POV-Ray : Newsgroups : povray.binaries.images : Makeshift Shelter Server Time
28 Dec 2025 21:59:07 EST (-0500)
  Makeshift Shelter (Message 1 to 9 of 9)
Subject: Makeshift Shelter
Date: 27 Jan 2005 15:34:06
Message: <41f9503e@news.povray.org>
This is 3 sides of a cube turned into a shelter on a very hot alien world.
I had to use trial and error (because my math skills are lacking) to figure
out how much to rotate and translate my box{-1,1} to make the cube sit
correctly on the plane{y,0}  Can someone 'splain the math for me?
Download 'cubist.jpg' (132 KB)
Preview of image 'cubist.jpg'
Subject: Re: Makeshift Shelter
Date: 27 Jan 2005 15:47:28
Message: <41f95360$1@news.povray.org>
Not really math, but this might help:
camera { location <5,1,8> look_at 0 }
light_source { 50 rgb 1 }
plane { y, 0 pigment { rgbt <1,1,1,.5> } }
plane { x, 0 pigment { rgbt <0,1,0,.5> } }
plane { z, 0 pigment { rgbt <0,0,1,.5> } }
difference
         box { <1,0,1>, <-1,2,-1> }
         box { <1,0,1>, <-1,2,-1> translate <.1,-.1,.1> }
         translate <1,0,1>
         rotate y*-45
         translate <0,0,-1>
         rotate x*45
         pigment { rgb <1,0,0> }
Greetings,
Maarten
Date: 27 Jan 2005 15:56:36
Message: <41f95584$1@news.povray.org>
Of course... It's all so simple now...  My mind was stuck on the object
center remaining at the origin.
"Maarten Boonen" <m44### [at] yahoocom> wrote in message
news:41f95360$1@news.povray.org...
world.
figure
> Hi,
> difference
>          translate <1,0,1>
>          rotate y*-45
>          translate <0,0,-1>
>          rotate x*45
> Greetings,
> Maarten
Date: 27 Jan 2005 18:21:09
Message: <41f97765$1@news.povray.org>
Bryan,
I love that scene.  As an avid SciFi reader, your image invokes worlds of
possibilities.  Your shelter has that great look of "it doesn't belong
there" as one would expect.  Somehow the sand plane looks a little flat.
What kind of texturing are you using?
Neil
"Bryan Valencia" <pov### [at] spamgourmetcom> wrote in message
news:41f9503e@news.povray.org...
> figure
Date: 27 Jan 2005 21:49:56
Message: <41f9a854$1@news.povray.org>
"Neil Kolban" <kol### [at] kolbancom> wrote in message
news:41f97765$1@news.povray.org...
> Bryan,
> I love that scene.
Thanks!
#declare LandTexture= texture{
  pigment{color rgb<1,1,.5>}
  normal{
   marble 2 turbulence 1.125
  scale .5
> Neil
Date: 28 Jan 2005 02:16:38
Message: <41f9e6d6$1@news.povray.org>
Neil Kolban wrote:
> Bryan,
I agree Neil, and the fact that it's not a typical geodesic tent shape that
human explorers would probably use gives it that alien feel. I'm already
wondering what kind of beings do use it, why are they there, and where is all of
their stuff.  Did they meet something that didn't agree with them, or something
that agreed with them so well it had them for dinner. :)
I'm new to POVray and so I've not played much with advanced textures on my own.
   So I'm not sure how one would make the shadow of the shelter interact with
the pattern of the sand.  Right now it doesn't and that gives the "flat" feeling
IMHO.  Would a bump map help provide depth? or maybe darkening the shadows with
a colormap?
Tony
Date: 28 Jan 2005 06:05:25
Message: <41fa1c75$1@news.povray.org>
Tony nous apporta ses lumieres en ce 2005-01-28 02:16:
> my own.   So I'm not sure how one would make the shadow of the shelter
> interact with the pattern of the sand.  Right now it doesn't and that
> gives the "flat" feeling IMHO.  Would a bump map help provide depth? or
> maybe darkening the shadows with a colormap?
> Tony
If you want the shadows to follow the curve of the ground, the ground need to actualy
have some
relief. When you use a normal, the surface remains flat. You need to use an
"isosurface" with the
surface replaced with an actual displacement of the surface.
You need something like this sample:
isosurface{function{y-F_turb3d[x/ScaleX,0,z/ScaleZ)*Amplitude}
contained_by{box{<10,1,10>,<-10,-1,-10>}
texture{Your_texture}
Date: 28 Jan 2005 23:39:40
Message: <41fb138c@news.povray.org>
That's not quite right! It over-rotates.
The following snippet is geometrically correct and illustrates the point.
#declare Chrome = texture { T_Chrome_3C }
#declare Gold   = texture {    T_Gold_1A}
plane { y, 0 texture {Gold} }
#declare thing = difference
         box { <1,-1,1>, <-1,1,-1> }
         box { <1,-1,1>, <-1,1,-1> translate <  .05, -.05,  .05> }
         texture {Chrome}
object {                 // rotations in global coordinate space
  thing
  rotate -45.0*y
  rotate sqrt(3/2)*45*x  // x component
  translate <0, sqrt(1/3), 0>
  rotate -50*y
If you think about it as a series of transformations, the first rotation is
easy, but now the x axis is'nt where it was. It's rotated through 45 so you
must now figure the component of x to rotate in your global coordinate
system. Pythagoras is enough to get the ratios with the square roots.
DLM
>> world.
>> figure
> Hi,
> difference
>         translate <1,0,1>
>         rotate y*-45
>         translate <0,0,-1>
>         rotate x*45
> Greetings,
> Maarten
Download 'box2.jpg' (42 KB)
Preview of image 'box2.jpg'
Date: 29 Jan 2005 00:11:16
Message: <41fb1af4$1@news.povray.org>
>> on my own.   So I'm not sure how one would make the shadow of the
>> shelter interact with the pattern of the sand.  Right now it doesn't
>> and that gives the "flat" feeling IMHO.  Would a bump map help provide
>> depth? or maybe darkening the shadows with a colormap?
>> Tony
> need to actualy have some relief. When you use a normal, the surface
> remains flat. You need to use an "isosurface" with the surface replaced
> Alain
Alain,
Thanks for the tip.  I have some images of my own that I'll use it on.  Someday
I hope to understand it. :)
Tony
