POV-Ray : Newsgroups : povray.binaries.images : Lensflare Server Time
13 Jul 2026 17:09:54 EDT (-0400)
  Lensflare (Message 11 to 18 of 18)
Subject: Re: Lensflare
Date: 19 May 2005 13:42:06
Message: <428ccfee$1@news.povray.org>
> only problem now: Additive_Blend(Color, 1, 0) on a given background-color,
is
> brighter than the background-color + Color.
Hmm, are you mixing it with colors like rgb 0? After some experimentation,
it looks like the usual interpolation of colors between additive and
non-additive colors doesn't work well (because of the trick the macro uses).
Try using only additive colors in your color map: if you need black, use
Additive_Blend(0,1,0)
> Slime's macro can be used for creating pigments that are added to what is
> *behind* the object surface. But if you want to also add several of these
> pigments to *each other*, while still using one object surface only, then
> you can still use an average where you multiply all colors (or ambient and
> diffuse values) with the number of pigments being averaged.
You should be able to use a layered texture or pigment map as usual.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 May 2005 14:04:07
Message: <428cd517@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message news:428ccf2d$1@news.povray.org...
> > aha! that worked! thanks a lot! :)
> > uhm, I can use that for my lensflare-system, can't I? :)
> Yes =)
thank you :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Date: 19 May 2005 14:05:12
Message: <428cd558$1@news.povray.org>
"Slime" <fak### [at] emailaddress> wrote in message news:428ccfee$1@news.povray.org...
> is
as far as I know, everything except the background uses
Additive_Blend(something,1,0)
cu!
Date: 20 May 2005 00:18:24
Message: <428d6510$1@news.povray.org>
Another way to do additive transparancy is used in NKFlare (really old but
fun lens flare system written by yours truly
http://www.nathan.kopp.com/nkflare.htm).  The technique works like this:
1) use the color you want, but set transmit to 0.5
2) use "ambient 2" (instead of "ambient 1")
3) use "refraction 2.0" (instead of "refraction on")
It's this last bit... the "refraction 2.0", combined with the 0.5 transmit,
yeilds a 100% transmission.  Then, then "ambient 2", coupled with the 50%
that's left over from the transmit component, gives you the 100% of whatever
color you specify, which is added to the 100% transmission.
-Nathan
"Slime" <fak### [at] emailaddress> wrote...
> > Is there a fast way to
> > combine pigments in an additive way?
> See my post "Additive transparency" in povray.binaries.scene-files,
> 2/3/2005.
>  - Slime
Date: 20 May 2005 02:51:45
Message: <428d8901$1@news.povray.org>
> old but fun lens flare system written by yours truly
> this:
Very curious using a currently undocumented feature! The refraction keyword
is obsolete though (except for photons, but that's unrelated), so who knows
if it will be supported in future versions of POV-Ray?
I wonder how it was described back when it was documented? Was it mentioned
that you could use a float rather than an on-off value? I always thought
refraction was related to the bending of rays only (in conjunction with
ior), not how much light passed through...
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 20 May 2005 04:44:29
Message: <428da36d$1@news.povray.org>
"Nathan Kopp" <pov### [at] nkoppmailshellcom> wrote in message
news:428d6510$1@news.povray.org...
> -Nathan
Ah, yes, that seems to work also :)
Maybe I should do some testing as to find out which technique is the fastest.
cu!
Date: 20 May 2005 08:19:42
Message: <428dd5de@news.povray.org>
With 5100 pigments averaged together giving a render time of about 6
minutes, I can't measure any difference. And indeed, why would there be one?
All the same calculations are there (refraction is 1.0 per default) they
just use different values.
Rune
Date: 20 May 2005 09:55:23
Message: <428dec4b$1@news.povray.org>
"Rune" <run### [at] runevisioncom> wrote in message
news:428dd5de@news.povray.org...
true
In that case, I think I'll go for Slime's solution, because it doesn't use any
undocumented features that might dissapear.
cu!
