POV-Ray : Newsgroups : povray.binaries.images : Miss you - WIP #3 Server Time
14 Apr 2026 05:44:53 EDT (-0400)
  Miss you - WIP #3 (Message 11 to 13 of 13)
Subject: Re: Miss you - WIP #3
Date: 24 Dec 2004 04:18:35
Message: <41cbdeeb@news.povray.org>
Tim Nikias wrote:
> Hi all!
> The latest version of the image. I'm unsure if I really want to go ahead and
> add some clouds, mainly because the landscape already has much white and
> extra clouds would subtract the nice blue-white-contrast.
> I'm thinking about pulling the distant lone tree with the fence a little
> closer, there's still quite a gap between the forest and the fence. I'll
> also need to add some more fine-detail to the main heightfield to avoid the
> plain white areas, that just look's awful.
> Tried putting some mountains at the horizon, but that just looked
> ridiculously overloaded.
> Suggestions and comments welcome, as always! :-)
> Regards,
> Tim
i think i'd leave the right end of the fences alone and try moving the
tree/corner join left almost to forest edge, there's a conventient
dimple in there, almost horizontally left and jiggle with the fence
spacing as already suggested
suggestion of track outline in the snow, maybe with occasional grass
spikes. rutted track throws up a sort of higher edge and a bit in
middle, grass would poke though. hard to explain what i mean
have you tried scaling the cat up by 1.25/1.5 out of curiosity?
and move along a line right up 20-30 deg to compensate
stephen
Date: 24 Dec 2004 05:31:01
Message: <41cbefe5$1@news.povray.org>
Yup, more irregularities in the fence are planned. The algorithm was simple
divide-and-place, but modifications should be simple.
I've already begun searching for some reference photos. As of yet I'm unsure
if I can get it right, but I'll try. If it doesn't work, I'll drop it. First
I'll check on the fences and the corner-position, might make a track
impossible to place.
Moving it away from the straight line is a good suggestion, scaling it
larger might be in order when they're moved. Otherwise, the cat-treehouse
relationship gets a little strange...
Thanks,
Tim
"Tim Nikias v2.0"
Date: 24 Dec 2004 09:42:09
Message: <41cc2ac1$1@news.povray.org>
Tim Nikias wrote:
> Hi all!
> Regards,
> Tim
Superb algorithmic work...really looks like a "real" forest and bushes. :)
But the image is starting to feel a little busy. The focus of the cat &
tree has been lost a bit, I think. The fence & lone tree is a great
touch, but if it was me I'd leave out the bushes altogether and spread
the forest trees out more or thin them a little (only in areas where the
trees have been hand-planted do they grow that thick!). The vehicle
tracks in the snow is a pretty good idea...that would add a civilized
feel to the scene, instead of the cat sitting out in the boonies
somewhere. :)
I think I would also lighten up the birdhouse a little...it looks dirty.
I know you're going for a "weathered" effect, but I think it's been
weathered just a little too much. :) The bendiness of the fence rails is
a great touch...I think I would reduce the bendiness just a little,
though. They all seem to be tilted down a little, too. I love the way
the snow lies on the far rails. :)
The moon is a great addition. I think you should leave the sky just the
way it is...I think it really sets off the white snow really well (and
skies that blue do happen occasionally in winter!)
Great work, as always!!
~Mike
