, which is close to excellent.
    It does need some movement at some stage though, which I know you're
considering. Attached is an overhead shot of my crap shark, but I think I
captured the movement ok. I did this some time ago now. Hope it helps in
some way.
   Hmm... you do drive me onwards with your modeling and ideas.
     ~Steve~
Download 'shark2.jpg' (16 KB)
Preview of image 'shark2.jpg'
Date: 19 Jul 2005 19:37:36
Message: <42DD8E87.9B8984B1@usb.ve>
Jim Charter wrote:
> I have taken the approach of incrementally refining different aspects of
>   the scene rather than trying to perfect one thing, say the model,
> before proceeding to the next.  I am still tempted to use just a black
> bg for the scene though.
Nice modeling, I like it.
Date: 19 Jul 2005 19:56:40
Message: <42dd9338$1@news.povray.org>
>> trace
>> times..)
Cool, I'll take it!
Date: 19 Jul 2005 23:20:01
Message: <web.42ddc1e89cdd56a24bf9a0280@news.povray.org>
Jim Charter <jrc### [at] msncom> wrote:
This is starting to look quite realistic.  As Steve said, it looks like a
flash photo with backscatter from suspended particles in the water column.
One thing; water tends to shorten flash ranges to about 2-8 ft, decreasing
with the amount of particulate matter, so for this picture to be realistic
the shark would have to be fairly small and about 4-5 ft from the camera.
I'd make the water a shade greener, then make the 'flash' brighter but with
a short fade-distance so there's greater contrast between the near and far
areas.
Also, with particles that large, I'd expect a LOT more smaller particles. I
think a wider range of particle size would be more realistic.
Here's a shot with roughly the same water color as yours, note the sediment
backscatter and how the colors wash out rapidly further from the flash.
This was a wide angle shot, so the shadows in the background are rocks no
more than 10-12 ft away, yet they're almost completely black.
RG
Download 'sd034.jpg' (49 KB)
Preview of image 'sd034.jpg'
Date: 20 Jul 2005 01:35:22
Message: <42dde29a@news.povray.org>
> areas.
Thanks Ron.  It is very helpful to have that information confirmed
especially about the water color.  I did in fact have a media layer of
fine yellow "pea" included but took it out because I was worried that it
was looking too turgid.  I'll put it back and go for a render in closer
with wider camera angle and lighting as you suggest.  The thing is the
modeling/texturing on the shark isn't detailed enough yet to sustain a
real close view.  And my command of media effects isn't quite up to a
long view with sunlight coming down from a surface plane.  But getting
there. ;)
Date: 20 Jul 2005 01:41:25
Message: <42dde405$1@news.povray.org>
> is why I like it, apart from the modeling, which is close to excellent.
The light is placed near the camera like a flash and it has a pretty
steep fade power.  But it is a spot light with a fall off angle of
around 20 degrees.  So I was really thinking directional strobe but I
guess a flash could be directed too.  Anyway I'll try some wider angles
and other things.  Thanks for the support.
> I captured the movement ok. I did this some time ago now. Hope it helps
> in some way.
Nice shot.  I see you went for the aqua sea color too.
   And you see I was right.  At some point you just gotta try doing a shark.
   But okay okay, I'll make the shark wiggle,,,soon.
Date: 20 Jul 2005 01:42:50
Message: <42dde45a@news.povray.org>
>> [Image]
Thanks Alberto and back at ya.  Great first cut on a very tough subject
... the female face you posted.
Date: 20 Jul 2005 03:46:03
Message: <42de013b@news.povray.org>
"Jim Charter" <jrc### [at] msncom> schreef in bericht
news:42dd4561@news.povray.org...
Wow! Not only convincing, but terrifying! Very good job.
Date: 20 Jul 2005 04:30:27
Message: <42de0ba3$1@news.povray.org>
Looks very nice to me !
Please don't put a black bg !!!!!
Dark Skull Software
http://www.darkskull.net
A+
