POV-Ray : Newsgroups : povray.binaries.images : Glass thingy Server Time
14 Jul 2026 08:58:35 EDT (-0400)
  Glass thingy (Message 11 to 20 of 24)
<<< Previous 10 Messages Goto Latest 10 Messages Next 4 Messages >>>
Subject: Re: Glass thingy
Date: 2 Jan 2005 15:10:22
Message: <41d8552e@news.povray.org>
stm31415 wrote:
> Do what Tim said, using saved data. Radiosity does give very pale caustics,
> but if you use the two pass method they will be clear and bright.
> -S
> 5TF!
Thanks Tim and stm31415 for suggesting the two pass method. In the last
few trial renders I've gotten some interesting results. Now, at least
photons are being shot. Obviously more experimenting is needed with the
light placement and stuff like that, but at least I'm back on the road
again.
Thanks to all
Maurice
Date: 7 Jan 2005 15:25:00
Message: <web.41deef7a22cbf4d17aa29ee90@news.povray.org>
Hi Maurice,
    Just curious how things went and if you have an image to show us :)
George
> > -S
> > 5TF!
> again.
> Thanks to all
> Maurice
Date: 7 Jan 2005 15:49:02
Message: <41def5be@news.povray.org>
George Pantazopoulos wrote:
> Hi Maurice,
> Regards,
> George
>>>-S
>>>5TF!
>>again.
>>Thanks to all
>>Maurice
Well, not very proud of the current result really.
I rendered the scene with the HDR image off and a cylinderical
lightsource over the blob. Saving the photon and radiosity data.
The caustics seemed to look okay.
Then I switched off the lightsource put the HDR image back on and upped
the reflection of the floor to 0.5.
The result is attached.
The caustics are now transfomred to shadows... I'm now renderingwith a
less reflective floor (0.1). But I'm afraid I'll loose the effect I was
going for.
Maurice
Download 'newt.jpg' (72 KB)
Preview of image 'newt.jpg'
Date: 7 Jan 2005 16:20:01
Message: <web.41defbfa22cbf4d17aa29ee90@news.povray.org>
Pardon my ignorance, but I don't see a need for radiosity in your image. Why
is it there? I would try disabling radiosity for now and tweak your photons
settings. This would simplify your life by eliminate a big variable from
the equation :)
> going for.
What exact effect are you looking for, and what is the diffuse component of
your floor?
-George
Date: 9 Jan 2005 14:58:44
Message: <41e18cf4$1@news.povray.org>
> the equation :)
Radiosity is used to cause caustics?
>>going for.
> your floor?
Okay. It is rather difficult to explain, so I set up a page on my
website to show what is going on and what I'm after. Please visit:
http://members.home.nl/m.e.j.r.hendrix/POV/glass.html
Maurice
Date: 9 Jan 2005 16:20:46
Message: <41e1a02a@news.povray.org>
Looking for something like in the attached picture?
Ger
Download 'asbak-011-600.jpg' (45 KB)
Preview of image 'asbak-011-600.jpg'
Date: 9 Jan 2005 16:22:50
Message: <41e1a0aa$1@news.povray.org>
Yes. Although that might be overdoing it a bit ;-)
Date: 9 Jan 2005 16:33:04
Message: <41e1a30f@news.povray.org>
This is what I used
global_settings {
        max_trace_level 255
        photons {
                count 1000000
                autostop 0
                jitter .1
// light source just inside the ashtray
light_source{ 0 color rgb <1,1,1>*4 translate <-160,0.51,40>
        photons {
                refraction on
                reflection on
#declare YourBlobbyGlassThing =
        blob.................. etc
        material { M_Glass3 }
        photons {
                target
                refraction on
                reflection on
                collect on
object { YourBlobbyGlassThing }
With the ashtray this used ~1Gb memory and 70~80 hours to render at 1200 x
600 pixels, so you might want to lower the count first :)
Ger
Date: 10 Jan 2005 12:17:37
Message: <41e2b8b1$1@news.povray.org>
Ger wrote:
Thanks for your input, it is very inspiring. See comments below.
> global_settings {
>         max_trace_level 255
>         photons {
>                 count 1000000
>                 autostop 0
>                 jitter .1
That is a very high count. I'm using default value. I start to
understand why I don't get caustics
My photons settings:
   photons {
   	spacing 1/2
	gather 20,100
   	max_trace_level 300
   	jitter 0.4
   	adc_bailout 0.01
   	save_file "newt.photons"
And radiosity block:
   radiosity {
     samples 1
     pretrace_start 0.08
     pretrace_end   0.01
     count 800
     nearest_count 8
     error_bound 0.07
     recursion_limit 2
     low_error_factor .5
     gray_threshold 0.0
     minimum_reuse 0.015
     brightness 1 //0.7
     adc_bailout 0.01/2
     normal on
     randomize on
     //media on
     max_sample 1.0
     load_file "newt.radiosity"
     always_sample no
>         photons {
>                 refraction on
>                 reflection on
Mmm that's interesting. My lightsource has no photons attached :-\
>         photons {
>                 target
>                 refraction on
>                 reflection on
>                 collect on
photons block of the blob:
   photons{
     target 0.05
     refraction on
     reflection on
     collect off // **
Why did you switch on collect? Doesn't that mean that photons are not
exiting the object after they hit it?
I'm hoping that won't be the time for my render... Did you render with
saved photons or calculate the photons dyuring the actual render.
My idea is now to do as follows:
1. Render @ 80x40 with photons, radiosity and lightsource on; save_file
for photons and radiosity
2. Render @ 800x400 with lightsource off and HDR image on, load_file for
photons and radiosity.
I think I'll also try out what happens if I switch on/off radiosity as
George Patazopoulos suggested the scene does not need it. I'm not
convinced but the render results will show.
Bedankt for your help,
Maurice
Date: 10 Jan 2005 16:40:12
Message: <41e2f63b@news.povray.org>
You might want to start way lower to get a basic idea of what is the outcome
is gonna be
>    photons {
>    spacing 1/2
> gather 20,100
>    max_trace_level 300
>    jitter 0.4
>    adc_bailout 0.01
>    radiosity {
I didn't have radiosity because it tends to wash out a lot of sharp effects
As far as I know (but don't hit me over the head if I'm wrong) you need that
to get any caustics effects.
>    photons{
>      target 0.05
>      refraction on
>      reflection on
>      collect off // **
Hmm, don't remember now.
All in 1 go, so no in between saves.
I sure would switch it off to make the caustics effect more clear
Graag gedaan :)
Ger
