POV-Ray : Newsgroups : povray.binaries.images : Lensflare Server Time
8 Nov 2024 06:25:34 EST (-0500)
  Lensflare (Message 1 to 10 of 18)
Subject: Lensflare
Date: 18 May 2005 19:48:19
Message: <428bd443@news.povray.org>
Chris Colefax's Lens Effect include file has a few disadvantages: sometimes it
substracts color from the background instead of adding to it, and you need a
high max_trace_level for it to work properly.
I tried to make my own lensflare-system to compensate for this problems. First I
tried with functions, but that seemed to be way too slow. This is a test with
averaging pigments. The lensflare itself consists only of 1 plane directly in
front of the camera (using screen.inc :)), with only 1 texture. There is only
one, quite big, problem with this technique: multi-colored lensflares are
impossible, because the colors average to gray :-/
It's a TIP, but again a useless TIP in most cases.  Is there a fast way to
combine pigments in an additive way?  (already found an addictive way though)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Download 'lensflare.jpg' (50 KB)
Preview of image 'lensflare.jpg'
Subject: Re: Lensflare
Date: 18 May 2005 21:04:41
Message: <428be629$1@news.povray.org>
See my post "Additive transparency" in povray.binaries.scene-files,
2/3/2005.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 May 2005 03:04:23
Message: <428c3a77$1@news.povray.org>
Very nice !
Dark Skull Software
http://www.darkskull.net
A+
Date: 19 May 2005 03:20:06
Message: <428c3e26$1@news.povray.org>
Zeger Knaepen wrote:
> Is there a fast way to combine pigments in an additive way?
As fast as average. Use average, while multiplying all colors (or
alternatively the ambient and diffuse values) with the number of pigments
being averaged.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 19 May 2005 04:12:02
Message: <428c4a52$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message news:428be629$1@news.povray.org...
> 2/3/2005.
aha! that worked! thanks a lot! :)
uhm, I can use that for my lensflare-system, can't I? :)
cu!
Date: 19 May 2005 04:12:22
Message: <428c4a66$1@news.povray.org>
"Marneus Calgar" <nos### [at] pleasecom> wrote in message
news:428c3a77$1@news.povray.org...
> Very nice !
thank you!
I hope I finish this one, some day :)
cu!
Date: 19 May 2005 04:13:42
Message: <428c4ab6$1@news.povray.org>
"Rune" <run### [at] runevisioncom> wrote in message
news:428c3e26$1@news.povray.org...
> being averaged.
That's how I did it, but it results in different shades of gray when I used more
than one hue.  But Slime's macro worked, so maybe this will become a fully
functional lensflare-system, someday :)
cu!
Date: 19 May 2005 12:15:14
Message: <428cbb92@news.povray.org>
>> pigments being averaged.
> I used more than one hue. But Slime's macro worked, so maybe this
> will become a fully functional lensflare-system, someday :)
Slime's macro can be used for creating pigments that are added to what is
*behind* the object surface. But if you want to also add several of these
pigments to *each other*, while still using one object surface only, then
you can still use an average where you multiply all colors (or ambient and
diffuse values) with the number of pigments being averaged.
So if you use both Slime's macro for the colors *and* the average trick,
then you can have several pigments that are additive *both* to the
background *and* to each other. :)
Example:
plane {-z, 0
   pigment {checker rgb 0.3, rgb 0.7}
   finish {ambient 1 diffuse 0}
   translate 10*z
plane {-z, 0
      average
      pigment_map {
         [1, spherical color_map {[0 transmit 0.99][0.3,rgbt <1,0,0,0.99>]}
translate < 0.6, 0.0,0>]
         [1, spherical color_map {[0 transmit 0.99][0.3,rgbt <0,1,0,0.99>]}
translate <-0.3, 0.5,0>]
         [1, spherical color_map {[0 transmit 0.99][0.3,rgbt <0,0,1,0.99>]}
translate <-0.3,-0.5,0>]
   finish {ambient 100*3 diffuse 0}
   translate 3*z
Rune
Date: 19 May 2005 13:05:12
Message: <428cc748@news.povray.org>
news:428cbb92@news.povray.org...
yep, that's what I'm using now :) (see attachment)
only problem now: Additive_Blend(Color, 1, 0) on a given background-color, is
brighter than the background-color + Color.
cu!
Download 'lensflare2.jpg' (53 KB)
Preview of image 'lensflare2.jpg'
Date: 19 May 2005 13:38:53
Message: <428ccf2d$1@news.povray.org>
Yes =)
 - Slime
