POV-Ray : Newsgroups : povray.binaries.images : Effect on Render Rate of Radiosity Count and Error Bound Server Time
16 Oct 2024 12:18:36 EDT (-0400)
  Effect on Render Rate of Radiosity Count and Error Bound (Message 1 to 3 of 3)
Subject: Effect on Render Rate of Radiosity Count and Error Bound
Date: 26 Feb 2005 17:01:34
Message: <4220f1be@news.povray.org>
Pixels per second count increases along the z axis (or, the negative y
axis if you're using the left-hand rule).  Data set was generated by
taking the overall average pixel per second count of one render at each
setting.
Radiosity settings were:
   Brightness 1
   Count 1, 10, 100 and 1000
   Error Bound 1.0 through 0.1 at intervals of 0.3
   Gray Threshold 0
   Low Error Factor 0.8
   Minimum Reuse 0.015
   Nearest Count 6
   Recursion Limit 3
   ADC Bailout 0.01
   Pretrace Start 0.08
   Pretrace End 0.04
   Maximum Sample -1
   Always Sample On
   Media Off
   Normal Off
Render size was 800x600, antialiasing on with threshold of 0.1, 0
jitter, 2x2 rays, method adaptive recursive.
Computer is 1.5 GHz Celeron with 512 MB RAM.
Data set is:
            1    10    100   1000 count
err. 1.0 25295 24030 14563  3314
      0.7 22885 20025  9612  1612
      0.4 22885 16020  3907   393
      0.1 10225  6241   541    42
It'd probably be more accurate if I ran more tests and averaged them, as
well as increased samples.
Tim Cook
Version: 3.12
Download 'graph.jpg' (46 KB)
Preview of image 'graph.jpg'
Subject: Re: Effect on Render Rate of Radiosity Count and Error Bound
Date: 26 Feb 2005 17:24:21
Message: <4220f715@news.povray.org>
Thumbnails of the test renders.
Tim Cook
Version: 3.12
Download 'thumbs.jpg' (111 KB)
Preview of image 'thumbs.jpg'
Date: 26 Feb 2005 18:14:09
Message: <422102c1@news.povray.org>
Looks like a good Wiki-Pov candidate ...
Interesting data.
