at camera angles 5, 10, 20, 40
normal is basically
crackle
scale .04
poly_wave .045
pigment_map {
[0 rgb 0]
[1 rgb .7]
averaged with some dents.
finish is
diffuse 1
specular .75
roughness .035
ambient 0
reflection { .075 .15
fresnel 1
metallic 0
Comments and criticism welcome.
Download 'img.1044.jpg' (35 KB)
Download 'img.1045.jpg' (26 KB)
Download 'img.1046.jpg' (21 KB)
Download 'img.1047.jpg' (23 KB)
Preview of image 'img.1044.jpg'
Preview of image 'img.1045.jpg'
Preview of image 'img.1046.jpg'
Preview of image 'img.1047.jpg'
I really like the texture around the specular highlights, especially near
the buckle, looks very photorealistic. But the "lighter" bit at the bottom
edges looks wrong, it's all one colour, is this just a reflection of the
walls? Too much reflection then IMO, or maybe the walls are too bright, or
too plain?
Girl's gonna fall off her shoes and break an ankle. (My younger daughter,
10 yrs old, wants a pair like that; in a rare show of solidarity, her
mother and I vetoed the idea.)
Anyway, to the topic -- fantastic, as always, and thanks for the code.
Texture makes the image, and it's the thing I have the most difficulty
with. Have you published any texture tutorials? If not, get with it! ;-)
Your shoe-modeling tutorial helped my Wings skills immensely.
Dave Matthews
"Goth" at 10 years, sounds like trouble. Tattoo? Sounds like my sister's
two girls actually. My own 12 year old daughter's a jock. Girly stuff
scares her.
This is a variation on the leather texture I put on the Wiki
Something that may be needed but a difficult topic to approach in a
general way. With texture it is very difficult to move seemlessly
between the general and the specific. That is I believe one of the
difficulties with the endeavor in the wiki to produce a catalog of
textures. They are so dependent on context.
Thanks for saying so. And that may provide an approach for doing
something with textures. Just step through an anecdotal example and the
issues that get touched on, are illustrated, other issues are not.
> too plain?
I think it is the reflection of the "table" surface. I really need to
do more experimenting with reflection, I don't really understand how it
works. I often seems to me that if there is *any* reflection on a
surface, it 1mmediately makes it look like a highly reflective surface.
Still I no doubt I could reduce the reflection here to some benefit.
I am also not sure why the texture gets washed out in the reflection.
But both of these effects may be present in the world but not really
noticed by us. For instance it my be that objects are often more
reflective than we perceive them to be. And that reflection tends to
wash out surface texture to an extent, even though I'd have thought the
opposite. I have experimented a bit with the blurred reflection devices
too but without satisfactory results. I guess what I haven't tried is
High aa, but I really can't see how it would have any effect.
Attached is one of my reference pictures for the shoes. You can see
that the finger and the throw sheet ground are both reflected quite
clearly in the leather.
Download 'img.3964.jpg' (20 KB)
Preview of image 'img.3964.jpg'
Jim Charter wrote:
Looks like pleather or some other fake polished leather. Real leather
doesn't have the sharp lines (noise) at the edge of the specular due to
its being covered with pores.
I took some reference shots, three with a highlight and three without.
Might be useful to you.
http://www.simcoparts.com/pics/leather
-Shay
Try to render it again with very strong antialiasing, like "+a0.0 +r4"
(or whatever the level switch is). It might make the blurred reflections
actually look blurred...
Or if it won't make, add a very small micronormals to the texture.
Basically bumps scaled very small. And then render using strong
antialiasing.
> -Shay
Thanks for those. I see from your example that the pitting from the
pores and the wrinkly pebbled look can exist simultaneously with each
other. Or in fact the pitting itself can look like pebbling. If I reach
over and pick up my Mizuno "Power Close" fielder's mitt here, and
examine it's "supersoft one-touch" leather under the magnifying glass, I
can see exactly the deep pitting that your photos exhibit. But if I
look on the other side of a seam, the pitting is not visible and the
look is more wrinkly-pebbled. This is also true if I examine the
leather of my Lug boots. So I wonder if the leather might actually have
two sides, or some other characteristic, which are effected differently
by the tanning.
Either way, neither look as smooth as do the examples I posted so thanks
for the wakeup call. I can intensify the deepth of the pebbling with
the poly_wave value. I can introduce pits by tweaking the color map I
suspect.
Attached are two details from the source photo I have. One is at the
native resolution, the other is resampled and magnified.
Download 'image1.jpg' (25 KB)
Download 'image2.jpg' (68 KB)
Preview of image 'image1.jpg'
Preview of image 'image2.jpg'
Shay nous apporta ses lumieres en ce 2005-04-12 11:18:
> -Shay
Or sn overly waxed leather, or some varnished leather. You may also have leather that
have been
"laminated" between steel rolers to make it ultra smooth. I'm thinking of some Italian
shoes that
have a mirror like finish.
