POV-Ray : Newsgroups : povray.binaries.images : Cockpit Utility Light Server Time
21 Mar 2026 22:05:34 EDT (-0400)
  Cockpit Utility Light (Message 1 to 8 of 8)
Subject: Cockpit Utility Light
Date: 10 Dec 2004 13:58:47
Message: <41b9f1e7@news.povray.org>
When learning instrument flying and the first few night flights you learn to
always have at least two (I like three) flashlights handy. There's a company
in California that makes cockpit lights for some situations before you have
to resort to the flight kit for a flashlight. The version I've modelled here
allows the pilot to save his night vision by using variable voltage and a
red filter, as well as adjusting for a flood or spot light effect.
I just think they're cool just like everything else about airplanes!
- Grim
Download 'CockpitLight.jpg' (56 KB)
Preview of image 'CockpitLight.jpg'
Subject: Re: Cockpit Utility Light
Date: 10 Dec 2004 16:52:50
Message: <41ba1ab2$1@news.povray.org>
GrimDude wrote:
Looks like the POV export on whatever program you are using chewed up
your mesh. Looks like a cool flashlight if it were cleaned up.
  -Shay
Date: 10 Dec 2004 17:17:58
Message: <41ba2096$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message
news:41ba1ab2$1@news.povray.org...
> GrimDude wrote:
> Looks like the POV export on whatever program you are using chewed up your
>  -Shay
Thanks, Shay (I think). Where do you see this as being chewed up?
(Link to manufacturer's website)
http://www.soderberg.aero/images/pdf/S1210.pdf
- Grim
Date: 10 Dec 2004 17:34:27
Message: <41ba2473$1@news.povray.org>
> chewed up?
see attached picture
  -Shay
Download 'chewed.jpg' (4 KB)
Preview of image 'chewed.jpg'
Date: 10 Dec 2004 18:18:08
Message: <41ba2eb0$1@news.povray.org>
Fascinating gizmo - I've learnt something!
For the imge quality, it wouldn't hurt to make the inner bore a smoother
circle (looks like a polygon with about 10 degree steps). Antialiasing won't
hurt the edges either.
DLM
"GrimDude" <a36### [at] bellsouthnet> wrote in message
news:41ba2096$1@news.povray.org...
>>  -Shay
> - Grim
Date: 10 Dec 2004 18:37:36
Message: <41ba3340$1@news.povray.org>
Oh, I saw that as a mistake in 'error_bound.' With AutoCAD the mesh can be
smoothed further by increasing the 'isolines' variable, which is really
easy. I rendered this again with the new value for e_b and a doubling of the
mesh density. I tested it with the same e_b value and a mesh four times as
dense and the same effect could be seen, though reduced in severity.
Thanks for pointing that out.
- Grim
Download 'CockpitLight2.jpg' (4 KB)
Preview of image 'CockpitLight2.jpg'
Date: 11 Dec 2004 00:34:11
Message: <41ba86d3@news.povray.org>
> - Grim
You have done a good job modeling. Do the ones you use have a detachable
base and power cord?
Date: 11 Dec 2004 02:39:13
Message: <41baa421@news.povray.org>
"Mr. Art" <pfl### [at] stxrrcom> wrote in message
news:41ba86d3@news.povray.org...
Thanks. The base can be relocated, or interchanged. The power cord is
soldered to the bulb socket, so it can't really be removed except to service
the light. I didn't model the cord, because it's a simple matter to create
one should I ever use this in a cockpit scene (and you know I will). I will
probably use the older method of a stiff-cord (sort of like one of Doctor
Octopus' mechanical arms), if and when I do.
In AutoCAD the cord would be created with a circle swept (extruded) along a
helix path and then unioned with other sweeps as needed. I'm sure there's
probably a way to do that in Pov that would save on resources by comparison.
- Grim
