POV-Ray : Newsgroups : povray.binaries.images : Glass thingy Server Time
11 May 2026 05:04:29 EDT (-0400)
  Glass thingy (Message 1 to 10 of 24)
Subject: Glass thingy
Date: 2 Jan 2005 04:37:35
Message: <41d7c0df@news.povray.org>
I have this blob made up of 5000 glass spheres inside a spherical HDR.
The result is attached. I turned on photons, but can't get any caustics
to appear.
MegaPOV returns an error: Slab Building warning: Could not save photon
map - no photons!
The blob object hass these propertis:
sturm
   pigment { color rgbt 1 }
   finish {
     ambient 0
     diffuse 0
     reflection { 0.1, 1.0 fresnel on }
     conserve_energy
interior {
   ior 1.5
   fade_distance 1.1
   fade_color <0.11, 0.1, 0.3>
photons{
   target Radius1/2
   refraction on
   reflection on
I can't find out what is wrong. Any suggestions are welcome.
Download 'newt.jpg' (56 KB)
Preview of image 'newt.jpg'
Subject: Re: Glass thingy
Date: 2 Jan 2005 10:25:32
Message: <41d8126c$1@news.povray.org>
Maurice nous apporta ses lumieres ainsi en ce 2005-01-02 04:37... :
> Hi,
> caustics to appear.
> map - no photons!
> sturm
> texture {
>   finish {
>     ambient 0
>     diffuse 0
>     conserve_energy
> interior {
>   ior 1.5
>   fade_distance 1.1
> photons{
>   target Radius1/2
>   refraction on
>   reflection on
What are the photons settings for the floor? Does it collect them?
Date: 2 Jan 2005 10:30:22
Message: <41d8138e$1@news.povray.org>
>> Hi,
>> [blabla...]
The floor:
plane{ <0,1,0>, 0
   texture{
     pigment{checker color rgb<1,1,1>*1.2 color rgb<1,1,1>}
     finish{ambient 0.1 diffuse 0.8 metallic reflection{0.9}}
   no_radiosity
It has no photons section...
Maurice
Welcomes everybody to the fifth year of the century.
Date: 2 Jan 2005 11:34:35
Message: <41d8229b$1@news.povray.org>
Maurice nous apporta ses lumieres ainsi en ce 2005-01-02 10:30... :
>>> Hi,
>>> HDR. [blabla...]
> The floor:
> plane{ <0,1,0>, 0
>   texture{
>   no_radiosity
No photons section = collect on  target off  OK
Then, it may be that the high reflection value (0.9) make them almost
invisible. The more reflective a surface is, the less it will show
photons effects. That's the main reason why it's recomended to set
collect off for highly reflective surfaces.
Date: 2 Jan 2005 11:42:55
Message: <41d8248f@news.povray.org>
Additionally, check if max_trace_level for the photons is high enough to
actually reach the plane. If the glass object has lots of holes in it, a
photon won't pass through, but rather get stuck somewhere along the way.
Note that you can define different max_trace_level for photons and the
actual raytraced rays, but I'm unsure if they use the same keyword... You'd
have to look at the docs for that.
Tim
"Tim Nikias v2.0"
Date: 2 Jan 2005 12:15:00
Message: <web.41d82b0222cbf4d1685c150d0@news.povray.org>
Does your light_source emit photons?
-S
5TF!
Date: 2 Jan 2005 13:56:31
Message: <41d843df$1@news.povray.org>
> -S
> 5TF!
There is no lightsource as such. This is a scene running on radiosity.
The light is caused by a HDR image.
Maurice
Date: 2 Jan 2005 14:00:37
Message: <41d844d5@news.povray.org>
That explains everything. Only lightsources cause photons, if you'd want to
have caustics created by radiosity, you'd have to use ridiculously high
settings for the tracing depth.
A workaround would be to do a two-pass render. On the first pass, you only
render with a lightsource and photons, which you save to disk using
save_file in the photons-block. On the second pass, you render using
radiosity, but instead of placing an actual lightsource, you just load the
photons using load_file. You'd get the photons without the lightsource that
way.
"Tim Nikias v2.0"
Date: 2 Jan 2005 14:00:46
Message: <41d844de$1@news.povray.org>
>>>> Hi,
>>>> HDR. [blabla...]
>> The floor:
>> plane{ <0,1,0>, 0
>>   texture{
>>   no_radiosity
I think you might be right. When I switch off the reflective finish of
the floor I see a hint of caustics on the floor. Is there any way to
increase the strenght of the caustics? Can't seem to find anything in
the manual that promises to do this. I found the caustics keyword for
interior but whatever value I use it doesn't seem to give the right effect.
Maurice
Date: 2 Jan 2005 14:25:00
Message: <web.41d849c522cbf4d1a1a747bc0@news.povray.org>
Do what Tim said, using saved data. Radiosity does give very pale caustics,
but if you use the two pass method they will be clear and bright.
-S
5TF!
