"Le Forgeron" <jgr### [at] free fr> wrote in message
news:42411a22$1@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> James Buddenhagen wrote:
> > I'm interested in artistic images with a math flavor.
> > Here is a simple one (at this point it has to be simple
> > or I can't create it!) which had its inspiration in
> > an arrangement Kottwitz found around 1995 for 20 points
> > on a sphere whose convex hull consists entirely of
> > triangles, and those triangles are as close to equilateral
> > as possible.
> 20 points on a sphere... sound like a dodecahedron to me...
Except, the faces of the regular dodecahedron are not triangles...
In the picture the 20 points are the centers of the red
circular caps and the yellow polyhedron (which has 20 faces)
is the dual of the convex hull.
Jim
> Jim
Are you sure it has 20 faces ? From here, I can see only 12 ...
Regis.
>>Hash: SHA1
>>>as possible.
> Jim
How the 20 points are arranged? The yellow polyhedron looks rather
strange: hexagons and pentagons as faces and at a first sight rather
arbitrary ones. Can you give a link to the paper of Kottwitz?
http://cage.ugent.be/~hs
"hermans" <sas### [at] telenet_invalid be> wrote in message
news:4241c745$1@news.povray.org...
> >>Hash: SHA1
> >>>as possible.
> > Jim
There was no paper. Kottwitz and I looked at looked at the problem of
point arragments on spheres giving all triangular faces for the convex
hull, with the triangles "as close to equilateral as possible" for a
while and then abandoned it. I don't even remember how we defined "as
close to equilateral as possible". In any case, the 20 points of this
example are given approximately by:
p1:=[ 0.4579, 0.0000, 0.8890 ];
p2:=[ -0.4579, 0.0000, 0.8890 ];
p3:=[ 0.0000, -0.6915, 0.7224 ];
p4:=[ 0.0000, 0.6915, 0.7224 ];
p5:=[ -0.6684, -0.6414, 0.3766 ];
p6:=[ 0.6684, -0.6414, 0.3766 ];
p7:=[ 0.6684, 0.6414, 0.3766 ];
p8:=[ -0.6684, 0.6414, 0.3766 ];
p9:=[ 0.9897, 0.0000, 0.1435 ];
p10:=[ -0.9897, 0.0000, 0.1435 ];
p11:=[ 0.0000, -0.9897, -0.1435 ];
p12:=[ 0.0000, 0.9897, -0.1435 ];
p13:=[ -0.6414, -0.6684, -0.3766 ];
p14:=[ 0.6414, -0.6684, -0.3766 ];
p15:=[ 0.6414, 0.6684, -0.3766 ];
p16:=[ -0.6414, 0.6684, -0.3766 ];
p17:=[ 0.6915, 0.0000, -0.7224 ];
p18:=[ -0.6915, 0.0000, -0.7224 ];
p19:=[ 0.0000, -0.4579, -0.8890 ];
p20:=[ 0.0000, 0.4579, -0.8890 ];
I think it has S4 point symmetry, but better check.
Jim Buddenhagen ( jbuddenh at gmail dot com)
"James Buddenhagen" <jbu### [at] REMOVEtexas net> wrote in message
news:42403f71@news.povray.org...
> as possible.
> Jim Buddenhagen
In response to several people I made two images of the 20 vertex
polyhedron (whose dual was the yellow part of the original picture).
I think the rather large amount of perspective made it hard to
see there were 20 faces. Anyway, here are the two images.
The one with orthogonal perspective shows the symmetry better.
If I recall correctly there are 4 different edge lengths.
Jim Buddenhagen
Download '20met_orthog_web.jpg' (54 KB)
Download '20met1_web.jpg' (60 KB)
Preview of image '20met_orthog_web.jpg'
Preview of image '20met1_web.jpg'
>>>>Hash: SHA1
>>>>>as possible.
>>>Jim
Why don't you take the 20 points on the sphere as the vertices of a
regular icosahedron? In that case all the triangles aren't "as close to
equilateral as possible" but equilateral. The dual polyhedron is a
regular dodecahedron (as can be seen on my site and on many other
sites). For similar arrangments of more points in many cases one can use
the theory of geodesic spheres (domes). Also in povray a lot of examples
exist.
Herman Serras
news:4242fec1$1@news.povray.org...
[...snip...]
Because the regular icosahedron has only 12 vertices. It has 20 faces,
so one might try the centers of those faces for the 20 points, but that
fails also because the convex hull is then the reg dodecahedron which
does not have triangular faces.
> exist.
> Herman Serras
Jim Buddenhagen
> [...snip...]
>>exist.
>>Herman Serras
> Jim Buddenhagen
Shame on me! I must have been very confused.
Herman
I had never heard of such a thing. Interesting. Another interesting
experiment would be to go the other way ... to get as close to round as
possible with a limited number of exactly equilateral triangles.
As far as your image itself, I find the most interesting image of this
type to be the one which demonstrates complete understanding of the
shape. By that, I mean an image which is colored or carved in such a way
which demonstrates the craftsman's understanding of the nature of the
shape ( opposite faces, interesting symmetries, etc. ).
I have used similar shapes before, as we have discussed. I use these
shapes mostly as a mechanism for iteration of smaller sub-shapes. A
fourth dimension. That's another way to go.
-Shay
-Shay
