POV-Ray : Newsgroups : povray.binaries.images : cylindrical pattern Server Time
14 Jul 2026 02:12:41 EDT (-0400)
  cylindrical pattern (Message 11 to 20 of 20)
Subject: Re: cylindrical pattern
Date: 15 Mar 2005 15:50:39
Message: <42374a9f$1@news.povray.org>
Christopher James Huff wrote:
> In article <4237206a$1@news.povray.org>, "Slime" <fak### [at] emailaddress>
> wrote:
>>Two solutions:
>> - rotate your cylindrical pattern to face along the z-axis with rotate 90*x
>> - use the spherical pattern instead of cylindrical
> Another solution: do the rotation in the call to the function. It's a 90
> degree rotation around one axis, so just swap two coordinates and negate
> one of them. Since you're generating an image for the height field, it's
> even easier to figure out...function images are sampled from the xy
> plane, the height field uses the image for the xz plane.
> function 1000, 1000 {F_Terrain(x, 0, y)}
That's cool, then I could use the same function for hf and its pigment,
just call each differently.
Date: 15 Mar 2005 17:25:12
Message: <cjameshuff-AEFA43.17251015032005@news.povray.org>
In article <42374a9f$1@news.povray.org>,
Another thing, it's possible that the function image feature uses the
upper left corner as the origin, with the y coordinate going down. I
hope that's not so, since it'd be confusing and unnecessary, but if so,
just use 1-y instead of y.
Christopher James Huff <cja### [at] gmailcom>
http://tag.povray.org/
Date: 15 Mar 2005 18:17:06
Message: <42376cf2$1@news.povray.org>
It does IIRC. I had a long discussion with Thorsten on this issue back in
the povray.pre-beta group, but he insisted it was the correct behavior.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 15 Mar 2005 18:25:16
Message: <42376edc$1@news.povray.org>
> back in the povray.pre-beta group, but he insisted it was the correct
> behavior.
Sorry, it was povray.beta-test:
http://news.povray.org/povray.beta-test/thread/%3C3cae24da%40news.povray.org%3E/?mtop=24
And I'm being reminded now that you were in the discussion too.
Rune
Date: 15 Mar 2005 18:37:59
Message: <423771d7@news.povray.org>
news:42376cf2$1@news.povray.org...
> Rune
Oh well so it is the correct behaviour.. ie
counter-intuitive-for-dummy-image-makers....
If it is good for developers, it must be good for us
Marc (We're not worthy, we're not worthy)
Date: 15 Mar 2005 20:19:04
Message: <cjameshuff-7D9647.20190215032005@news.povray.org>
In article <42376edc$1@news.povray.org>,
Yes, I remember that thread now. Looks like I should have followed up on
it...
Date: 16 Mar 2005 04:56:10
Message: <423802ba$1@news.povray.org>
"Marc Jacquier" <jac### [at] wanadoofr> wrote in message
news:423771d7@news.povray.org...
>> Rune
It's the proper behavior for sticking textures on "walls"... you just need
to rotate it for "floors" and "side walls", it's as good a default behavior
as any.
Date: 16 Mar 2005 12:32:33
Message: <42386db1$1@news.povray.org>
Tim Attwood wrote:
> ... you just need
No you need to translate if need the origin of the pattern used to
correspond to its native origin in any other context.  I am not
complaining, just pointing out that it is not only the rotate thing that
can fake you out.  The rotation confusion had to do with my own
misunderstanding that the syntax relates to this thing called a
"function image".  I thought it was specifically a variation on height
field syntax and so expected it would work without needing any
manipulation.  That was my mistake.  But the origin being at <0,1,0>
looks truly arbitrary.  Your mind is saying, "Okay, I guess that is just
how it works, so I will compensate."  But at the same time it is also
asking, "But am I misunderstanding something here?  Am I building on a
scaffold of misunderstanding?  Am I doing something wrong which is
causing this behavior?  If I compensate like this will there be even
greater confusion down the line"  Without Rune's post I couldn't answer
that.  Again, once you know what to do it is fine.
Date: 16 Mar 2005 12:45:09
Message: <423870a5$1@news.povray.org>
Thanks Chris, that's what I'll do.
Date: 16 Mar 2005 15:04:10
Message: <cjameshuff-43ED90.15040716032005@news.povray.org>
In article <423802ba$1@news.povray.org>,
> as any.
The use of the xy plane for image maps is. Putting the origin of the
function image coordinate system at < 0, 1> in the world coordinate
system is a different issue.
