> I worked a bit on textures and here is the result> Bye> > ------------------------------------------------------------------------
Looks like a photo !!!
Dark Skull Software
http://www.darkskull.net
A+
Subject: Re: Urban furniture revisited
Date: 13 May 2005 08:00:49
Message: <428496f1$1@news.povray.org>
"Txemi Jendrix" <txe### [at] nospamcom> wrote in message
news:4284149f@news.povray.org...
> I worked a bit on textures and here is the result> Bye> -- > ________________________> Txemi Jendrix> www.txemijendrix.com>
Looks good, but the pattern on each bit of wood is identical.
Chris B.
L
That's because each bit of wood is identical (there's only one, the rest
are references), actually it is a prism heavily extruded and rotated.
Anyway, it's not going to be in the foreground and it will be smaller
> Chris B.
Txemi Jendrix
Date: 13 May 2005 11:20:32
Message: <4284c5c0$1@news.povray.org>
looks great. the shape is excellent. the metal legs are perfect. the
texture's pattern is a little to repetitious, but it's forgiveable and
wouldn't be noticed in a scene.
-r
Ross wrote:
> > looks great. the shape is excellent. the metal legs are perfect. the> texture's pattern is a little to repetitious, but it's forgiveable and> wouldn't be noticed in a scene.
Thank you very much for your kind comments.
Actually the metal legs need a bit more work to add some accesories
(eight torus and four cylinders I think) and you are right with the
texture pattern.
I will finish the legs this weekend. See you later.
> -r
Txemi Jendrix
