> -Mark (also like Mike Oldfield)
who doesn't :)
"Zeger Knaepen" wrote:
> who doesn't :)
Have you listened to any more than just the Tubular
Bells series? Also, I recommend a good stereo system.
Smoking pot would probably help as well.
Yadgar,
If you raise recursion you'll probably want to
lower brightness to compensate, but I'm going
on memory here...
smoking pot will solve all problems
"Renderdog" <slo### [at] hiwaay net> wrote in message
news:web.4216846aa984a05ce6a17f880@news.povray.org...
> > who doesn't :)
I have listened to almost everything he did including the rare stuff like Freggy
Went A-Courting and the extended versions of Moonlight Shadow, To France, Shadow
On The Wall and so on :)
cu!
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x) // ZK http://www.povplace.be.tf
> High!
> After several months, I revisited a project put to hibernation for a
> while... an indoor scene using radiosity (but with a strongly
> illuminated landscape outside). I tried the "Radiosity_IndoorLQ" settin
g
> form rad_def.inc, but modified it in some ways:
The result seems reasonable for the scene setup but this setup is not
realistic. The outside environment is too dark compared to the interior
(so you need to look at the finishes) and the ground is too bright
compared to the sky (it even seems like there is ambient finish on the
ground).
No matter if there is sunlight outside or not it would be realistic for
the windows to be completely overexposed if the corners of the room are
not completely black.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
High! ;-)
Yes, I admit that I in fact look like a prototypical 70s hippie (if
there wasn`t that overweight problem...) - but that doesn't necessarily
mean that I solve my rendering problems by using hemp products...
See you in Khyberspace!
Yadgar
Now playing: Legacy (Synergy) - what about that?
> interior (so you need to look at the finishes) and the ground is too
> bright compared to the sky (it even seems like there is ambient finish
> on the ground).
There is no ambient light at all, I set it to zero in the
global_settings. The sky is just a sky_sphere, so finish settings
wouldn't apply at all!
> for the windows to be completely overexposed if the corners of the
> room are not completely black.
Yes, that would be realistic for a camera - but the human eye adapts
differently to such light levels!
Yadgar
Now playing: Mercy & Truth (Blonker)
I am neither talking about a photographic camera nor the human eye here
- i am talking about light intensities. Radiosity calculates (and can
only calculate) the distribution of radiation in the scene. Whether you
process the image to look like a photograph or like how you think you
see such a scenery is up to you.
LMAO!!
WTF?!
More literally true of, say, Pink Floyd: Set the Controls for the Heart
of the Sun.
But you do not, in fact, have the light levels you anticipate, because
you're reproducing this scene on a monitor, which can't produce anything
near the kind of contrast ratios that occur in real environments. To get
the results you anticipate, you'd need a ridiculously powerful
projector, and the scene you'd need to output from POV-Ray (with 16-bit
channels, mind you) would probably appear much darker on a monitor
because of the extreme contrast.
You would probably be better off attempting to simulate a photograph
here, since your monitor can handle that.
-Xplo
