POV-Ray : Newsgroups : povray.binaries.images : Antennas & missing cable (see povray.newusers) Server Time
13 Apr 2026 22:53:45 EDT (-0400)
  Antennas & missing cable (see povray.newusers) (Message 1 to 5 of 5)
Subject: Antennas & missing cable (see povray.newusers)
Date: 5 Feb 2005 16:41:04
Message: <42053d6c@news.povray.org>
As illustration to a discussion in povray.newusers (Laying cables)
Download 'pa13r-ongrass.jpg' (49 KB)
Preview of image 'pa13r-ongrass.jpg'
Subject: Re: Antennas & missing cable (see povray.newusers)
Date: 8 Feb 2005 20:57:38
Message: <42096e12@news.povray.org>
very nice... but generaly, that 's the other side of plug which is useful...
42053d6c@news.povray.org...
Date: 9 Feb 2005 11:46:32
Message: <420a3e67@news.povray.org>
> useful...
Eh?
Je suis desolee, mais peut etre je ne comprends pas le rigole ici :-)
J'ai model'ee le fiche completement, avec tout les details interieur. Si je
faites une "zoom" au fiche "N" on peut voir tout les details :-)
I am veryy sorry, but I do not get the joke. The connectors are installed on
the splitter and the antennas, it just waits for the cables - which I have
problems with.
The connectors are fully modelled, i.e. with all the internal details. I can
zoom in and you can see the small parts on the inside... if you want to :-)
Ekki
Date: 9 Feb 2005 23:08:54
Message: <420ADE5B.9050803@nomail>
Ekki, I'm guessing that Rune's Inverse Kinematics might help you:
http://runevision.com/show.asp?id=97
You specify a start point, an end point and the vectors at each of those
points. Here's an example scene
__SCENE__
// INVERSE KINEMATICS CABLE INCLUDE FILE: SAMPLE FILE
// This scene shows how to make a cable using Rune's
// Inverse Kinematics Include file.
global_settings {
   assumed_gamma 1.0
#declare yCam = camera {
   location  <2.0, 14, -4>
   direction 1.5*z
   look_at   <2.0, 0.0,  2.0>
#declare zCam = camera {
   location  <0.0, 3, -14>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
#declare xCam = camera {
   location  <-14, 3, 0>
   direction 1.5*z
sky_sphere {
     gradient y
     color_map {
       [0.0 rgb <0.6,0.7,1.0>]
       [0.7 rgb <0.0,0.1,0.8>]
light_source {
   <0, 0, 0>            // light's position (translated below)
   color rgb <1, 1, 1>  // light's color
   translate <-30, 30, -30>
plane {
   y, -2
   pigment { color rgb <0.7,0.5,0.3> }
// CABLE PARAMETERS
    #declare ikn_p1 = 0;         // Startpoint of cable
    #declare ikn_z1 = y;        // Forward vector at startpoint
    #declare ikn_y1 = z;         // Up vector at startpoint
    #declare ikn_p2 = <4,3,3>; // Endpoint of cable
    #declare ikn_z2 = x;         // Forward vector at endpoint
    #declare ikn_y2 = y;         // Up vector at endpoint
    #declare ikn_twist = 0;      // Attempted twisting.
    #declare ikn_radius1 = 0.2;  // Radius at startpoint
    #declare ikn_radius2 = 0.2;  // Radius at endpoint
    #declare ikn_length = 8;   // Length of cable
    #declare ikn_links = 400;    // Number of links in cable
// TEXTURE FOR THE CABLE:
    #declare CableTexture =
       pigment { Yellow }
       finish {phong 1}
// STIFFNESS VALUES FOR CABLE:
    #declare ikn_stiffness1 = 2; // Relative stiffnes at startpoint
    #declare ikn_stiffness2 = 1; // Relative stiffnes at endpoint
// INCLUDE IKN.INC:
    #include "ikn.inc"
// CREATE CABLE:
    #declare Cable =
    union {
       #declare C = 0;         // Start at link 0...
       #while (C<=ikn_links-1) // ...and run through all links.
          #declare T = C/(ikn_links-1); // Goes from 0 to 1 along the cable.
          sphere {                      // Make a sphere...
             0, 1
                CableTexture
//             Translate the texture this way for UV texturing:
//             (that formula work well for most cables)
                translate -z*T*ikn_length/(ikn_radius1/2+ikn_radius2/2)
             scale ikn_r[C]             // ...and scale it...
             transform ikn_transform[C] // ...and transform it
automatically.
          #declare C = C+1;
// Some simple plugs:
cylinder {
	<0,-1,0>
	<0,0,0>
	0.4
	pigment { Grey }
cylinder {
	<4,3,3>
	<5,3,3>
	0.4
	pigment { Grey }
object {Cable}
// Try all three cams -- as per sample image
camera{ yCam }
Download 'cables.jpg' (51 KB)
Preview of image 'cables.jpg'
Date: 10 Feb 2005 13:13:19
Message: <420ba43e@news.povray.org>
Excellent! Many thanks, that looks exactly like what I was looking for.
Unfortunately my other hobby takes over for this weekend, so I cannot try it
out until next week... I will come back with result.
Again thanks.
Ekki
