POV-Ray : Newsgroups : povray.binaries.images : latest WIP [136 K] Server Time
12 Oct 2024 04:25:31 EDT (-0400)
  latest WIP [136 K] (Message 1 to 10 of 14)
Subject: latest WIP [136 K]
Date: 26 Jun 2005 03:22:55
Message: <42be57cf@news.povray.org>
POV-Tree for the trees and shrubs
Wings for the shoes and shoe topiaries
CSG for rest
This would be the ideal time to incorporate changes so criticism is
welcome.  Foreground around the base of the treee is obviously
unfinished.  To have ivy covering the ground there too is the current
intention for that area.
Download 'img.1118.jpg' (136 KB)
Preview of image 'img.1118.jpg'
Subject: Re: latest WIP [136 K]
Date: 26 Jun 2005 04:45:42
Message: <42be6b36@news.povray.org>
"Jim Charter" <jrc### [at] msncom> schreef in bericht
news:42be57cf@news.povray.org...
> CSG for rest
Nice scene!!
A problem with POVtree that I have not solved either, are the leaves that
seem to float in the air, without branches/twigs to attach them. This is
especially so in close-up. In groups or in the distance that doesn't really
matter. But it is annoying... A possible solution is probably to increase
the number of leaves in the bunches, to hide the absence of twigs. I think
that Gilles' tree macro did not have that problem.
I like the ivy and the way it drapes the shoe topiaries. How did you do
that, by the way?
Date: 26 Jun 2005 18:42:21
Message: <42bf2f4d$1@news.povray.org>
Thomas de Groot wrote:
> Nice scene!!
Thanks!!
Yes, I hadn't turned my full attention to that yet.  I was hoping that
it has something to do with "major radius", "minor radius" settings on
the twig(?) tab.  Anyway, as you say, MakeTree would work just as well
for these "canopy" leaves.  I also want to do a more detailed job an the
actual leaves.  Those you see are just stock POV-Tree place holders.
> that, by the way?
I am actually using the Wings vertex data.  The "frames" are build by
joining vertices around each face.  But for the ivy, I "mined" out the
average or center points for each face along with the average normal so
I could use Reorient_Trans to correctly orient the bit of vine hanging
from each point. It is very crude but seems adequate for this level of
detail in this particular picture. The bits of hanging vine and their
leaves were generated in POV then instanced.  I usually create an array
of half a dozen or so random variations, then access the array randomly
when I go to place and actual bit of vine.
The ivy on the trunk is arranged along real vine stalks which I applied
using trace() together with spline definitions.  The trick there of
course is to add each generated vine to the trace target object so that
succeeding vines will ride over top of the preceding ones.
Date: 27 Jun 2005 03:09:02
Message: <42bfa60e@news.povray.org>
news:42bf2f4d$1@news.povray.org...
> the twig(?) tab.
Hmm. Yes. Don't remember if I played really seriously with that. Will have
to try.
Smart. Good work.
Smart too! An idea I had not yet explored. [so much to do!]
Date: 27 Jun 2005 09:05:00
Message: <42bff97c$1@news.povray.org>
>>the twig(?) tab.
> to try.
I spent last evening on it.  I don't think it is possible to totally
eliminate the gap.
On to plan B.  Convert MakeTree to output mesh or hopefully mesh2. :|
Date: 27 Jun 2005 18:04:47
Message: <svt0c117psjog241puc92vnh99n4p7rakb@4ax.com>
On Sun, 26 Jun 2005 03:22:36 -0400, Jim Charter <jrc### [at] msncom>
>CSG for rest
The path doesn't fit the back/mid ground. I can't put my finger on it
seem mismatched with respect to the path, I think. Besides that, I
think you're getting a foot fetish, Jim :-)
BTW the greenery's looking good.
Regards
Date: 27 Jun 2005 19:26:13
Message: <42c08b15@news.povray.org>
Now that one I didn't quite expect.  But in a way you are pointing to
the thing that was bothering me too, but I saw it in terms of the
coloring.  This coloring was the first solution I was halfway happy
with, ie the red brick road way and the light facing, but I wasn't sure
it it would sell.
