POV-Ray : Newsgroups : povray.binaries.images : Miss you - WIP Update Server Time
14 Jul 2026 10:25:44 EDT (-0400)
  Miss you - WIP Update (Message 11 to 18 of 18)
Subject: Re: Miss you - WIP Update
Date: 20 Dec 2004 09:51:46
Message: <41c6e702$1@news.povray.org>
Great ideas can take you farther than technical precision. You have both
there, so don't worry; it already is a great image and from now on it can
only get better.
I'm too much of a newbie to give you any advice. I think the image is great
as it is. Cheers.
Date: 20 Dec 2004 14:00:45
Message: <41c7215d$1@news.povray.org>
Tim Nikias wrote:
> Suggestions, comments and questions welcome,
   This looks fantastic! These macros should be of good use for a lot of
things... About the image itself, I don't have enough experience with
snow and cold places to comment on it (for example, is really the sky so
violet there?).
Jaime
Date: 20 Dec 2004 19:16:24
Message: <41c76b58@news.povray.org>
> This is becoming very nice!!
Thanks!
> Just a suggestion: usually, along the border of a wood, trees tend to be
> smaller and have branches starting lower than inside the wood  because
they
> don't have to seek light.
I'm thinking about adding some smaller vegetation, like bushes, because
adding branches could be a little more difficult.
> Well another suggestion: two or three fences across that wide field
> range....
Yeah, I've been thinking about that possibility...
Tim
"Tim Nikias v2.0"
Date: 20 Dec 2004 19:17:45
Message: <41c76ba9$1@news.povray.org>
> only get better.
Thank you very much for the kind words!
great
> as it is. Cheers.
Nah, don't underestimate your own taste! You're possibly right that you're a
newbie on the technical side of things, but you can still make suggestions
on what you think is missing or needs adjustment. :-)
"Tim Nikias v2.0"
Date: 20 Dec 2004 19:28:08
Message: <41c76e18@news.povray.org>
> One comment, one suggestion and two questions. First the comment, the
> face on the cat looks a little strange.
It is looking up at the sign. Modelling a face using blobs isn't that easy,
but on a higher res the viewing direction of the cat can be discerned more
easily. Since the cat *does* look like a cat, I wanted to improve on the
overall image before getting stuck with it...
> I suppose this could be accomplished with a bump map or some averaged
> normals or something, but I was trying to think of a better way to do
> it. There seems to be a general sentiment running that bump-mapping is
> cheating somehow, and I don't like using normals to simulate actual
> shapes (personal preference, probably completely unfounded). So I
> wondered...would it be possible to use Surcoat to do the general snow
> layer with a good blob factor, then to do it again on top of that and
> shrink the blobs to a really tiny size so that they don't join at all,
> but rather look like little crystals sitting on top of the snow layer?
Yes, that is possible. You'd just have to do a two-pass with Surcoat: one to
collect the initial, rough data, and then a second pass onto the blob. You'd
have to either render an orthographic view of the blob (to speed up the
sampling of the second pass) or just shoot samples at the entire boundary
box, but that shouldn't be a too big problem, right? ;-)
> Second question: how does Surcoat handle the snow layers?
Actually, all samples, along with their respective surface normal, are
simply saved into a file. A simple loop can then parse through the file and
while the File is defined, like this:
#fopen File Surcoat_Data read
#while (defined(File))
#read (File, Sample_Position, Sample_Normal)
//do some stuff
#fclose File
I've prepared a simple set of macros for visualization, e.g. placing objects
at the samples' positions, or create a simple, spherical blob, or just place
spheres with a given radius. It should be easy to write your own
visualization macro, as the read-in (as seen above) is quite simple.
For the snow, I've written another set of macros which actually trace() the
surroundings of a sample to add some data like possible height, closest wall
and such, to generate heights for the snow. Instead of spheres, I use
cylinders in a blob to visualize the samples (along with the added data).
The processing of the original data into an extended set is of course more
scripting-biased, but that's the way it always is, right?
> Lastly, the suggestion...it seems likt there's a high "blue factor" in
> your snow. With such strong shadows I think it would be a tad more
> realistic if it were more blindingly white. Maybe it's that "artistic
> license" again...just a thought.
Hm, I'll think about that. Need to inspect some more winter photographs. :-)
> Overall incredible work. You're in my HOF book now. :)
Thanks for the praise. :-)
"Tim Nikias v2.0"
Date: 20 Dec 2004 19:29:52
Message: <41c76e80$1@news.povray.org>
> things...
Thank you! As for the macros: I hope so! Would rather have them see being
used than collecting dust on my website! :-) Release of them is still a
little off though, as I don't have the time to clean the code and write a
help at the moment.
> violet there?).
The sky is just a temporary placement, the colors will get adjusted to a
more realistic palette once I get to creating the clouds and such.
"Tim Nikias v2.0"
Date: 21 Dec 2004 04:05:01
Message: <web.41c7e6d9c5f2ea51ba7e96eb0@news.povray.org>
My suggestion would be to leave out the clouds and seriously consider
not altering the sky color either.  To me (a finn) it looks perfect,
although on one condition:  the date is, roughly, from March/April.
But it really is a very good looking image, and I congratulate you
on your execution of the snow dropping macros -- very convincing results.
jussi
Date: 21 Dec 2004 08:57:21
Message: <41c82bc1$1@news.povray.org>
March/April?! There's snow in the image, for god's sake! :-) Seriously
though, I want to take some pictures of the sky here (when it's cold and
clear with little haze, but some clouds) and use that as reference for
colors. As for the clouds, I don't want to overload the sky, just a few
details, as we here (not in Finnland ;-) don't have too many days with no
clouds. Thanks for the feedback though!
Thank you! :-)
"Tim Nikias v2.0"
