POV-Ray : Newsgroups : povray.binaries.images : Leaf and cobbled street Server Time
13 Apr 2026 22:53:23 EDT (-0400)
  Leaf and cobbled street (Message 21 to 30 of 34)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Leaf and cobbled street
Date: 9 Mar 2005 14:09:06
Message: <422f49d2$1@news.povray.org>
This is a new cobbled street! That's why it doesn't look eroded ;)
I'll try to improve the texture of the leaf and stones. Thanks for the
comments!
Fernando
Xplo Eristotle wrote:
> Fernando G. del Cueto wrote:
>> This is only a part of my never-really-started project for Povcomp. I
>> managed to find some free time to implement some ideas. I used
>> Photoshop to change tones and fix some little details.
>> Hope you like it. Comments and suggestions are welcomed.
> Realistically, the cobbles should be worn smoother than this as they've
> had people/horses/wagons/cars/whatever on them for X years (and if
> they're old enough, lots of rain). And as someone else pointed out, some
> of the stones appear to be merging together. Other than that, they look
> great.
> That leaf could use some shine.
> -Xplo
Subject: Re: Leaf and cobbled street - update
Date: 9 Mar 2005 14:12:50
Message: <422f4ab2@news.povray.org>
This is the version with less post-processing... perhaps the texture of
the leaf looks a bit better...
I'm amazed of how much the image changes between my two monitors. I'm
wondering how does it looks in your monitors...
Fernando
> managed to find some free time to implement some ideas. I used Photoshop
Download 'leaf05c.jpg' (316 KB)
Preview of image 'leaf05c.jpg'
Date: 9 Mar 2005 15:16:39
Message: <422f59a7@news.povray.org>
> Fernando
Don't worry, it looks *very* nice. Love it ! But the leaf definitely has
a little disturbing something.
Very good work.
Regis.
Date: 9 Mar 2005 15:35:32
Message: <422f5e14$1@news.povray.org>
> Thanks Jim.
> The problem with the leaf is that I'm using a bicubic patch with an
> image/bump map of the leaf on it, with alpha channel for transparency.
> When I put some positive specular, the whole square patch shows up...
> Therefore I think I need to make it look more decayed perhaps...
> Fernando
>> Very nice.  Yes cobble stones tug at me too. These are great.  Maybe
>> it's the finish on the leaf that doesn't quite read for me?  Perhaps
>> either a little more gloss ormore apparent decay?  Go one direction or
>> the other?
No you can do what you want you need to use the image_pattern with a b/w
  profile or mask of the leaf as the image source.  You make two
textures which duplicate the pigment and bump references but which
differ in finish and transparency.
Date: 9 Mar 2005 17:08:49
Message: <422f73f1$1@news.povray.org>
With this level of JPEG compression, I'm hard pressed to tell this apart
from a photograph.
Nice one.
Date: 9 Mar 2005 17:32:17
Message: <422f7971$1@news.povray.org>
If I have one criticism it's that the cobbles appear to have a diagnoal
striation all aligned in the same direction.
I can't tell if it's deliberate or an artefact, but it shouldn't (IMHO) be
there.
Ray
Date: 9 Mar 2005 22:53:26
Message: <422fc4b6$1@news.povray.org>
I believe I'm doing what you're saying... the problem is that I can't
use neither reflection nor specular settings for the finish, as these
act on the whole patch, even those areas that are transparent... I don't
know if there is an easy workaround for this.
Or perhaps there is a way to give values to the specular using an image map?
Fernando
>> Thanks Jim.
>> Fernando
>>> or the other?
>  profile or mask of the leaf as the image source.  You make two textures
> which duplicate the pigment and bump references but which differ in
Date: 9 Mar 2005 22:56:05
Message: <422fc555$1@news.povray.org>
> there.
> Ray
You're a very perceptive person. I actually tried to diminish them with
postprocessing. In the unprocessed image, they are very noticeable. I
have to find the correct setting for the image map for the edges to be
not visible when tiling it.
Fernando.
Date: 9 Mar 2005 22:58:03
Message: <422fc5cb$1@news.povray.org>
Thanks for the compliment! The JPEG compression was set rather high, IIRC...
Fernando
> from a photograph.
> Nice one.
Date: 10 Mar 2005 03:09:25
Message: <423000b5@news.povray.org>
Hmmm  Actually I could not reproduce your problem
I put runnable sdl and maps in p.b.scene-files
but the relevant sdl looked like this:
         #local MyTex =
                         image_map {
                                 tga "im_oak.tga"
                 normal {
                         bump_map {
                                 tga "bm_oak.tga" bump_size 4
                 finish {
                         diffuse .7
                         specular .5
                         roughness .1
                         reflection 0
         bicubic_patch {
           type 1
            flatness 0.1
           u_steps 3
           v_steps 3
           <0, 1,  3> <1, 1, 3> <2, 1, 3> <3, 1, 3>
           <0, 1,  2> <1, 1, 2> <2, 1, 2> <3, 1, 2>
           <0, 1,  1> <1, 1, 1> <2, 1, 1> <3, 1, 1>
           <0, 1,  0> <1, 1, 0> <2, 1, 0> <3, 1, 0>
              image_pattern {
                 tga "ip_oak.tga" use_alpha
              texture_map {
                 [0
                         pigment { rgb 1 transmit 1 }
                         finish {
                                 diffuse 0
                                 specular 0
                                 reflection 0
                                 ambient 0
                 [1
                         MyTex
              scale 3
              rotate x*90
Download '001.jpg' (37 KB)
Preview of image '001.jpg'
