POV-Ray : Newsgroups : povray.binaries.images : Alpha On Corrupting HDRI Server Time
26 Aug 2025 23:20:51 EDT (-0400)
  Alpha On Corrupting HDRI (Message 1 to 10 of 10)
Subject: Alpha On Corrupting HDRI
Date: 17 Mar 2005 23:56:02
Message: <423a5f62@news.povray.org>
HDRI reflections go horribly wrong when I render with Alpha output, in
MegaPOV.  The HDRI image has a no_image tag on it and I'm rendering with
saved radiosity data.  Is this a known issue?  Are there workarounds or
fixes that I should know about?
Skip
Download 'eye.jpg' (129 KB)
Preview of image 'eye.jpg'
Subject: Re: Alpha On Corrupting HDRI
Date: 18 Mar 2005 00:35:10
Message: <423a688e@news.povray.org>
It's been pointed out by myself and at least a couple other people in the
past. The workaround is to use POV-Ray 3.5, but that's probably not an
option if you're using HDRI... =\
Still no word from the developers on this issue, unless I've missed it. I
took a brief look at the source code in 3.5 and 3.6 and didn't see any
differences in the places that I would have thought were relevant.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 18 Mar 2005 13:54:01
Message: <opsnuj4bjmd5227z@beastie.mshome.net>
Take alpha channel from bad image and add to good image using GIMP or
Photoshop?
Date: 18 Mar 2005 16:02:11
Message: <423b41d3@news.povray.org>
"Daniel S. Matthews" <dan### [at] 3-enet> wrote in message
news:ops### [at] beastiemshomenet...
> Photoshop?
won't do.  With alpha-output, the background is transparent, so anti-aliasing
will work on any background you put behind it.  With your combined method,
anti-aliased pixels will be a blend of the background color (probably black) and
the background-color, resulting in an annoying black (or other colored) edge
around your scene.
cu!
Date: 18 Mar 2005 16:45:39
Message: <d1fhu2$95b$1@chho.imagico.de>
You mean this is not a MegaPOV problem but also exists in official POV-Ray?
In any case could you point me to where the problem is clearly described
including a minimal test scene?
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 18 Mar 2005 21:33:57
Message: <423b8f95@news.povray.org>
POV-Ray?
Yes.
The minimal test scene would be any object with a bright pigment (rgb
<1,2,3> for instance) plus a light source. I believe the problem is that
POV-Ray is "normalizing" the colors before outputting them; that is,
dividing every color by its brightest component if any component is greater
than 1.
I think the last message to talk about this was "Problem with option +ua" in
this group on January 11, and my response to that message referenced two
earlier messages: "alpha output color problem" on 1/1/05, and "possible
bug?" on 11/28/04. Or just search for messages from me in this group
containing the word "alpha."
 - Slime
Date: 20 Mar 2005 04:20:02
Message: <d1jf24$oka$1@chho.imagico.de>
Thanks, the sample scene from Nicolas was very useful.  I am not yet
completely sure what is the best solution but the source of the problem
is identified.
Date: 20 Mar 2005 18:28:01
Message: <423e0701$1@news.povray.org>
> is identified.
Noticed you posted a bug report in povray.bugreports. I'm just curious why
you think that Compensate_For_Alpha_AA is the source of the problem? I had
also suspected that it was the source, but then I noticed that it didn't
change from POV-Ray 3.5 to 3.6.
Do you think that it worked wrong in 3.5 also, but it never caused a problem
because color clipping occured earlier in the process?
 - Slime
Date: 21 Mar 2005 10:01:18
Message: <423EE276.26C14E19@gmx.de>
> > is identified.
I tested it...
> I had
What's done in Compensate_For_Alpha_AA() is not really accurate
scientific method and therefore it is not working properly for all kind
of input values.  It is not yet decided what will ultimately be the
solution but of course there will be one.
-- Christoph
Date: 21 Mar 2005 12:07:00
Message: <423eff34$1@news.povray.org>
> I tested it...
Ah. How clever of you. =)
It seems to me that the correct thing to do is (a) treat the background as
rgb <0,0,0> (which I believe is already done) and (b) at the end, divide the
color by one minus the amount of transparency (if zero then just leave the
color as is). Are there cases where that doesn't work? The hardest thing, I
would think, is determining what the transparency value really is in the
case of things like emission media, but that seems to be handled already.
 - Slime
