POV-Ray : Newsgroups : povray.binaries.images : Oval Box Server Time
14 Apr 2026 00:45:16 EDT (-0400)
  Oval Box (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Oval Box
Date: 14 Feb 2005 14:18:03
Message: <4210f96b$1@news.povray.org>
"Ross" <rli### [at] everestkcnet> wrote in message
news:4210f67c$1@news.povray.org...
> very much so. great texture too. however, what are those artifacts on the
> bottom left corner of the lid? they look like they sort of continue all
> around the bottom edge of the lid, but are more noticeable on the left
> side.
Thanks!
...and, Hmmm...  I'm not sure.  I hadn't noticed that.  I thought those
might be j-peg artifacts, but they're in the original BMP image also.  I
wonder if they are a result of my isosurface-heightfield.  Maybe I need to
check my max-gradient or something (though I always thought that led to
black spots).
I'll have to fiddle around with it a bit more, and perhaps see if I missed a
warning in the code parser.
Jeremy
www.beantoad.com
Date: 14 Feb 2005 16:18:59
Message: <421115c3$1@news.povray.org>
Jeremy M. Praay wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
> news:4210db55@news.povray.org...
>>Beautiful.  Some really nice subtlties like the way the tacks sink into
>>the wood grain and the vertical drizzle of yellow.
>>So I take it you are combining UV mapping with procedural texture or did
>>you lay the texture down on the imagemap along with the strip shapes?
> UV-mapping?  Blasphemy!  ;-)
> It's all procedural.
Okay ;) I would have thought it odd if it wasn't but I just wanted to be
sure.  I think to be fair, if you use the hf_cylinder macro you are
using a type of uv mapping implicitly, in the sense that a uv space is
being projected, which is what I meant.
I think I used about 5-6 layers of texture to create
> the wood.  Actually, I have nothing against uv-mapping, but I generally find
> it easier (and more fulfilling) to use procedural unless I'm dealing with
> something where pictures/drawings are involved.
Well the fine grain of the wood is *extremely* convincing whatever the
case. So you are using a texture like granite or crackle which works the
same in all dimensions and so appears to wrap very well, especially on
regular shapes.  This is also my preferred solution.  Are you applying a
normal too it looks like?
But you are dealing with drawing aren't you?
  But I don't want to paint
> myself into a corner, either.  Playing around with Gilles' Mini Cooper demo
> taught me a lot about how to use heightfields in conjunction with
> photographic textures, and some day I may make use of that.  For example,
> it's difficult (though not impossible) to produce "wear" in the proper
> places by using procedural textures.  But I digress...
Yeah I was just playing with putting functions into hf's myself in the
hope of speeding up the isowood.inc for limited applications or for
testing, but the way the pattern gets transformed when applied to the hf
object is fairly mind-bending. ie it seems to automatically rotate the
wood pattern to align it with the vertical. Incidently I don't know if I
am experiencing a "senior moment" but I could not find where it is
covered in the official docs, how to apply functions to hf's.  I had to
go rummaging through old files to remember.
> To make the fingers have a different texture than the wood that they are
> tacked onto, I simply made a cylinder slightly larger than most of the
> heightfield cylinder (technically an isosurface) and said "translate x*20"
> for the texture.  I experimented with more complex solutions ("cylindrical"
> pigments), but that was the simplest solution.
> I had a difficult time forcing myself to use a heightfield, and I actually
> produced a version that was pure CSG.
How?  You are still dependent on the image_map to displace the "fingers"
are you not?  I can picture uv mapping the image to a cylinder, and I
can picture making the image a function and displacing an iso's surface
with it, but I can't picture doing both.
  But with the heightfield, I was able
> to make the tack holes, and then place the tacks in them one at a time, as
> well as to make the "fingers" a little bit round.  Basically, it was about
> the same process that I used for my old radios (the "face-plates" were all
> heightfields), except wrapped around a cylinder.  Anyway, I think it makes
> for a more realistic object, while keeping all of the benefits of using CSG.
Well it is a very cool result and it stands up to magnification very well
Date: 14 Feb 2005 19:06:56
Message: <42113d20$1@news.povray.org>
"Jeremy M. Praay" <jer### [at] questsoftwarecom> wrote in message
news:4210f96b$1@news.povray.org...
>> side.
> Maybe I need to check my max-gradient or something (though I always
> thought that led to black spots).
Increasing the max_gradient only made more spots appear, which had me
puzzled for a bit.  Eventually, I realized that it was creating a ring
around the object (like Saturn), and it just so happened that it was right
along the bottom, which corresponded to the bottom of the
pigment-image_map-heightfield-thing.  Adjusting "contained_by" by an
extremely small fraction fixed it.
I guess it was something similar to a coincident surfaces problem.
Jeremy
www.beantoad.com
Date: 14 Feb 2005 19:56:16
Message: <421148b0@news.povray.org>
news:421115c3$1@news.povray.org...
