POV-Ray : Newsgroups : povray.binaries.images : Problem with option +ua Server Time
18 Feb 2025 17:36:36 EST (-0500)
  Problem with option +ua (Message 1 to 7 of 7)
Subject: Problem with option +ua
Date: 11 Jan 2005 16:27:27
Message: <41e444bf@news.povray.org>
Hi Guys,
I'm trying to re-make an old scene with a transparent background and
after trying different things, I realised that I was not getting the
same output depending on the use of the +ua option or not. I attached a
minimal scene with the two images.
Do you get the same ? Is it the expected behaviour ? And if so, what is
the explanation please ?
Nico
// povray +Iscene.pov +fn      +oscene.png
// povray +Iscene.pov +fn +ua  +oscene-ua.png
   location  <0,0,-3>
   look_at  0
   direction 1.5*z
#macro Glow(Color)
   media {
     emission 1
     density {
       spherical
       poly_wave 5
       density_map {
         [0 rgb 0]
         [1 rgb Color]
     method 3
box {-10, 10 hollow}
sphere {
   0, 1
   hollow on
   pigment {rgbt 1}
   interior {Glow(<1.0, 0.1, 0.2>*44)}
Download 'scene.png' (18 KB) Download 'scene-ua.png' (18 KB)
Preview of image 'scene.png'
Preview of image 'scene-ua.png'
Subject: Re: Problem with option +ua
Date: 11 Jan 2005 17:38:40
Message: <41e45570@news.povray.org>
This is probably the same problem that I was having in the thread "alpha
output color problem" on 1/1/05, and that Zeger Knaepen mentioned in the
thead "possible bug?" on 11/28/04.
In short, the developers haven't commented on the issue yet (so there's no
news on whether it's a bug or intended behavior, hopefully the former). But
version 3.5 didn't have this problem, so if you're not depending on any of
the changes in version 3.6, then you can use version 3.5 for your
alpha-output images.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 12 Jan 2005 04:05:30
Message: <41e4e85a$1@news.povray.org>
Ok, thanks, I will use version 3.5 then.
What is weird though with version 3.6 is when you add a dummy radiosity
block like:
global_settings {
   radiosity {
	pretrace_start 0.08
	pretrace_start 0.01
You can clearly see that the image is ok during pretrace but then, the
final trace goes wrong.
Nico
>  - Slime
Date: 12 Jan 2005 07:23:50
Message: <41e516d6@news.povray.org>
"Nicolas Rougier" <rou### [at] loriafr> wrote in message
news:41e4e85a$1@news.povray.org...
> block like:
> global_settings {
>    radiosity {
> pretrace_start 0.08
> pretrace_start 0.01
you don't need radiosity for that, just adding +sp8 +ep4 to your ini will show
you the same thing :)
cu!
Date: 12 Jan 2005 15:40:08
Message: <41e58b27@news.povray.org>
Among other things, Slime saw fit to write:
> But version 3.5 didn't have this problem, so if you're not depending on
> any of the changes in version 3.6, then you can use version 3.5 for your
If the alpha channel is OK, you could render twice (once with +ua and once
without) and use the alpha channel of the "transparent" picture for the
"opaque" one.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 13 Jan 2005 05:52:41
Message: <41e652f9$1@news.povray.org>
But I will get aliasing problem depending on the background, no ?
Nicolas
> "opaque" one.
w
Date: 13 Jan 2005 11:03:51
Message: <41e69be7@news.povray.org>
Yes.
When the alpha channel is turned on, the rgb values are divided with the
alpha value, such that when the rgb values are later multiplied with the
alpha value in an image viewer it will balance out.
If the dividing step is not done, you will get traces of the background
color at the edges of antialiased objects, and the background color will
also be visible behind all semi-transparent surfaces.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
