POV-Ray : Newsgroups : povray.binaries.images : Why does just this take a million years to render? Server Time
16 Oct 2024 14:45:01 EDT (-0400)
  Why does just this take a million years to render? (Message 1 to 8 of 8)
Subject: Why does just this take a million years to render?
Date: 15 Feb 2005 10:39:08
Message: <4212179c$1@news.povray.org>
// Persistence of Vision Ray Tracer Scene Description File
// File: IsoDessert.pov
// Vers: 3.5
// Desc: Tests using isosurfaces for landscapes
// Date: 2/15/2005
// Auth: Bryan Valencia
// ==== Standard POV-Ray Includes ====
#include "colors.inc"   // Standard Color definitions
#include "textures.inc"   // Standard Texture definitions
//#include "functions.inc"  // internal functions usable in user defined functions
#declare f_mymarble=function{pattern{marble turbulence 2.575}}
#declare f_mygranite=function{pattern{granite turbulence 1}}
#declare LandContour=function{
 y+f_mymarble(x/100,y/100,z/100)*100
 +f_mygranite(x,y,z)/10
isosurface {
  function { LandContour(x,y,z) }          // function (can also contain declared
functions
  contained_by { sphere{0, 1e3} }  // container shape
  //threshold 0.0                     // optional threshold value for isosurface [0.0]
  accuracy 0.01                      // accuracy of calculation [0.001]
  max_gradient 1                      // maximum gradient the function can have [1.1]
  evaluate 1, 1.2, 0.95             // evaluate the maximum gradient
  //max_trace 1                       // maybe increase for use in CSG [1]
  //all_intersections                 // alternative to 'max_trace'
  open                              // remove visible container surface
  pigment{gradient y}
#declare Place1=<0,100-clock*90,-100+clock*100>;
#declare Place2=<-clock,100-clock*90,-99+clock*99>;
camera{
 location Place1
 look_at Place2
light_source{<-10000,10000,0> color rgb 1}
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere { pigment {color rgb <0.7,0.7,1.0>} }
Subject: Re: Why does just this take a million years to render?
Date: 15 Feb 2005 11:21:42
Message: <E19yCCAZFiECFwQL@econym.demon.co.uk>
It seems reasonably fast for what it does. Complex isosurfaces are often
not very fast.
You can speed it up by a factor of about 3 by fitting a tighter
contained_by shape, like
  contained_by { box{<-1e3,-111,-1e3><1e3,0,1e3>} }
If it's important for it to have a circular horizon you can intersect it
with a sphere or cylinder. If you're lucky you may well be able to get
away without having to use max_trace which would eat into the speed
improvement.
Mike Williams
Gentleman of Leisure
Date: 15 Feb 2005 11:41:55
Message: <42122653$1@news.povray.org>
> // Vers: 3.5
> // Date: 2/15/2005
What is your definition of a year?
On my system it took 17minutes.
Maurice
http://get-me.to/Hendrix
Version: 3.12
GEd-s+:+aC++UL+PL+E-W++N++o--K-
wO---M-VPS+PEY+PGPt++++5--XRtv+
b+DI+D--Ge++h----y++++
Date: 15 Feb 2005 22:19:14
Message: <4212bbb2$1@news.povray.org>
Actually it did the sky in a jiffy, then it did 1 line every 4 minutes at
the horizon, and sped up a little after that.  At the time I posted, I had
just waited for the first few lines of the horizon, and cancelled, assuming
the whole isosurface would be as slow.
Also, I am confused as to why the 'land' all seems to be below y=0 when the
code is adding functions to y.
"Maurice" <cel### [at] nospamhotmailcom> wrote in message
news:42122653$1@news.povray.org...
> > // Vers: 3.5
> > // Date: 2/15/2005
> Maurice
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> ------END GEEK CODE BLOCK------
Date: 15 Feb 2005 22:36:13
Message: <pan.2005.02.16.03.36.12.850545@nospam.com>
Out of curiosity, what settings did you render with?
With no AA and at a resolution of 800x600, it rendered on my P4 2Ghz
laptop in just under 4 minutes under Linux (self-compiled POV-Ray build
running at niceness -20).
Jim
Date: 16 Feb 2005 01:25:31
Message: <RJv3tGASRuECFwRx@econym.demon.co.uk>
The surface exists at points where the whole function evaluates to zero.
The functions you added to y can take values between 0 and 100.1. So to
get the whole function to add up to zero, y must take values between 0
and -100.1.
E.g. suppose for some values of x, y and z
         f_mymarble(x/100,y/100,z/100) evaluates to 0.5
     and f_mygranite(x,y,z) evaluates to 0.5
then your LandContour surface exists where
         y + 50 + 0.05  =  0
So y must be -50.05
Mike Williams
Date: 16 Feb 2005 14:22:14
Message: <42139d66@news.povray.org>
My current version of this is on a 1GHz Pentium is taking 1H 3m.  The fun
part is that it's intended to be part of an animation.
Now I remember why I keep going back to heightfields.
"Jim Henderson" <nos### [at] nospamcom> wrote in message
news:pan### [at] nospamcom...
> Jim
Date: 16 Feb 2005 16:39:30
Message: <pan.2005.02.16.21.39.33.704360@nospam.com>
I know the feeling - I've been playing a lot lately with radiosity, focal
blur, and photos, and my renders are taking anywhere from an hour to (the
longest so far) 65 hours on the 2 Ghz system.
But the results are quite stunning. :-)
Jim