> sure.  I think to be fair, if you use the hf_cylinder macro you are using
> a type of uv mapping implicitly, in the sense that a uv space is being
Ahh.  Ok, then.  I'll forgive the heresy.  ;-)
I actually looked at the hf_cylinder macro, and it scared me, so I simply
used a isosurface-pigment-image_map-thing.  I have no idea how to refer to
it, but it's something I've used before, so it was easy to adapt.  I think
Christoph Hormann does something similar in some of the iso_csg library
macros (IC_HF_Cylinder).
>> find it easier (and more fulfilling) to use procedural unless I'm dealing
>> with something where pictures/drawings are involved.
Yep.  Granite, bozo, agate.  Then I generally just stretched them in one
direction or the other.  For the lid, I also used a warp {repeat 2*x flip
<1,0,0>} on each layer, and rotate it slightly (before the warp).  It's
something I figured out a long time ago, and haven't modified much since.
It makes nice veneer too, but it can also create the appearance of a wood
cross-section without using "wood."
<snip>
>> x*20" for the texture.  I experimented with more complex solutions
>> ("cylindrical" pigments), but that was the simplest solution.
>> actually produced a version that was pure CSG.
> are you not?  I can picture uv mapping the image to a cylinder, and I can
> picture making the image a function and displacing an iso's surface with
I should probably restate that.  I had a cylinder for the box, then I
created the fingers by differencing cylinders (turned 90 degrees) from a
cylinder (the same size as the box) and then unioning the box-cylinder with
the differenced (fingers) cylinder and translating the differenced one
slightly -z, so that the fingers would stick out.  But then I realized that
rounding the differenced parts was nearly impossible, and without some
rounded edges on the fingers, it just didn't look right, so I gave up on
that, and turned to heightfields, which up to that point, I hadn't used.
To be technically correct, the rounded edges (on top of the lid) which you
see now are actually the Round_Cylinder_Union.
I think I'll add the source to the pov-ray wiki, though I might want to
clean it up a little bit first.
Jeremy
www.beantoad.com
Date: 14 Feb 2005 20:13:24
Message: <42114cb4$1@news.povray.org>
Woah, I own one of those.  This is a pretty good reproduction, with a
particularly nice job on the wood texture.  Nice work.
Date: 14 Feb 2005 20:43:47
Message: <421153d3$1@news.povray.org>
Okay, so you are doing the thing I couldn't picture.  I'd forgotten
about the IC_HF_Cylinder() macro in iso_csg. ( It does tend to confuse
the term heightfield or hf which I normally would use to mean mesh. )
My mistake.   So that makes my reference to UV space implicit only in
the fact of the image_map keyword and that's about it.  I'll shutup now.
Yeah, after I posted I realized what you meant.  Duh.
Date: 14 Feb 2005 22:05:01
Message: <web.421166c4f8cea3c16e93bf990@news.povray.org>
Excellent work. My father and I have made hundreds of these from size 000 to
9. The wood is excellent.
On those that we make, the pins holding the top and bottoms inside their
respective bands are made of wood. Also, the small nails used to form the
bands are copper.
Those are just nit picking, because I think you work is fantastic.
Tim
Date: 15 Feb 2005 12:15:00
Message: <web.42122d18f8cea3c18bf73c810@news.povray.org>
"Jeremy M. Praay" <jer### [at] questsoftwarecom> wrote:
> Modelled after the oval boxes that were produced by the Shakers.  I really
> like playing with wood textures, though the "wood" keyword was never
> actually used in any of these textures/pigments.  :-)
> CSG with isosurfaces with an image_map pigment to create the appearance of
> overlapping strips (basically, just like a heightfield wrapped around a
> cylinder).
> Jeremy
> www.beantoad.com
Man, go away for a few weeks, come back, and find that now you, also, have
made a faux POV (pho-POV?) (a detailed photograph that you try to pass off
as a POVRay creation.)
That's absolutely fantastic.
Dave Matthews
Date: 15 Feb 2005 14:24:44
Message: <42124c7c@news.povray.org>
"Tim McMurdo" <jod### [at] wohrrcom> wrote in message
news:web.421166c4f8cea3c16e93bf990@news.povray.org...
> Excellent work.
Thanks!  :-)
> bands are copper.
I have a couple of books that I used for reference photos, both of which had
lots of new boxes, as well as Shaker antiques.  I tried to create a box that
looked the way a new box may have appeared circa 1850's.  To do that, I
combined some things from the old and the new.  I did notice that most (or
at least some) of the new boxes used the wooden pins, but most of the older
boxes used metal tacks, as far as I could tell.
Some quick Googling makes me think you're right about the copper tacks.  I
should change to a copper color.  Also, I see a lot of antique boxes with
what appear to be wooden pins/tacks for the fingers.  I wonder if their
methods switched at some point.
Jeremy
www.beantoad.com
Date: 15 Feb 2005 19:23:12
Message: <42129270$1@news.povray.org>
Jeremy M. Praay nous apporta ses lumieres en ce 2005-02-14 19:05:
>>>side.
I got something similar with a blob with a thressold of 0.
