POV-Ray : Newsgroups : povray.binaries.images : MegaPOV HDRI tests... Server Time
16 Oct 2024 10:12:16 EDT (-0400)
  MegaPOV HDRI tests... (Message 1 to 9 of 9)
Subject: MegaPOV HDRI tests...
Date: 25 Mar 2005 09:52:08
Message: <42442598@news.povray.org>
...with my abused "boltstill" scene.
   Test 3 uses Debevec "kitchen_probe", while test 4 uses my own probe
rendered with MegaPOV from my POVCOMP entry (available soon: I'm still
tweaking it). I think MegaPOV HDRI support just rocks...
Jaime
Download 'boltstill-hdri-3.jpg' (54 KB) Download 'boltstill-hdri-4.jpg' (56 KB)
Preview of image 'boltstill-hdri-3.jpg'
Preview of image 'boltstill-hdri-4.jpg'
Subject: Re: MegaPOV HDRI tests...
Date: 25 Mar 2005 10:25:00
Message: <web.42442c9fce13eb4bcc64607c0@news.povray.org>
The bolt scene always looked cool, but with HDRI? Incredible. I can't wait
to see the probe.
-S
5TF!
Date: 25 Mar 2005 10:50:02
Message: <d21bn5$hfa$1@chho.imagico.de>
Funny - i have been doing some tests with HDRI the last days as well...
Thanks. ;-)
The second one looks somewhat dull - is there reflection in the bolts
texture?  The no_radiosity flag will help to reduce render time when
combining radiosity with reflection BTW.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 25 Mar 2005 11:21:06
Message: <42443a72$1@news.povray.org>
   I'm testing it with all of my previous scenes which are suited for
it... both as HDRI probe or as HDRI target.
> Thanks. ;-)
   No, thanks to you! Specially for the output! I'm even starting to use
it as default output for all my scenes... seems like a good archival
format, being rgbe. With the help of screen.inc, I've done a quick
"hdr-viewer" scene with which I "convert" the .hdr files later to other
formats for viewing. The main advantage is that I can tweak the lighting
intensity later, without having to re-render the scene... thanks!
> texture?
   Yes, there is reflection, but not as much as on the other one. And
also the lighting range on the probe from "thekitchen" is still not very
dynamic... there is excessive light coming from the walls and furniture,
compared with the light intensity from the window.
   Don't worry, I always save radiosity first with plain pigments: I
even don't remember my last one-pass rendering... :)
Jaime
Date: 25 Mar 2005 11:40:01
Message: <web.42443e81ce13eb4ba8399d8d0@news.povray.org>
very nice!
did you see my ISO thread surface of last year?
Subject: re: my very first iso-surface (and second macro) :-)
Date: 5 Sep 2004 10:30:00
Date: 25 Mar 2005 11:53:36
Message: <42444210$1@news.povray.org>
Jaap wrote:
> very nice!
   Thanks!
   Ah, yes... really nice, and much better than my thread, faked with
differenced toruses. But I thought then that it would be really slow to
use your isothread with my "micronormals" texture... well, looking at it
now, max_gradient is only 2... perhaps I should try? ;)
Jaime
Date: 25 Mar 2005 12:05:02
Message: <d21g3q$ile$1@chho.imagico.de>
That's the case in most scenes - since the light source itself does not
actually turn up in the HDR light probe it will often look too dark.
If you however compine HDRI with conventional light sources, in case of
your kitchen for example place an area light at the window position in
addition it will look OK.  I guess both variants can be useful.
>   Don't worry, I always save radiosity first with plain pigments: I even
But all samples taken in the final trace will not profit from this.  And
in scenes like this you usually have a lot of in-trace samples taken.
Date: 25 Mar 2005 14:15:00
Message: <web.42446229ce13eb4ba8399d8d0@news.povray.org>
your texture is very nice!
I did some speed experiments with that iso (4 separate iso's, instead of
using a
lot of Max(..) Min(..) in the function, etc), but i can't remember witch was
the
best. if the thread is only a small part of your image, it's not to bad,
because
the bounding box can be very tight around the thread.
the source also includes a full list of official thread dimensions for
M3..M64.
(i was going to use it for povcomp)
source of all thread iso experiments:
jwstolk.afreehost.net/parts.pov.gz
jaap.
Date: 26 Mar 2005 05:53:03
Message: <42453f0f$1@news.povray.org>
That's real good. Looks impressively real...
