POV-Ray : Newsgroups : povray.binaries.images : Radiosity problem solved (for the time being) - and looking ahead! Server Time
13 Aug 2025 04:58:20 EDT (-0400)
  Radiosity problem solved (for the time being) - and looking ahead! (Message 1 to 4 of 4)
Subject: Radiosity problem solved (for the time being) - and looking ahead!
Date: 20 Feb 2005 05:46:19
Message: <42186a7b@news.povray.org>
High!
Thanks to Mark's suggestions, I increased the recursion level to 3 and
downed the brightness (now it's 0.85). The result (first image attached
here) is quite convincing to me, but it took my poor old AMD K6-II-400 9
hours and 10 minutes (really time of a major system upgrade... I think
I'll go for an Athlon running at 1.8 GHz). So for tweaking, I chosed a
second radiosity setting, a modified version of Radiosity_Fast from
rad_def.inc (second image).
The third image (with modified Radiosity_OutdoorLight from rad_def.inc)
shows the whole building in its current state. Now I plan to place the
whole thing into a suburb of (pre-war?) Kabul... but unfortunately, I
lost the bookmark for those fantastic 3-arcseconds-per-pixel DEMs from
the last great Space Shuttle global mapping mission after a system crash
last month! I know it was on the USGS server, but USGS's web presence is
quite ramified and sometimes confusing in its structure...
See you in Khyberspace!
Yadgar
Now playing: Oscillations (Silver Apples)
Download '2005-02-19 khana-ye yadgar wip, take 2 (yadgar).jpg' (10 KB) Download '2005-02-20 khana-ye yadgar wip, take 5 (yadgar).jpg' (14 KB) Download '2005-02-19 khana-ye yadgar wip, take 4 (yadgar).jpg' (17 KB)
Preview of image '2005-02-19 khana-ye yadgar wip, take 2 (yadgar).jpg'
Preview of image '2005-02-20 khana-ye yadgar wip, take 5 (yadgar).jpg'
Preview of image '2005-02-19 khana-ye yadgar wip, take 4 (yadgar).jpg'
Subject: Re: Radiosity problem solved (for the time being) - and looking ahead!
Date: 20 Feb 2005 14:45:00
Message: <web.4218e8871b7f16efb31e6d870@news.povray.org>
As has been mentioned before, it really kind of bothers me that there is
more light hitting the ceiling than there is hitting the floor. That just
doesn't look right, and it seems very unlikely to ever happen in real life.
 - dan B hentschel
Date: 20 Feb 2005 17:45:04
Message: <421912f0$1@news.povray.org>
To me it seems very likely to happen in real life, especially if the light
source itself is exactly above the building and the sky itself doesn't emit
(indirect) light. There will be no direct light hitting the floor inside,
while the lit floor outside reflects onto the ceiling inside.
Date: 21 Feb 2005 03:35:39
Message: <42199d5b$1@news.povray.org>
> light source itself is exactly above the building and the sky itself
> doesn't emit (indirect) light. There will be no direct light hitting
> the floor inside, while the lit floor outside reflects onto the
> ceiling inside.
Especially with his "ground" that bright yellow.  In real-life most of the
time the ground is pretty dark compared to the blue sky / clouds.  Unless it
has been snowing, then you can tell the lighting is different inside.
