POV-Ray : Newsgroups : povray.binaries.images : nuclear explosion v0.2 Server Time
14 Apr 2026 00:53:27 EDT (-0400)
  nuclear explosion v0.2 (Message 4 to 13 of 33)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: nuclear explosion v0.2
Date: 8 Mar 2005 01:54:47
Message: <422d4c37$1@news.povray.org>
Big improvement! How exactly do you use AOI to create that effect? What sort
of surface is the texture on?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 8 Mar 2005 04:15:27
Message: <422d6d2f@news.povray.org>
Zeger Knaepen wrote:
> slightly better shape, and a better background :)
> but it took 10 minutes to trace this time
   Almost AWESOME ROLEX quality... I only miss the explosion lighting
the mountains, but that would need some magic.
   I second Skip and Slime requests for the explanation: it should be
really interesting to read...
Jaime
Date: 8 Mar 2005 04:45:01
Message: <d0jrvg$2nn$1@chho.imagico.de>
There is something wrong with the background - it is quite dark although
it seems to be a sunny day.  The explosion now is quite bright (which
probably is realistic but i lack the first hand experience here ;-))
So you would expect to see:
- the shadow of the explosion cast by the sun
- the light of the explosion cast on the surrounding.
Last updated 27 Feb. 2005 _____./\/^>_*_<^\/\.______
Date: 8 Mar 2005 05:05:01
Message: <web.422d77959e24cecb1186d1c30@news.povray.org>
Very good indeed.
But a 'bit' too small for a nuclear explosion ! normally, no more mountains
and no more earth..
agree
Rene
Date: 8 Mar 2005 05:49:20
Message: <1737603.GOMX6Qxvpa@raf256com>
Very photo-like, I would only change a bit shape of the "top"
btw, So, I see that topic of Americans attacking Iraq is popular in p.b.i
recently ;)
Rafal Maj Raf256
Date: 8 Mar 2005 06:11:59
Message: <422d887f$1@news.povray.org>
"Stefan Viljoen" <ryl### [at] polardcom> schreef in bericht
news:422d380b@news.povray.org...
> The right honourable Zeger Knaepen spake:
> > cu!
> Wow... how DID you do that?!
9500 spheres arranged in a mushroom-shape (with a lot of while-loops of
course :)) and seperated into a couple of categories: smoke, dust and 3
types of fire, all textured with a simple texture: something like:
(for the fire)
  aoi
  color_map {
   [0 rgb <1,.6,.4>*2 transmit 1]
   [.5 rgb <1,.6,.4>*2 transmit .75]
  poly_wave .75
 normal {bumps .5 scale .5 warp {turbulence .5 lambda 3}}
 finish {ambient .1 diffuse 1.5 brilliance 2}
cu!
ZK AKA Gaeriel
http://www.povplace.be.tf
"The door on your left. No, your other left!"
Date: 8 Mar 2005 06:15:12
Message: <422d8940$1@news.povray.org>
"Skip Talbot" <Ski### [at] aolcom> schreef in bericht
news:422d42e1$1@news.povray.org...
> That looks really, really good Zeger.  I mean that.
Thanks!
> I saw in your previous post that you are using AOI.  I thought about doing
> the same thing for modeling a large thunderhead.  Its very much faster
like
> you said, and modeling something like a thunderhead with media is just a
> headache waiting to happen.  How did you place your AOI sphere (or
whatever
> surfaces you are using to create the shape), by hand, some sort of macro?
Well, there are 9500 spheres, so clearly I didn't place them by hand :p
They're all randomly placed, within certain boundaries.  Each shape (the
head of the explosion, every shockwave and so on) is a collection of some
while-loops of 30 to 1000 spheres (according to the density of that part).
The next step is to make it animatable :)
cu!
ZK AKA Gaeriel
"Use the instrumentpanel, Luke!"
Date: 8 Mar 2005 06:18:27
Message: <422d8a03$1@news.povray.org>
"Slime" <fak### [at] emailaddress> schreef in bericht
news:422d4c37$1@news.povray.org...
> Big improvement!
I tried different things: one big shape with a texture_map, a couple of
blobs with different textures, a couple of merge's of spheres with different
textures and some union's of spheres with different texture.  Apparently the
overlapping surfaces you get with union instead of merge are vital to create
a believable gas-effect.
for the texture: see my reply to Stefan :)
cu!
ZK AKA Gaeriel
"If we ain't outta here in ten minutes, we won't need no rocket to fly
through space."
Date: 8 Mar 2005 06:22:08
Message: <422d8ae0$1@news.povray.org>
"jaime" <jai### [at] ignoranciaorg> schreef in bericht
news:422d6d2f@news.povray.org...
well, it actually should be possible... the lighting shouldn't be as
detailed as the mountains really are, so a simplistic model of the
mountains, textured with the background-image, could be used to simulate
lighting.
The only real problem is the shadow of the smoke and dust.  The whole
explosion has a no_shadow modifier, because otherwise it renders about 100
times slower :-/
I might be able to fake the shadow too...
Once it's animatable, I'll post the source :)
cu!
ZK AKA Gaeriel
"The ships hang in the air in exactly the same way that bricks don't."
Date: 8 Mar 2005 06:24:31
Message: <422d8b6f$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> schreef in bericht
news:d0jrvg$2nn$1@chho.imagico.de...
I had to darken it, or the explosion would have been too bright :p
I think it's still not bright enough to be realistic :)
working on that :)
should be possible, like I explained in reply to jaime :)
cu!
ZK AKA Gaeriel
"Train you will I. Train you I will. Yes! Step one: touch your tongue to
mine."