The blob is all of a piece, that is if I don't render the stairs, it
would flow continuously.  So I wonder if that is it.  That if the
expectation is that it would act as a retaining wall of sorts.  If it
was truly a path, it would conform to the terrain more rather than being
geometrically regular. But if it is geometrically regular then you
should see the terrain conform to it?  In a cultivated garden the
landscaper could actually have it both ways, I guess?  So maybe I need
to either make the terrain more geometric to conform to the walkway or
the walkway more conforming to the terrain.  Hmmm.  Kind of a b---h
since that walkway was harder to do than I'd anticipated :(  It's not as
if I didn't think of this before, it's just that I dismissed it with the
idea that the whole thing is a fantasy anyway.  Something of a new thing
for me, this fantasy business.
> Besides that, I
Yeah, but that's old news.  Melly nailed me on that one like four years
ago.
This is an idea I've had since the "Gardens" round.  But I was unable to
complete the entry in time back then.  Gilles, anyway, and I am sure
many others, have been using mesh data to arrange objects since forever.
  I always thought the topiary idea was screamingly obvious, what with
the POVer's preoccupation with foliage generation and all, but I don't
remember seeing anyone else do it so....
Somehow this idea of a fantasy garden of shoes seems like some sort of
logical progression from the hundreds of paintings I used to do of shoes
propped up on their toes:
http://www21.brinkster.com/jrcsurvey/paintings/selectedmenu.html
Date: 28 Jun 2005 03:41:21
Message: <13v1c1doaj9vp1i9v788iopp7jautvnps2@4ax.com>
On Mon, 27 Jun 2005 19:26:01 -0400, Jim Charter <jrc### [at] msncom>
>it it would sell.
Yes the colouring but not of the walkway but the hillock. The texture
looks right if it is about a mile away but the path shows it is much
closer. This part of the image is hard to look at for me. Eye and mind
in conflict if you know what I mean. I like the lighting, the red
brick road and the water. I've already mentioned the trees and ivy I
think. The real shoes are a bit obscured by the bushes in the
background and I would like to see what they looked like lying
carelessly on the ground, at least one of them.
>> Besides that, I
>ago.
Before my time. I only discovered the newsgroup when Moray 3.5 went
into beta. Anyway Tom has an eye for that sort of thing being a bit of
Thanks for the link, very nice to see some of your work. I am
impressed.
Regards
Date: 28 Jun 2005 04:16:55
Message: <42c10777$1@news.povray.org>
news:42c08b15@news.povray.org...
> it it would sell.
Hmm... I wonder if one of the causes of this is not the exact juxtaposition
of the left topiary and the branching of the path/staircase. This breaks the
perspective view at a crucial point (for the eyes).
That is very good work, Jim. I believe that this may get people interested
in shoes you know! Quintessential, really.
Date: 28 Jun 2005 11:11:48
Message: <42c168b4@news.povray.org>
>>it it would sell.
The whole thing came about because I needed to do something with the far
side of the pond.  I felt there needed to be some sort of wall or riser
there, just behind that featured topiary, precisely to give the eye a
reference point and to help profile the point where the topiary is
supported. Having a hill just recede away into the background along with
the converging lines of the surrounding walkway seemed unsatisfying.
Once I put the riser there, the need to have it extend into the hill,
somehow, was inevitable.  I kind of liked the stairs sweeping down and
ending at the all important toe touch.  But in the general case it is
well known that such convergences of lines in a picture are bad
compositionally. precisely because they interrupt the sense of
overlapping perspective.  The least I can do is rotate the stairs around
the pond to the right some more or change the camera angle.  Actually,
in my mind the wall was higher, but I wanted that sort of golf links
look too, with fixtures extending into the distance on a rolling green.
  Maybe I want too much
Thankyou.  I believe there is a *lot* of latency involved with shoes.
If you look closely you may notice that I showed you the "selected"
menu.  Inquiring minds may wonder what would be on the plain vanilla menu ;)
