POV-Ray : Newsgroups : povray.binaries.images : Boli (29 Kb) Server Time
21 Mar 2026 17:14:12 EDT (-0400)
  Boli (29 Kb) (Message 1 to 10 of 13)
Subject: Boli (29 Kb)
Date: 5 Feb 2005 11:23:01
Message: <4204f2e5@news.povray.org>
Blobs and procedurals
Bamana people, Boli altar figure, organic materials
Download 'img.1032.jpg' (29 KB)
Preview of image 'img.1032.jpg'
Subject: Re: Boli (29 Kb)
Date: 5 Feb 2005 12:40:27
Message: <Xns95F4BDEBC4B2raf256com@203.29.75.35>
jrc### [at] msncom news:4204f2e5@news.povray.org
Very realistic :)
What was formula of distortion of surface? Somethinkg like
+f_crackle(x,y,z) ?
http://www.raf256.com/3d/
Computer Graphics
Date: 5 Feb 2005 18:28:09
Message: <42055689$1@news.povray.org>
> Very realistic :)
Thanks.
> +f_crackle(x,y,z) ?
Based on crackle yes but I defined the function on a pigment so I could
use the pigment_map to manipulate the profile. Leaving out the
turbulence manipulators*, the main idea was this:
Two instances of the crackle at scale .6 are averaged.  One is a map of
tones designed to raise the edges of the cells to form "flakes", the
second is a map of scaled down instances of crackle. Their scale changes
across the cell of the larger crackle with the scale getting smaller
towards the "raised" edge of the "flake".  Also the inner crackle cells
are toned to form humps rather than hollows.
function {
   average
   pigment_map {
     [1
       crackle
       scale .6
       pigment_map {
         [0 rgb 0]
         [.1 rgb 0]
         [.3 rgb 1]
         [1 rgb .5]
     [1
       crackle
       scale .6
       pigment_map {
         [0 rgb 0]
         [.1 rgb 0]
         [.3
	  crackle
           scale .15
           pigment_map {
            [0 rgb 0]
            [.1 rgb 0]
            [.3 rgb .5]
            [1 rgb 1]
         [1
	  crackle
           scale .45
           pigment_map {
            [0 rgb 0]
            [.1 rgb 0]
            [.3 rgb .5]
            [1 rgb 1]
*generally like:
turbulence .35
octaves 4
lambda 2.1
omega .55
Date: 6 Feb 2005 15:30:01
Message: <web.42067d99152825da455988290@news.povray.org>
That is nice. If it was real I would buy it if I could afford it :-)
It reminds me of statues I have seen in the Iraklion museum in Crete, the
shape and weathering.
Date: 7 Feb 2005 09:56:37
Message: <420781a5$1@news.povray.org>
news:4204f2e5@news.povray.org...
Very nice, Jim!
The cracks are just pigments and normals?  No isosurfaces?  If so, they are
incredibly realistic normals.
I tried something similar with iso-surfaces awhile ago, to produce a desert
scene.  This effect is much more realistic than what I used. I should see
what I can do with that.
Jeremy
www.beantoad.com
Date: 7 Feb 2005 12:59:23
Message: <4207ac7b@news.povray.org>
Jeremy M. Praay wrote:
> "Jim Charter" <jrc### [at] msncom> wrote in message
> Very nice, Jim!
Thankyou.
The ultimate intention is to do it with isoblobs and real displacement
based on the texture.  In fact I first modeled the figure in isoblobs
using iso_csg,  and I do have an early render with a displacement using
a granite texture (attached),  but I switched to regular blobs and
normals for development purposes.  I tried one overnight render with
this complex texture but I was very slow.  I was using the adaptive max
gradient like a good little doobie which is probably why.  I expect I
can get good results cheating on the max gradient but it will still be a
long render so I am trying to put together a little nicer setting to go
along with it.
Here is some picture of Boli
http://www.hamillgallery.com/BAMANA/BamanaBoli/BamanaBoli04.html
Here the fissures have more of a crevice quality which should be a
relatively easy effect.  The one I was studying in the Metropolitan
Museum, however, shows more of a flaking effect with the edges at the
cracks scalloped outward more.
Download 'img.1018.jpg' (17 KB)
Preview of image 'img.1018.jpg'
Date: 7 Feb 2005 15:55:42
Message: <4207d5ce$1@news.povray.org>
news:4207ac7b@news.povray.org...
> along with it.
Googling also gave me this link, if you're interested in other photographic
references: http://www.randafricanart.com/Henfrey_Boli.html.
I can see both types of surfaces here.  Judging from these (at the bottom of
the page, esp.), your attempt at the texture of the surface seems really
good.  Is that one from the MMOA the same one that you were looking at (near
the bottom of the page)?
The texture of your original also makes me think of brownies.  It seems to
be a great multi-purpose surface texture: paint coming off walls, desert
mud, etc.  I may have to play around with the code you supplied.  :-)
Jeremy
www.beantoad.com
Date: 7 Feb 2005 15:57:12
Message: <4207d628$1@news.povray.org>
Is there something symbolic about the use of blobs? The creation of an
icon from readily available "materials"? Looks a lot more like blobs
than clay to be honest.
Texture is really incredible.
  -Shay
Date: 7 Feb 2005 16:11:34
Message: <4207d986$1@news.povray.org>
>>along with it.
Wow!  That link pretty much sums it up.  Yes that must be the one, there
is only one on display anyway and the largesh head and relatively stubby
legs compared to others looks right.  It is the opposite aspect that is
on dislap in the case however.  But I feel so vindicated.  That link
does show that some have a more crusty look, others more doughy.
One vital thing I omitted there was that I am applying a poly_wave .25 -
.35  And as I think I footnoted, I reduced the octaves to 4 and
compensated by increasing lambda and omega slightly
Date: 7 Feb 2005 16:13:52
Message: <4207da10$1@news.povray.org>
No just th obvious thing, getting a little OD'd
on mesh.
The creation of an
I don't think they are clay, not sure what is underneath but the overall
effect is like of very smooth transitions like layers over smoothing
layer of paint or something.
tanks
