POV-Ray : Newsgroups : povray.binaries.images : a couple of wheels (POV vs ProEngineer) Server Time
14 Apr 2026 13:58:55 EDT (-0400)
  a couple of wheels (POV vs ProEngineer) (Message 1 to 5 of 5)
Subject: a couple of wheels (POV vs ProEngineer)
Date: 15 Nov 2004 15:09:33
Message: <41990cfd@news.povray.org>
Here are two wheels I drew, I was roughly trying to copy the wheels off my
radio controlled car, but I didn't actually have them in front of me while I
was drawing.
Anyway, the one on the green background I did completely in POV (using solid
of revolution and prism cuts) and it took a couple of hours.  The one on the
white background I did at work using ProEngineer in my lunch break, took
about 30 mins to model and another 5 or so to import into POV.  I would have
added some tread to the tyre but I ran out of time!
So, after this experience, here are some points I've noticed:
* In POV it is very hard to add rounds to edges that are a result of complex
CSG, it takes lots of thought and is a pain in the bum.  In a modeller it is
easy to just select the edge and choose "round" no matter how wiggly or
curved it is.
* Getting the actual shape right takes a long time in POV, unless you have
actual measurements to use it takes a lot of trial and error to get
something that looks right.
* Making quick little changes is very easy in a modeller, but having to
export and import into POV every time you decide something isn't quite right
is a pain in the behind.  The files are also very big if you want good
quality (I think that wheel was 80k triangles or something).
* Using the solid of revolution feature it took me a while to get the
straight edges / rounded bits right, lots of faffing around.  In the
modeller you can just draw and see exactly what you're doing in real time.
* I can get away with drawing wheels in POV at work, but not drawing them in
the modeller :-)
Download 'wheel.jpg' (24 KB) Download 'wheel1.jpg' (18 KB)
Preview of image 'wheel.jpg'
Preview of image 'wheel1.jpg'
Subject: Re: a couple of wheels (POV vs ProEngineer)
Date: 15 Nov 2004 19:52:39
Message: <41994f57$1@news.povray.org>
I don't know if anyone has heard about it, but solidwerks is a good piece of
software....
Date: 16 Nov 2004 11:13:11
Message: <419a2717$1@news.povray.org>
SolidWorks is very good indeed. I use it at university (as a student). To
bad I can't find a way to export the files to pov-ray other than using VRML
files.
Greetings,
JWV
"Eli" <eli### [at] jehoelnet> wrote in message news:41994f57$1@news.povray.org...
of
> software....
Date: 16 Nov 2004 14:42:50
Message: <419a583a@news.povray.org>
"JWV" <jwv|at|planet.nl> wrote in message
news:419a2717$1@news.povray.org
> student). To bad I can't find a way to export the files to pov-ray
> other than using VRML files.
Does it export *.slp files?  That's what I use from ProE, then use
slp2pov.exe to convert to a pov include file.
Date: 16 Nov 2004 19:08:49
Message: <419a9691$1@news.povray.org>
I have something called "PovWorks" that claims to export SolidWorks files to POV
format.  I used it a few years ago but right now I don't have it (or
SolidWorks) installed.  Unfortunately when I googled for the current version to
provide a link I couldn't find anything useful.  I would send you mine
but I'm sure it's too old for recent versions of either SolidWorks or POV.  Too bad.
> files.
> Greetings,
> JWV
> of
>>software....
