POV-Ray : Newsgroups : povray.binaries.images : Problem with ASCII matrix read into a mesh2 Server Time
28 Dec 2025 15:06:59 EST (-0500)
  Problem with ASCII matrix read into a mesh2 (Message 1 to 10 of 10)
Subject: Problem with ASCII matrix read into a mesh2
Date: 2 Apr 2005 06:43:48
Message: <424e8574@news.povray.org>
High!
Another step towards Khyberspace... but at the moment, I'm once again
hampered by obviously misunderstood technology!
About one year ago, by a posting of Christoph Hormann's latest
achievements in Earth modeling I was informed about the newly published
data files of the Shuttle Radar Topography Missions (SRTM), showing the
At ftp://ftp.glcf.umiacs.umd.edu/glcf/SRTM/Degree_Tiles the single
1-degree tiles are downloadable for free - in the format of 1200 x 1200
GeoTIFFs. Unfortunately, although they look very much like 16-bit
heightfield bitmaps for PoV-Ray, their height scale definition is
completely different, so that PoV-Ray cannot interprete them in a
sensible way.
As I did not (yet) found any understandable definition of the GeoTIFF
standard, I had to content myself with converting them into ASCII
matrizes with a vertical resolution of 1 metre.
The program I used for this is 3DEM, available at
http://www.visualizationsoftware.com/3dem.html (according to all I know,
  there is no Linux version of it!). The converted GeoTIFFs then are
simple tapeworms of 1,440,000 six-digit float values in clear text,
separated by blanks, without any CRs and LFs.
As PoV-Ray I/O directives accept only ASCII files with commas as
delimiters, I had to replace those blanks by commas using the "replace"
utility of Linux, which worked perfectly.
Then, after some problems with the standard mesh object, Jerome M.
Berger (thank you, Jerome!) suggested me to use mesh2 instead, I
rendered a first test version of a spherical mesh2 of GeoTIFF tile
N34E068 (the geographically inclined among us are inviting to look it up
  in their favourite atlas ;-)).
But the result was weird, obviously the float values in the ASCII matrix
are arranged in a different way than the pixels in the GEO-TIFF file.
Attached are the mesh2 rendering and an 2D map generated with 3DEM
showing how the terrain should look instead.
For better comparability of the land features, I placed a waterline at
2500 metres elevation in both images.
The code is available on p.b.s-f
See you in Khyberspace!
Yadgar
Download 'iotest-n.png' (67 KB) Download 'n34e068.jpg' (38 KB)
Preview of image 'iotest-n.png'
Preview of image 'n34e068.jpg'
Subject: Re: Problem with ASCII matrix read into a mesh2
Date: 2 Apr 2005 07:25:02
Message: <d2m2tm$t1s$1@chho.imagico.de>
Oh, come on, there is GDAL: http://www.remotesensing.org/gdal/ which
comes with a simple utility program that converts between any formats
supported which includes Geotiff of course as well as PNG and PGM which
can be read by POV-Ray.
You quite obviously got the size of the images wrong by 1-2 pixel.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 2 Apr 2005 07:31:15
Message: <424e9093@news.povray.org>
High!
Shortly after my last post, I looked up the corresponding thread on
p.b.s-f and found a post of J. M. Berger where he pointed out an error
in his correction of my original traditional mesh version.
So I replaced all "data" in the vertices block by mtrix[a][b] - and this
is what I*ve got (again compared to the 2D map from 3DEM - code (now
really) on p.b.s-f):
Yadgar
Now playing: Village (Robert Quine & Fred Meer)
Download 'iotest-n.png' (91 KB) Download 'n34e068.jpg' (38 KB)
Date: 2 Apr 2005 09:55:22
Message: <424EB1D3.2020802@hotmail.com>
>> matrix are arranged in a different way than the pixels in the GEO-TIFF
>> file.
One pixel, because the matrix is square and there is a diagonal.
Assuming he is reading left to right and top to bottom, Yadgar
is reading one to little per line. A typical obi-wan error I guess
(http://www.catb.org/~esr/jargon/html/O/obi-wan-error.html).
Now playing: New Deal by Dolores Keane
Date: 2 Apr 2005 10:14:19
Message: <424eb6cb@news.povray.org>
I never heard of this! So, possibly the detour via the ASCII matrix is
not longer necessary?
Yes, otherwise there wouldn't be that strange diagonal scarp... must be
a mistake in J. M. Bergers correction of my original version (using a
traditional mesh rather than mesh2). I'll soon try it out (the indices
obviously must be set to 1200 x 1200 x 2, not 1199 x 1199 x 2!), but
firstly, I have to complete the download of the current Java API ;-)!
Yadgar
Date: 2 Apr 2005 10:41:33
Message: <424ebd2d$1@news.povray.org>
Are you sure this isn't the old byte order boondoggle?
From the GeoTiff spec at
http://www.remotesensing.org/geotiff/spec/geotiff2.3.html#2.3
" It is worth emphasizing here that the TIFF spec indicates that
TIFF-compliant readers shall honor the 'byte-order' indicator, meaning that
4-byte integers from files created on opposite order machines will be
swapped in software, and that 8-byte DOUBLE's will be 8-byte swapped."
DLM
news:424e9093@news.povray.org...
> High!
> Yadgar
Date: 2 Apr 2005 11:31:18
Message: <424ec8d6@news.povray.org>
Yes, that's it... how on Earth could I know that the ASCII matrix is in
fact 1201 by 1201? I once again tried it with 1201 instead of 1200, and,
finally got it right (attached here)!
But the GeoTIFF conversion tools mentioned before by Christoph is VERY
intriguing... I think I'll try it out somewhat later, when I finished
the first ground views for better judgement!
Yadgar
Now playing: Earth (Adalbert von Deyen)
Download 'iotest-n.png' (85 KB)
Date: 2 Apr 2005 12:32:53
Message: <424ed745@news.povray.org>
I looked it up and found a dozen programs which use the GDAL library...
which of them do you mean exactly?
Yadgar
Date: 2 Apr 2005 13:30:01
Message: <d2mo82$aaf$1@chho.imagico.de>
>> which can be read by POV-Ray.
None.  Just read what i wrote - GDAL comes with an utility program
gdal_translate (see http://www.remotesensing.org/gdal/gdal_utilities.html).
Date: 2 Apr 2005 14:22:12
Message: <424EF05D.7020805@hotmail.com>
> fact 1201 by 1201?
1) counting ;)
2) it is not uncommon to add one extra line to make sure that
  interpolation can be performed without having to read the
  surrounding tiles.
3) look at the result and you can easily spot what is wrong
> Yadgar
