POV-Ray : Newsgroups : povray.binaries.images : Mesh2 bug? [JPG, 800 x 600, 42881 bytes] Server Time
11 May 2026 00:43:13 EDT (-0400)
  Mesh2 bug? [JPG, 800 x 600, 42881 bytes] (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Mesh2 bug? [JPG, 800 x 600, 42881 bytes]
Date: 23 Apr 2005 20:10:19
Message: <426ae3eb@news.povray.org>
> High!
>> Hmmm... the mesh2 is a 1-square degree slice of Earth's surface at 1
>> unit equalling 1 metre... so everything you see in the image is
>> several million units away from the origin. I'll try scaling it down
>> by a factor of, let's say 1000 and see what happens...
> No, obviously it's no matter of dimension... even if I scale the whole
> thing down to one billionth (!!!). the gaps remain the same!
> Perhaps I should try tweaking max_trace level...
> See you in Khyberspace!
> Yadgar
See if PoseRay can help here (user.txcyber.com/~sgalls/). It can read
mesh2{} and mesh{} objects. Load the mesh and join vertices with a
larger tolerance until you don't see any gaps. Then export back to mesh
from PoseRay. If you cannot read the mesh please let me know.
later,
FlyerX
Date: 24 Apr 2005 03:48:48
Message: <426b4f60@news.povray.org>
High!
I'm not sure whether this might work... since the POV mesh2 is not
generated from a ready-made mesh object in some other format, but from a
simple ASCII matrix of float values separated by commas, generated by
3DEM from a GeoTIFF!
Yadgar
Date: 24 Apr 2005 04:07:52
Message: <426b53d8@news.povray.org>
High!
Gilles Tran wrote:
> If precision errors can be ruled out, then it looks like that the common
> vertices of two adjacent triangles are actually slightly different... I've
> never seen something like this in a regular mesh2. One possible way to test
> this would be to choose one vertex coordinate (for instance x=3.8989901) and
> search for the beginning of the string (without the last digits, for
> instance 3.898). If you find something like x=3.898123 then it's probable
> that the vertices are duplicated and slightly off.
I have no clue how to do this... I even didn't understand until now how
face_indices work - it's all Greek to me! And posting the code would be
useless without also posting the ASCII matrix - but the latter is about
6 megs large!
In the original matrix, the elevation values are in fact integer
numbers, but converted to floats, with an accuracy of 2 digits right of
the point, such as 2894.00,2876.00,2803.00,... etc.
Perhaps I should erase all those useless .00s to get real integers...
Yadgar
Now playing: Endless Dream (Yes)
Date: 24 Apr 2005 04:11:34
Message: <426b54b6$1@news.povray.org>
I'm not sure actually *scaling* the object down (with the scale keyword)
would make a difference. (This would just cause the ray to be transformed by
the inverse amount, calculate the intersection as usual, and then scale the
result back down, which doesn't avoid the actual potential problem of huge
numbers.) Instead, you might have to actually change the values you're
working with; that is, multiply the actual vertex_vectors by a small number
(or perhaps subtract a large number from them to bring them closer to the
origin in a certain direction without uniformly scaling).
The other thing, as Gilles pointed out, is to check whether your mesh data
actually *is* a series of disconnected triangles! Look at your data
carefully to rule this out.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 24 Apr 2005 04:13:23
Message: <426b5523$1@news.povray.org>
and
Another way would be to look at the face indices and check that a certain
vertex number, for instance vertex # 100, appears more than once. If each
vertex number appears only once, then that would indicate triangle corners
aren't matching up.
 - Slime
Date: 24 Apr 2005 04:41:46
Message: <426b5bca$1@news.povray.org>
High!
No, I instead divided all non-degree numbers through 1000, so also the
elevation values for the vertices!
Perhaps you didn't understand the situation yet... I didn't import any
ready-made mesh data in a non-POV format, but merely a series of 1.44
million (1200 by 1200) elevation points stored in a simple ASCII file,
such as
2492,2478,2501,2498,... etc. ad nauseam
Yadgar
Now playing: The Revealing Science of God, 1996 live version (Yes)
Date: 24 Apr 2005 04:44:59
Message: <426b5c8b$1@news.povray.org>
High!
(half an hour later)
Not even this worked... now I'm really not sure anymore whether I should
insist on spherical Khyberspace or instead settle for a flat
Afghanistan... although it would be strange to spot distant Kandahar
from Kabul's Koh-e Safi!
See you there ;-)!
Yadgar
Date: 24 Apr 2005 05:55:02
Message: <d4fq5j$g1u$1@chho.imagico.de>
> High!
> I finally managed to render a spherical mesh2 section from GeoTIFF
> elevation data... but then a strange artifact shows up: narrow gaps
> between most triangles! How can I get rid of this
It is quite obvious - like others have mentioned - that the triangles
you see a gap between do not share the same vertices like they should.
Note i am talking about *the same* here, not calculated from the same
data.  Apart from the errors this could introduce (and the gaps you see)
this is immensely inefficient - the very purpose of the mesh2 syntax is
to avoid specifying the same vertices several times.
Note there is no need to code something new - Ingo's MMMM-macros
(http://members.home.nl/seedseven/) can be used for this.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 24 Apr 2005 06:31:12
Message: <426b7570$1@news.povray.org>
High!
Obviously this is designed for using smooth_triangles... but I did (at
least for the moment) not specify any normal vectors at all!
Can I use the macros nonetheless?
Yadgar
Date: 24 Apr 2005 06:49:00
Message: <426b799c$1@news.povray.org>
You might be able use my MMM (available from the Download-Section of my
website), if you can store the data in a 2d-array.
E.g., if the DEM-data is in a rectangular grid, the first pixel (top left)
would be at array[0][0] and the last pixel (bottom right) would be at
array[100][100], the first dimension being the x-space.
They convert a rectangular grid of vertices into triangles/a mesh, and I've
got macros to generate some normals off of the data for smooth_triangles.
I've lately add Wavefront-OBJ export, so you could also save the mesh to
disk and smoothen/subdivide it with a different programm.
Tim
"Tim Nikias v2.0"
