POV-Ray : Newsgroups : povray.binaries.images : Last post Server Time
15 Aug 2025 07:08:13 EDT (-0400)
  Last post (Message 1 to 4 of 4)
Subject: Last post
Date: 13 Jan 2005 00:54:27
Message: <41e60d13@news.povray.org>
I won't post again, until it's finished! :)
ToDo:
Control cables
Joystick
Rudder Pedals
MidWing Mount
Landing Struts
Inter-Plane wing (between wheels)
[wheels are actually already finished but not shown]
Shock for tail strut
Spandaus and ammo belts
Engine mounting
Wing skids
Seat
Fuel Tank
Cockpit coaming
Engine
Prop (the hardest part)
Covering
Although it sounds like a lot of work I think it will go quickly now.
- Grim
Download 'Minutae4.jpg' (116 KB)
Preview of image 'Minutae4.jpg'
Subject: Re: Last post
Date: 13 Jan 2005 09:50:56
Message: <41e68ad0$1@news.povray.org>
GrimDude wrote:
Did you figure out how to stretch the fabric over the wings?
  -Shay
Date: 13 Jan 2005 14:49:08
Message: <41e6d0b4$1@news.povray.org>
Yeah, I figured out three different methods. The method that requires the
least amount of work (even though it uses more memory) is probably what I'll
use. Initially this will be a mesh model and then I'll convert it to POV
primitives. I wanted to finish an entry for povcomp, but since I just got
hit with a big A.R. job I doubt I'll make the deadline (my reason for using
AutoCAD). Normally I frown on this approach preferring pure POV instead.
AutoCAD source is currently 23Megs with a low polygon count, but peaks over
40Megs when I smooth it. I expect it will peak beyond 100Megs when
completed.
- Grim
Date: 13 Jan 2005 17:43:44
Message: <41e6f9a0$1@news.povray.org>
I can't wait to see it finished Grim.  My airplane projects were my favorite
(and most labor intensive).  I think you are right on with your mesh size
estimate.  My long-ez model came in at just under a 100 I believe.
Skip
