POV-Ray : Newsgroups : povray.binaries.images : Glass Rods (and photon problem?) Server Time
18 Jun 2026 18:14:32 EDT (-0400)
  Glass Rods (and photon problem?) (Message 1 to 7 of 7)
Subject: Glass Rods (and photon problem?)
Date: 10 May 2005 21:37:20
Message: <428161d0@news.povray.org>
I have shot about 1Gb of photons, the shadows /
reflection seems very accurate, but despite dispersion
(and a rather dispersion_samples setting) the highlights
do not show color, except when pointing at the camera.
How so? ( I'm using 3.5 for windows... time to upgrade?)
    interior
      ior 2.0
      dispersion 1.15
      dispersion_samples 50
      fade_distance 5.0
      fade_power 2.0
      caustics 2
Steven Pigeon, Ph. D.
ste### [at] stevenpigeoncom
ste### [at] videotronca
Download 'InformationRods_small.jpg' (47 KB)
Preview of image 'InformationRods_small.jpg'
Subject: Re: Glass Rods (and photon problem?)
Date: 10 May 2005 23:38:47
Message: <42817e47$1@news.povray.org>
Nice! What would be the source of the color then? Your light looks white or
perhaps vaguely blue. The only time I've seen much color in prisms is when
they are optically active and the light is polarized. Now make POV do that!
DLM
"Steven Pigeon" <pig### [at] iroumontrealca> wrote in message
news:428161d0@news.povray.org...
>    interior
>      ior 2.0
>      dispersion 1.15
>      fade_distance 5.0
>      fade_power 2.0
>      caustics 2
Date: 10 May 2005 23:55:31
Message: <42818233@news.povray.org>
The light going through the prism should normaly
disperse (the glassy material is not perfectly straight,
there is a small warping in its normal, that should
accentuate the effect.)
The color seems to vary with the photon density.
At lower density, more color shows. But it's also
much granier.
"dlm" <me### [at] addressinvalid> wrote in message
news:42817e47$1@news.povray.org...
> or
> that!
> DLM
>>    interior
>>      ior 2.0
>>      dispersion 1.15
>>      fade_distance 5.0
>>      fade_power 2.0
>>      caustics 2
Download 'InformationRods_13.jpg' (43 KB)
Preview of image 'InformationRods_13.jpg'
Date: 11 May 2005 19:28:01
Message: <42829501$1@news.povray.org>
Steven Pigeon nous apporta ses lumieres en ce 2005-05-11 03:35:
>     interior
>       ior 2.0
>       dispersion 1.15
>       fade_distance 5.0
>       fade_power 2.0
>       caustics 2//???
Why are you using caustics? Normaly, when you sue photons, you don't use caustics. In
fact, you drop
the fake caustics to replace them with true ones.
Date: 11 May 2005 19:46:07
Message: <4282993f$1@news.povray.org>
I'll remove them and see what happens
Thanks for pointing that out.
Best,
    S.
"Alain" <ele### [at] netscapenet> wrote in message
news:42829501$1@news.povray.org...
>>     interior
>>       ior 2.0
>>       dispersion 1.15
>>       fade_distance 5.0
>>       fade_power 2.0
>>       caustics 2//???
> caustics. In fact, you drop the fake caustics to replace them with true
> ones.
> Alain
Date: 22 May 2005 03:05:01
Message: <web.42902eca234e41e4b896af6f0@news.povray.org>
Sorry, I'm new to povray and I use a modeler. I have been messing around
with photons and glass and was wondering what the photon block or code was
that you added to each object.
This what I have managed to make
General stuff some photons
www.teampki.com/~cyris69/renders/
All glass + photons this is where u can see how i have used them
www.teampki.com/~cyris69/renders/glassroom.html
If anything could you help me out by emailing me at cyr### [at] insightbbcom
Thanks, and beautiful work I might add.
Date: 22 May 2005 14:41:24
Message: <4290d254$1@news.povray.org>
Cyris69 nous apporta ses lumieres en ce 2005-05-22 09:03:
With comments:
photons{target//enable the object to receive and interact with the photons
  refraction on//enable photons refraction for that object
  reflection on//enable photons reflection for that object
  collect off// disable showing the photons effect from other objects
//usefull for mostly transparent or highly reflective objects
The default are:photons{target off refraction off reflection off collect on}
In glassroom6.bmp, you need more photons: reduce the spacing OR increase the count.
I see much facing, you need to set your meshes to a finer setting.
