POV-Ray : Newsgroups : povray.binaries.images : Tuning radiosity? Server Time
21 Mar 2026 15:47:27 EDT (-0400)
  Tuning radiosity? (Message 1 to 10 of 13)
Subject: Tuning radiosity?
Date: 14 Feb 2005 16:08:50
Message: <42111362@news.povray.org>
Hi all!
I'm learning how to use radiosity, so I've made a small image based on the
classic Cornell Box (see below)
I've used rather high quality settings (I think), roughly based on
Radiosity_OutdoorHQ in rad_def.inc . The render took more than 24h on my
poor 750 MHz PC and though, I think there are still some radiosity artifacts
on the image (especially between the toruses; also some kind of grainy
effect).
 I read the Povray docs several times, but I have a lot of difficulty
understanding how radiosity works precisely, in relation with the various
parameters. Could anybody help me find which parameter to tune to get a
better quality?
Luminous cylinders are ambient 2.8 diffuse 0
Walls are ambient 0 diffuse 0.98
Radiosity settings are:
    brightness       1.0
    count            500
    error_bound      0.1
    gray_threshold   0.0
    low_error_factor 0.5
    minimum_reuse    0.015
    nearest_count    7
    recursion_limit  3
    adc_bailout      0.0035
    max_sample       -1.0
    media            on
    normal           on
    always_sample    1
    pretrace_start   0.08
    pretrace_end     0.004
Thanks in advance!
Xavier
Download 'mycorn2.jpg' (135 KB)
Preview of image 'mycorn2.jpg'
Subject: Re: Tuning radiosity?
Date: 14 Feb 2005 16:35:01
Message: <web.42111850ddcdc699a3fcf12a0@news.povray.org>
>     count            500
Bump this up to somewhere between 800 and 1200
>     recursion_limit  3
In the scene you are using, you may be able to reduce this to 1 without any
noticeable sacrifice in quality, but it will likely reduce your render time
drastically.
 - dan B hentschel
Message: <web.4211187bddcdc6999b0dd50e0@news.povray.org>
>     brightness       1.0
>     count            500
>     error_bound      0.1
>     gray_threshold   0.0
>     minimum_reuse    0.015
>     nearest_count    7
>     recursion_limit  3
>     adc_bailout      0.0035
>     max_sample       -1.0
>     media            on
>     normal           on
>     always_sample    1
>     pretrace_start   0.08
>     pretrace_end     0.004
I don't see any artifacts. It looks very clean to me. Unless you are using
normals and media, I would turn them off; it is slowing you down and giving
you nothing (or next to it). I am not sure I understand the max_sample
-1.0; where did you come up with that?
As far as I am concerned it looks quite good. There might be a little
unevenness in the far bottom corner/edge, and to fix that you can either
raise your count, or raise your error_bound. I think your only real problem
is the normal and media settings, which are slowing things WAY down.
-S
5TF!
Date: 14 Feb 2005 16:48:48
Message: <42111cc0@news.povray.org>
Nice, I love this one, really neat. :-))
Date: 14 Feb 2005 17:17:28
Message: <42112378@news.povray.org>
42111cc0@news.povray.org...
Thanks LB! (already posted it last week on news.zoo-logique.org, maybe you
missed it :-) )
Xavier
Date: 14 Feb 2005 17:20:20
Message: <42112424$1@news.povray.org>
Thanks, will try just now!
Xavier
web.42111850ddcdc699a3fcf12a0@news.povray.org...
> >     count            500
> >     recursion_limit  3
any
time
> drastically.
>  - dan B hentschel
Date: 14 Feb 2005 17:29:52
Message: <42112660@news.povray.org>
giving
Actually, this is the default setting given by Moray, it is also the default
for Povray (I've just checked the documentation for that)
normal and media are also on by default, I will try to set them off.
problem
Thanks, I will try!
Xavier
Date: 15 Feb 2005 16:14:16
Message: <42126628$1@news.povray.org>
> missed it :-) )
> Xavier
So what ?! I can "officially" agree your work here too ! no ? ;-p
Date: 19 Feb 2005 02:10:02
Message: <cv6ohh$2ht$1@chho.imagico.de>
> Hi all!
> effect).
That render time seems reasonable with such a scene and these settings.
    You might try decreasing pretrace_end and low_error_count.  Also
might try the 'randomize' option from MegaPOV.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 20 Feb 2005 15:25:32
Message: <4218f23c$1@news.povray.org>
cv6ohh$2ht$1@chho.imagico.de...
 effect).
> Christoph
Thanks for the tips Christoph,
I don't have Megapov installed (and I don't think it is compatible with
Moray)
Anyway I've re-rendered a new version with better count and error_bound
settings (took 2.5 days!), there are less artifacts now and I'm happy with
the result.
Xavier
