POV-Ray : Newsgroups : povray.binaries.images : Radial height_field Server Time
28 Dec 2025 07:48:05 EST (-0500)
  Radial height_field (Message 1 to 10 of 11)
Subject: Radial height_field
Date: 16 May 2005 14:39:21
Message: <4288e8d9@news.povray.org>
Christoph Hormann's recent updates on his LOTW-project, inspired me to do some
work on my own LOTW-system.  Now, this is a technique-in-progress (TIP?).  A
radial height_field.  The idea is that parts of the landscape far away from the
camera don't need to be as detailed as the parts close to the camera.  So in
terms of regular height_fields, the resolution may decrease as the distance from
the camera increases.  This can easily be accomplished by going through the
points in your height_field-image (or function in this case) not in a
rectangular way, like regular height_fields, but in a radial way.
Hope you understand what I'm talking about :)
Oh, and, uhm, it might be an interesting technique, but I'm afraid, it's not
very useful: parse-time increases and trace-time doesn't really seem to be less
than an ordinary height_field :-/
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)                 // ZK http://www.povplace.com
Download 'radialheightfield.jpg' (54 KB)
Preview of image 'radialheightfield.jpg'
Subject: Re: Radial height_field
Date: 16 May 2005 16:52:36
Message: <42890812@news.povray.org>
> some
> A
> from the
> in terms of regular height_fields, the resolution may decrease as the
> distance from
> the points in your height_field-image (or function in this case) not in a
> not very useful: parse-time increases and trace-time doesn't really seem
> to be less than an ordinary height_field :-/
I had a similar idea, also abandoned, my take was to use the camera
parameters (direction, width, height) to control the nummer of points. It
was no faster but the memory consumption seemed lower. here's a sample
image just to prove I'm not just BS-ing :-)
Bill Hails
http://thyme.homelinux.net/
Download 'smooth.jpg' (44 KB)
Preview of image 'smooth.jpg'
Date: 16 May 2005 17:44:50
Message: <42891452@news.povray.org>
The idea is interesting, though. I wonder if it would work better
implemented in code than SDL.
-Xplo
Date: 16 May 2005 17:53:01
Message: <4289163d$1@news.povray.org>
I guess it's somewhat unnecessary with heightfields. Unless you got a
*very* detailed one, I doubt the effect will be very noticeable. It
would be really nice with isosurfaces (wasn't there anyone doing some
stuff in that direction?) and with terrain generators or things like
that. IIRC it's a standard feature for meshes in most commercial packages.
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
Date: 16 May 2005 18:07:06
Message: <4289198a$1@news.povray.org>
"Xplo Eristotle" <xpl### [at] infomagicnet> wrote in message
news:42891452@news.povray.org...
It will probably parse a lot faster, but the trace-speed should be the same.
cu!
Date: 16 May 2005 18:10:48
Message: <42891a68@news.povray.org>
"Florian Brucker" <tor### [at] torfboldcom> wrote in message
news:4289163d$1@news.povray.org...
Yes, but it was supposed to be for *very* detailed height_fields :)
I just rendered a low-resolution radial height_field to more clearly show what
it is :)
> It
But most commercial packages use scanline-rendering, where the speed is
proportional to the amount of polygons in the scene.  With raytracing, it's
different.  The main factor is the image resolution, not the scene-detail.
Extremely detailed scenes will render faster with raytracing than with scanline
rendering.  So I really wonder if a LOD-system for height_fields has any use :-/
cu!
Date: 16 May 2005 18:20:09
Message: <pan.2005.05.16.22.20.09.70117@nospam.com>
> scene-detail.
Well, perhaps - the thought that comes to my mind is the parse time -
that's still going to be a factor of the number of objects/polygons in the
scene regardless, so lowering the detail level farther away from the
camera could potentially save some time - and quite possibly some memory
(which might be more significant).
It might be interesting with this technique to look at memory consumption.
Jim
Date: 16 May 2005 18:53:32
Message: <4289246c@news.povray.org>
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:pan### [at] nospamcom...
> > scene-detail.
ah, yes, now I remember why I tried this :)
no really, I forgot :-/
Maybe I need to buy me some more memory :)
cu!
Date: 16 May 2005 19:13:59
Message: <pan.2005.05.16.23.13.59.521599@nospam.com>
<G>
The thought of how complex the scenes are that I can create with 2 GB of
memory with a technique that reduces memory consumption are somewhat
mind-boggling.  Not to mention that I've not done anything near complex
enough to warrant using all the memory in my machine. <G>
Jim
Date: 17 May 2005 03:34:05
Message: <42899e6d@news.povray.org>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> schreef in bericht
news:42891a68@news.povray.org...
> > It
packages.
it's
scanline
use :-/
Still, that idea of Florian, to apply the technique to isosurfaces, seems
interesting to me. It would not parse faster I suppose, but wouldn't it
render faster?
